DISPL50CM
DISPL50CM
    STARTECH
    DISPL50CM
DISPL50CM 数据手册
0.5m Short DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k Product ID: DISPL50CM The DISPL50CM 0.5m/50cm DisplayPort 1.2 Cable with latches provides a secure, connection between your DisplayPort-equipped devices and is capable of providing higher performance than either HDMI® or dual link DVI. The DP cable supports high resolutions of up to 4k x 2k (4096 x 2160) @ 60Hz with a maximum HBR2 bandwidth of 21.6 Gbps. The cable also supports Multi-Stream (MST) for daisy chaining multiple monitors and provides optional audio support. The short 50cm DisplayPort cable is perfect for mobile applications, such as connecting your laptop to a monitor and it provides a portable solution that makes it perfect for carrying as a laptop accessory. The DISPL50CM is backed by StarTech.com’s Lifetime Warranty, for guaranteed reliability and ensures that digitally protected content is displayed properly, with both HDCP and DPCP capability. www.startech.com/uk 0800 169 0408 Certifications, Reports and Compatibility Applications • Connecting a DisplayPort Display to a PC or other DisplayPort Source Features • • • • • High-resolution support of up to 4k x 2k Support for High Bit Rate 2 (HBR2) bandwidth of up to 21.6 Gbps Backward compatible with DisplayPort 1.1 Offers 50cm in cable length Designed and manufactured to DisplayPort 1.2 standards • Supports the DPCP (DisplayPort Content Protection) standard in addition to HDCP Molded latching connectors with strain relief • www.startech.com/uk 0800 169 0408 Hardware Connector(s) Physical Characteristics Packaging Information What's in the Box Warranty Lifetime Cable Jacket Type PVC - Polyvinyl Chloride Cable Shield Type Aluminum-Mylar Foil with Braid Connector Plating Nickel Fire Rating CMG Rated (General Purpose) Number of Conductors 19 Connector A 1 - DisplayPort (20 pin) Latching Male Connector B 1 - DisplayPort (20 pin) Latching Male Cable Length 0.5 m [1.6 ft] Cable OD 7.3 mm [0.3 in] Color Black Connector Style Latching Product Height 12 mm [0.5 in] Product Length 0.5 m [1.6 ft] Product Weight 40 g [1.4 oz] Product Width 20 mm [0.8 in] Wire Gauge 28 AWG Package Quantity 1 Shipping (Package) Weight 58 g [2 oz] Included in Package 1 - 0.5m Latching DisplayPort 1.2 Cable Product appearance and specifications are subject to change without notice. www.startech.com/uk 0800 169 0408
DISPL50CM 价格&库存
很抱歉,暂时无法提供与“DISPL50CM”相匹配的价格&库存,您可以联系我们找货
