ICUSBAUDIOB
ICUSBAUDIOB
    STARTECH
    STARTECH - ICUSBAUDIOB - USB Stereo Audio Adaptor External Sound Card
ICUSBAUDIOB 数据手册
USB Stereo Audio Adapter External Sound Card StarTech ID: ICUSBAUDIOB This USB Audio adapter converts a USB port to an audio port, allowing you to add headsets and microphones to your computer without the need to unplug other devices! Compliant with USB 2.0 and USB audio device specification 1.0, the USB audio adapter couldn't be any simpler to install...it's as easy as connecting the adapter to an available USB 2.0 port, then connecting your audio devices to the provided 3.5 mm audio ports as needed. Compatible with Windows 98SE and up, as well as Mac OS 9.x and later, the adapter integrates into any computer environment, providing superb sound quality and convenience that can't be matched. Applications Add audio support to any USB capable computer system Replace a failed onboard audio port for desktops or laptops Connect 3.5mm mini-jack headset to a Playstation 3 console Features 3.5mm mini-jack connectors for headphone and MIC Headphone and microphone support on PlayStation 3 Compact, palm sized form factor Compliant with USB audio device class specification 1.0 Plug-and-Play compliant uk.startech.com 0800 169 0408 Technical Specifications Warranty Chipset ID Connector Type(s) Connector Type(s) OS Compatibility 2 Years C-Media - CM108AH 1 - USB A (4 pin) Male 2 - 3.5 mm Mini-Jack (3 Position) Female Windows 2000/ XP(32/64-bit)/ Vista(32/64-bit)/ 7(32/64-bit)/ 8 (32/64-bit) Mac OS X (tested up to 10.8) Linux Color Black Enclosure Type Plastic Product Length 80 mm [3.1 in] Product Width 40 mm [1.6 in] Product Height 15 mm [0.6 in] Product Weight 53.5 g [1.9 oz] Shipping (Package) Weight 0.1 kg [0.3 lb] Included in Package 1 - USB to Audio Adapter Included in Package 1 - Instruction Manual uk.startech.com 0800 169 0408 Certifications, Reports and Compatibility uk.startech.com 0800 169 0408
ICUSBAUDIOB 价格&库存
很抱歉,暂时无法提供与“ICUSBAUDIOB”相匹配的价格&库存,您可以联系我们找货
ICUSBAUDIOB
    库存:20
    ICUSBAUDIOB
    库存:28
    ICUSBAUDIOB
    • 1+242.69448
    库存:28
