DVI2VGAE
DVI2VGAE
    STARTECH
    STARTECH - DVI2VGAE - Connector Adapter, DVI-D, 1 Ways, Plug, VGA, 1 Ways, Receptacle
DVI2VGAE 数据手册
DVI-D to VGA Active Adapter Converter Cable – 1920x1200 StarTech ID: DVI2VGAE The DVI2VGAE active DVI-D to VGA adapter lets you connect a digital DVI output from your desktop or laptop computer onto a VGA monitor or projector, saving the cost of upgrading to a DVI-D compatible display. Providing a simple way to output user-generated content such as presentations and work documents, the DVI-D to VGA converter can also work to increase your productivity by extending your computer's desktop onto to a secondary monitor, doubling available workspace. This portable adapter works to convert a standard powered DVI bus to VGA, without an external power source. For low-powered DVI ports, a USB cable is included that can power the device from any USB power source. With support for resolutions up to 1920x1200 (WUXGA), this active adapter offers a comprehensive solution for connecting a High-Definition VGA display to a DVI-D video source. The DVI2VGAE DVI-D to VGA Adapter is backed by a StarTech.com 2-year warranty and free lifetime technical support. Applications Connect digital DVI-enabled devices, such as your laptop or desktop computer, to a VGA projector or display Features Maximum resolution of 1920x1200 No external power adapter required uk.startech.com 0800 169 0408 Technical Specifications Warranty 2 Years Converter Type Active Audio No Connector A 1 - USB Micro-B (5 pin) Connector A USB Micro-B (5 pin) Female Connector Type(s) USB Micro-B (5 pin) Connector A 1 - DVI-D (19 pin) Male Connector B 1 - VGA (15 pin; High Density D-Sub) Female Maximum Digital Resolutions 1920x1200 Wide Screen Supported Yes Maximum Analog Resolutions 1920x1200 Color Black Product Length 248 mm [9.8 in] Product Width 45 mm [1.8 in] Product Height 15 mm [0.6 in] Product Weight 75 g [2.6 oz] Shipping (Package) Weight 0.1 kg [0.2 lb] Included in Package 1 - DVI-D to VGA Adapter Converter Included in Package 1 - USB type A to Micro USB type B Cable Certifications, Reports and Compatibility uk.startech.com 0800 169 0408
DVI2VGAE 价格&库存
很抱歉,暂时无法提供与“DVI2VGAE”相匹配的价格&库存,您可以联系我们找货
