10-Port Industrial USB 3.0 Hub with External
Power Adapter - ESD & 350W Surge Protection
Product ID: HB30A10AME
This TAA compliant 10-port industrial USB 3.0 hub gives you the
scalability and power supply flexibility you need in harsh industrial environments, product, and repair labs,
conference rooms or office workstations. With its rugged industrial-grade metal housing, it is designed to
meet the advanced requirements of connecting a high number of devices in factories and office
environments.
Perfect for Harsh Environments
This industrial USB hub delivers reliable performance with a metal, heavy-duty housing. It supports widerange 7-24V DC terminal block input, giving you the flexibility to power the hub as required, based on
your own power input capabilities.
Perfect for factory environments, the rugged hub also supports a wide operating temperature range (0°C
to 70°C) and offers surge and ESD protection to each USB port, which can help prevent damage to your
connected devices.
www.startech.com
1 800 265 1844
Connect & Charge More USB Devices
Designed for a high volume of connections, this robust USB 3.0 hub offers 10 connection ports, for
connecting more USB devices and peripherals.
The hub also supports USB battery charging specification 1.2, delivering up to 2.4A on any port to a
maximum of 50W total, so you can charge your mobile devices faster than traditional USB ports allow.
Locate the Hub Where You Need It Most
With versatile installation options, you can install the hub where it’s best suited for your environment.
With built-in mounting brackets and included DIN mount rails, you can securely mount the USB 3.0 hub to
most surfaces such as a wall, under a desk or rack.
It supports wide-range 7-24V DC terminal block input, giving you the flexibility to power the hub as
required, based on your own power input capabilities. You have the option to power the industrial hub by
connecting the hub directly to an outlet with the included external terminal block power adapter, for more
convenient and flexible installation.
Works with Older USB Devices
The rugged USB hub supports the full 5Gbps bandwidth of USB 3.0 and is backward compatible with
previous USB devices. You can connect your legacy peripherals alongside your newer USB 3.0 devices
without any disruptions.
The HB30A10AME is backed by a StarTech.com 2-year warranty and free lifetime technical support.
www.startech.com
1 800 265 1844
Certifications, Reports
and Compatibility
Features
Protects your connected devices with 15kV Air and 8kV Contact ESD
protection
Surge protection of 350W on the downstream and upstream USB
ports
Mount industrial USB hub where required with built-in mounting
brackets or included DIN rails
Offers flexible, wide-range power inputs with a 7-24V DC terminal
block and included external power adapter
USB Battery Charging Specification 1.2 up to 2.4A on any port to a
www.startech.com
1 800 265 1844
Hardware
Performance
Warranty
2 Years
Bus Type
USB 3.0
Chipset ID
Genesys Logic - GL3523
Fast-Charge Port(s)
Yes
Industry Standards
USB Battery Charging Specification Rev. 1.2
USB 3.2 Gen 1 - Backwards compatible with USB 3.0, 3.0,
and 1.1
Interface
USB 3.0
Ports
10
USB-C Device Port(s)
No
USB-C Host Connection
No
ESD Protection
+/-15kV (Air)
+/-8kV (Contact)
Connector(s)
Maximum Data Transfer Rate
5 Gbps
MTBF
126,106 Hours
Surge Protection
350W on the DFP and UFP
Type and Rate
USB 3.0 - 5 Gbit/s
UASP Support
Yes
Connector Type(s)
10 - USB 3.1 USB Type-A (9 pin, Gen 1, 5 Gbps) Female
1 - USB Type-B (9 pin) USB 3.0 Female
1 - Terminal Block (2 Wire)
Software
OS Compatibility
OS Independent; No additional drivers or software required
Special Notes /
Requirements
Note
If connected to a USB 2.0 host port, performance may be
limited
This product is intended for use with terminal block power
only – Standard AC adapter not available
System and Cable Requirements
Host computer with an available USB 3.0 port
Indicators
LED Indicators
1 - Power (Green)
Power
Input Current
1.4A
Input Voltage
100 - 240 AC
Output Current
3.25A
Output Voltage
20V DC
Plug Type
www.startech.com
1 800 265 1844
Environmental
Physical
Characteristics
Packaging
Information
What's in the Box
Power Consumption (In Watts)
65W
Power Source
AC Adapter Included
Humidity
5%~95% RH (Non-condensing)
Operating Temperature
0°C to 70°C (32°F to 158°F)
Storage Temperature
-20°C to 85°C (-4°F to 185°F)
Color
Black
Product Height
30.000
Product Length
198.000
Product Width
55.000
Weight of Product
352.000
Package Height
70.000
Package Length
295.000
Package Width
190.000
Shipping (Package) Weight
1362.000
Included in Package
1 - USB Hub
1 - USB 3.0 Host Cable
1 - Universal Power Adapter (NA/JP, ANZ, UK, EU)
2 - DIN Rail Brackets
4 - Mounting Screws
1 - Quick-Start Guide
Product appearance and specifications are subject to change without notice.
www.startech.com
1 800 265 1844
很抱歉,暂时无法提供与“HB30A10AME”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2743.368121+356.34960
- 10+2433.9077910+316.15228
- 25+2362.0111025+306.81326
