HB30A4AIB
HB30A4AIB
    STARTECH
    STARTECH - HB30A4AIB - Hub, USB 3.0, 4 Ports, 5 Gbps, Bus Powered
HB30A4AIB 数据手册
4 Port USB 3.0 Hub - USB-A to 4x USB 3.0 Type-A with Individual On/Off Port Switches SuperSpeed 5Gbps USB 3.1/3.2 Gen 1 - USB Bus Powered - Portable - 9.8" Attached Cable Product ID: HB30A4AIB This portable USB 3.0 hub gives you an easy way to add four USB 3.0 Type-A ports to your laptop, with individual power switches to save power. The USB port expander plugs easily into your laptop’s USB Type-A port. Plus, it’s bus-powered for easy portability. Use your existing USB 3.0 devices such as flash drives, mouse, keyboard and external hard drives. The 4-port USB 3.0 hub expands your computer’s USB Type-A port into four USB 3.0 (Type-A) ports, and it’s backward compatible with your older USB 2.0 devices. (USB 3.0 is also known as USB 3.1 Gen 1.) Each port on the USB 3.0 hub has its own power switch so you can turn off devices when they’re not in use. That means you can better manage power consumption for your USB devices, without having to physically disconnect the device or cable. With its compact, lightweight design, this hub is perfect for portable use. The versatile USB to USB hub is bus-powered, with no need for an external power adapter. You can travel lighter with fewer cables to carry with you. The 4-Port USB 3.0 hub installs automatically when you connect it to your laptop, so you can be up and running in seconds. HB30A4AIB is backed by a StarTech.com 2-year warranty and free lifetime technical support. Certifications, Reports and Compatibility Applications • Take the hub with you when you travel, to connect your USB devices • Switch unused ports off when using high power-consuming USB equipment • Perfect for office, hot-desk, home office and bring-your-own-device environments Features • 4-PORT USB 3.0 HUB: Expand the connectivity of a USB-A laptop by adding 4x USB-A ports w/ individual port switches, using this USB 3.2/3.1 Gen 1 5Gbps bus powered hub; 4.5W shared w/downstream devices • INDIVIDUAL PORT SWITCHES: Each USB-A port has an on/off push button (w/ LEDs) to disconnect power/data to devices; Save energy by turning off SSD/thumb drives, web cams, headsets, etc. when not in use • MANAGE POWER & RESET DEVICES: Port switches enable you to direct power to selected peripherals, power on/off without physically unplugging the device which reduces wear and tear on the USB port • COMPACT & PORTABLE: A lightweight bus powered USB 3.0 hub with black plastic housing, 9.8" (25 cm) attached USB-A host cable and small form factor [3.3in (85mm) x 1.4in (35mm) x 0.8in (1.9cm)] • WIDE COMPATIBILITY: USB Type-A laptop hub is OS independent & no drivers to install; supporting operating systems including Windows, macOS, Linux, Chrome OS and Android; USB 3.0/2.0 device compatible Hardware Warranty 2 Years USB-C Device Port(s) No USB-C Host Connection No Fast-Charge Port(s) No Ports 4 Interface USB 3.0 Bus Type USB 3.0 Industry Standards USB 3.1 Gen 1 (USB 3.0) - Backward compatible with USB 2.0 and 1.1 Chipset ID VIA/VLI - VL817 Maximum Data Transfer Rate 5 Gbps Type and Rate USB 3.0 - 5 Gbit/s UASP Support Yes MTBF 841,302 hours Performance Connector(s) Connector Type(s) USB Type-A (9 pin) USB 3.0 (5 Gbps) USB Type-A (9 pin) USB 3.0 (5 Gbps) Software OS Compatibility OS Independent; No additional drivers or software required System and Cable Requirements Available USB Type-A port - USB 3.0 (5Gbps) Special Notes / Requirements The total available power output of the HB30A4AIB is based on the available input power and is shared between all downstream facing ports. Indicators LED Indicators Port Power Power Source USB-Powered Operating Temperature 0C to 55C (32F to 131F) Storage Temperature -10C to 70C (14F to 158F) Humidity 20~80% RH (Non-condensing) Color Black Form Factor Compact Material Plastic Cable Length 9.8 in [25 cm] Product Length 3.3 in [85 mm] Product Width 1.4 in [34.9 mm] Product Height 0.8 in [19.2 mm] Weight of Product 1.5 oz [43 g] Power Environmental Physical Characteristics Packaging Information Package Length 5.6 in [14.2 cm] Package Width 6.7 in [17 cm] Package Height 1.2 in [30 mm] Shipping (Package) Weight 3.8 oz [107 g] Included in Package hub What's in the Box quick-start guide *Product appearance and specifications are subject to change without notice.
HB30A4AIB 价格&库存
很抱歉,暂时无法提供与“HB30A4AIB”相匹配的价格&库存,您可以联系我们找货
HB30A4AIB
  • 1+353.53936
库存:16
