USB to RS232 DB9/DB25 Serial Adapter Cable - M/M
StarTech ID: ICUSB232DB25
The ICUSB232DB25 USB to RS232 DB9/DB25 Serial Adapter Cable (M/M) lets you connect 9-pin (DB9) or 25-pin
(DB25) RS232 serial devices to your laptop or desktop computer through a USB port, as though the computer
offered an onboard serial port. The integrated 3-foot (0.9 meter) cable allows it to be connected directly from the
serial device to the computer without requiring additional cables.
A cost-effective solution that bridges the compatibility gap between modern computers and legacy serial
peripherals, this high quality USB/RS232 Serial Adapter cable ships with a DB-9 to DB-25 adapter for connection
to varied serial equipment.
Backed by a StarTech.com 2-year warranty and free lifetime technical support.
Applications
Ideal for connecting serial devices to laptops or tablet PCs through the USB port
Connect to and monitor/control industrial sensors
Connect bar code scanners and other serial devices to a USB port
Connect a serial modem, digital camera, or PDA with serial sync to your PC's USB port
Connect to automotive ODB/ODBII sensor adapters that use serial connectivity
uk.startech.com
0800 169 0408
Features
USB powered; No external power adapters needed
Supports serial transfer speeds up to 250Kbps
Includes a DB9 to DB25 pin adapter for 25-pin RS232 serial communication
Supports USB transfer speeds up to 12Mbps
Plug-and-Play and Hot Swap Support
Windows certified (WHQL) drivers
3ft cable length
Supports remote wake-up from Modem input signals and USB power management
Compliant with USB Rev. 2.0 Full-Speed specification
Electronics Industries Association (EIA) standard RS-232-C compliant
USB to Straight-Through RS232 Serial Adapter
uk.startech.com
0800 169 0408
Technical Specifications
Warranty
Port Style
Ports
Interface
Bus Type
Chipset ID
Connector
Type(s)
External Ports
External Ports
Max Baud
Rate
Serial Protocol
Data Bits
FIFO
Flow Control
Parity
Stop Bits
OS
Compatibility
2 Years
Cable Adapter
1
USB 2.0
USB 2.0
Prolific - PL-2303
1 - USB A (4 pin) Male
1 - DB-25 (25 pin; D-Sub) Male
1 - DB-9 (9 pin; D-Sub) Male
230.4 Kbps
RS-232
4, 5, 6, 7, 8
512 Bytes
None, Xon/ Xoff, Hardware
None, Even, Odd, Mark, Space
1, 1.5, 2
Windows® 8 (32/64bit), 7 (32/64), Vista(32/64), XP(32/64), XP Embedded, POS Ready 2009,
Embedded System 2009, CE 4.2/5.2, Windows Mobile 5/6, PocketPC 2003, 2000
Windows® Server 2008 R2, 2003(32/64)
Mac OS 10.1 and up (Tested up to 10.8)
Linux
Yes
Microsoft
WHQL
Certified
Cable Length 0.9 m [3 ft]
Enclosure
Plastic
Type
Color
Gray
Product Length 0.9 m [3 ft]
Product
70 g [2.5 oz]
Weight
Humidity
5~85% RH
Operating
0°C to 70°C (32°F to 158°F)
Temperature
uk.startech.com
0800 169 0408
Storage
Temperature
Shipping
(Package)
Weight
Included in
Package
Included in
Package
Included in
Package
Included in
Package
-40°C to 85°C (-40°F to 185°F)
90 g [3.2 oz]
1 - 3ft USB to RS232 Cable
1 - DB9 to DB25 Serial Adapter
1 - Driver CD
1 - Manual
Certifications, Reports and Compatibility
uk.startech.com
0800 169 0408
很抱歉,暂时无法提供与“ICUSB232DB25”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+261.582001+33.94005
- 10+232.0295510+30.10565
- 25+221.2267325+28.70399
- 50+213.3953650+27.68787
- 100+205.84216100+26.70785
- 250+196.26857250+25.46569
