ICUSB232V2
ICUSB232V2
    STARTECH
    ICUSB232V2
ICUSB232V2 数据手册
1 Port USB to RS232 DB9 Serial Adapter Cable - M/M Product ID: ICUSB232V2 The ICUSB232V2 1 Port USB to Serial Adapter converts a USB port into an RS232 DB9 serial port to connect to, monitor, and control a serial device. Supporting data transfer rates up to 921.6 Kbps, the USB to serial cable is a convenient and cost-saving solution for providing serial connectivity to devices such as point-of-sale terminals, serial modems, industrial equipment, and a wide variety of other RS232 peripherals. The USB to RS232 converter is easy to install and offers broad operating system compatibility, including Windows 8 and later, Linux and Mac OS, for easy integration into mixed environments. Backed by a StarTech.com 3-year warranty and free lifetime technical support. Certifications, Reports and Compatibility Applications • IT Administrators looking to add legacy functionality to newer notebooks, PCs and servers that lack an integrated RS232 port • Connect bar code scanners, receipt printers and other point of sale devices • Connect, monitor and control industrial/automotive sensors and other sensitive equipment • Connect and program LED and digital signage boards Features • USB to Straight-Through RS232 DB9 Serial Adapter • High-speed 921.6Kbps Baud Rate • Compatible with Windows 8 and later, Mac OS, and Linux • Compatible with USB 1.1 or higher ports • USB-powered - no external power adapter required • Single cable, small footprint design for portability Hardware Warranty 3 Years Ports 1 Interface Serial Bus Type USB 2.0 Port Style Cable Adapters Industry Standards USB 1.1/2.0 RS232 Chipset ID Prolific - PL2303RA Serial Protocol RS-232 Max Baud Rate 921.6 Kbps Data Bits 5, 6, 7, 8 FIFO 512 Bytes Flow Control None, Xon/Xoff, RTS/CTS, DTR/DSR Parity Odd, Even, Mark, Space, or None Parity Modes Stop Bits 1, 1.5, 2 MTBF 30,000 Hours Connector A USB Type-A (4 pin) USB 2.0 Performance Connector(s) Connector B DB-9 (9 pin, D-Sub) OS Compatibility Windows 2000, XP, Vista, 7, 8, 8.1, 10 Software Windows Server 2003, 2008 R2, 2012, 2012 R2, 2016, 2019 macOS 9.x, 8.x, 10.6 to 10.15, 11.0 Linux 2.4.31 to 4.11.x LTS Versions Only Microsoft WHQL Certified Yes Special Notes / Requirements System and Cable Requirements One available USB 1.1 (or above) port Operating Temperature 0C to 60C (32F to 140F) Storage Temperature -20C to 80C (-4F to 176F) Humidity 0~65% RH Color Black Material Plastic Product Length 16.9 in [43.0 cm] Product Width 1.4 in [35.0 mm] Product Height 0.8 in [20.0 mm] Weight of Product 1.4 oz [40.0 g] Package Length 8.7 in [22.0 cm] Package Width 7.9 in [20.0 cm] Package Height 0.8 in [21.0 mm] Shipping (Package) Weight 2.0 oz [56.0 g] Environmental Physical Characteristics Packaging Information What's in the Box Included in Package USB to RS232 Adapter Instruction Manual *Product appearance and specifications are subject to change without notice.
ICUSB232V2 价格&库存
很抱歉,暂时无法提供与“ICUSB232V2”相匹配的价格&库存,您可以联系我们找货
ICUSB232V2
  • 1+247.03705
库存:474
