6.6 ft. (2 m) USB-C to DisplayPort 1.4 Cable - BiDirectional
Product ID: CDP2DP142MBD
This USB-C™ to DisplayPort™ 1.4 cable lets you connect your USB Type-C™ (or Thunderbolt 3™) device to
a DisplayPort display, or a DP device to a USB-C display with just one cable.
Unparalleled Performance with Support for 8K 30Hz
Supporting four times the resolution of 4K, this 8K DP 1.4 adapter cable delivers the stunning quality of
UHD at resolutions up to 7680×4320, and also features HBR3 functionality, providing a bandwidth of up
to 32.4Gbps.
The video cable is backward compatible with 4K and 1080p displays, which makes it a great accessory for
home, office or other work environments, while future-proofing for 8K implementation.
www.startech.com
1 800 265 1844
Easy & Clutter-Free Installation
At 6.6 ft. (2 m) in length, this bidirectional adapter cable delivers a direct connection that eliminates excess
adapters and cabling, ensuring a tidy, professional installation. For shorter installations, we also offer
a 3.3 ft. (1 m) USB-C to DP cable, enabling you to choose the right cable length for your custom installation
needs.
Convenient, Bi-Directional Support
Use this USB-C to DisplayPort adapter cable to output 8K video and audio to a DP display from the USB
Type-C (or Thunderbolt 3) port on your laptop or mobile device. With bi-directional capabilities,
this cable can also connect your DisplayPort-enabled devices to a display featuring USB-C input. For added
convenience, the cable supports both Mac & Windows operating systems.
CDP2DP142MBD is backed by a StarTech.com 3-year warranty and free lifetime technical support.
Note:
Your USB 3.1 Type-C device must support DP Alt Mode to work with this cable.
To achieve 8K resolutions, your source and your destination must support DisplayPort 1.4.
www.startech.com
1 800 265 1844
Certifications, Reports
and Compatibility
Applications
Stream 8K video to a DisplayPort 1.4 screen or monitor
Ultimate accessory for early adopters of 8K technology
Deliver eye-catching presentations while you’re on the go
Perfect for creative professionals
Features
Versatile, bi-directional support lets you connect either your USB
Type-C (or DisplayPort) device to a DisplayPort (or USB-C) display
High Bit Rate 3 (HBR3) capabilities, providing bandwidths up to
32.4Gbps
Cutting-edge video quality with support for UHD video resolutions up
to 8K 30Hz
Compatible with Thunderbolt 3 and USB 3.1 Type-C ports that
support DP Alt Mode
Reduce clutter with an adapter and display cable, in-one
Latching DisplayPort connector ensures a secure connection
www.startech.com
1 800 265 1844
Hardware
Warranty
3 Years
Active or Passive Adapter
Active
Audio
Yes
AV Input
USB-C
DisplayPort - 1.4
AV Output
DisplayPort
USB-C
Chipset ID
Chrontel - CH7213C-BF
Texas Instruments - TUSB544
VIA Labs - VL170
Performance
Connector(s)
Audio Specifications
DisplayPort - 7.1 Channel Audio
USB-C - 7.1 Channel Audio
Bandwidth
HBR3
Maximum Digital Resolutions
DisplayPort: 7680x4320 (8K) / 30Hz
USB-C: 7680x4320 (8K) / 30Hz
Video Revision
DisplayPort 1.4
Wide Screen Supported
Yes
Connector A
1 - USB-C (24 pin) DisplayPort Alt Mode Male Input
1 - Thunderbolt™ 3 USB-C (24-pin) (40Gbps) Male Input
Special Notes /
Requirements
Connector B
1 - DisplayPort (20 pin) Male Output
System and Cable Requirements
Your USB-C device must support DisplayPort Alt Mode to
Environmental
Physical
Characteristics
Humidity
10%-85% RH
Operating Temperature
0°C to 45°C (32°F to 113°F)
Storage Temperature
-10°C to 70°C (14°F to 158°F)
Color
Black
Material
Plastic
Product Height
10.000
Product Length
78.7 in [200 cm]
Product Width
20.000
Weight of Product
79.000
www.startech.com
1 800 265 1844
Packaging
Information
What's in the Box
Package Height
25.000
Package Length
225.000
Package Width
125.000
Shipping (Package) Weight
85.000
Included in Package
1 - 2 m USB-C to DisplayPort 1.4 Bi-Directional Adapter
Cable
Product appearance and specifications are subject to change without notice.
www.startech.com
1 800 265 1844
很抱歉,暂时无法提供与“CDP2DP142MBD”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+182.995811+23.68690
