CDP2DP2MBD
CDP2DP2MBD
    STARTECH
    STARTECH - CDP2DP2MBD - Audio / Video Cable Assembly, USB Type C Plug, DisplayPort Plug, 6.6 ft, 2 m...
CDP2DP2MBD 数据手册
6.6 ft. (2 m) USB-C to DisplayPort 1.2 Cable - BiDirectional Product ID: CDP2DP2MBD This USB-C™ to DisplayPort™ 1.2 cable lets you connect your USB Type-C™ (or Thunderbolt 3™) device to a DisplayPort display, or a DP device to a USB-C display with just one cable. Easy & Clutter-Free Installation At 6.6 ft. (2 m) in length, this bidirectional adapter cable delivers a direct connection that eliminates excess adapters and cabling, ensuring a tidy, professional installation. For shorter installations, we also offer a 3.3 ft. (1 m) USB-C to DP cable, enabling you to choose the right cable length for your custom installation needs. As well, the cable works with both Mac and Windows devices and allows for plug-and-play installation, removing the need for any additional software or drivers. www.startech.com 1 800 265 1844 Convenient, Bi-Directional Support Use this USB-C to DisplayPort adapter cable to output 4K video and audio to a DP display from the USB Type-C (or Thunderbolt 3) port on your laptop or mobile device. With bi-directional capabilities, this cable can also connect your DisplayPort-enabled devices to a display featuring USB-C input. Ultra HD 4K Resolution at 60Hz This USB-C to DP 1.2 adapter cable lets you harness the video capabilities that are built into your computer's USB Type-C (or DisplayPort) connection, to deliver the astonishing quality of UHD to your 4K display. For even higher resolution and bandwidth support, we offer a USB-C to DP 1.4 cable, which is the perfect accessory for early adopters of 8K. CDP2DP2MBD is backed by a StarTech.com 3-year warranty and free lifetime technical support. Note: Your USB 3.1 Type-C device must support DP Alt Mode to work with this cable. www.startech.com 1 800 265 1844 Certifications, Reports and Compatibility Applications • • • Ideal for home, office or hot-desk applications Perfect accessory for creative professionals Deliver enriched presentations on the go • Stream, view and edit 4K video Features • Versatile, bi-directional support lets you connect either your USB Type-C (or DisplayPort) device to a DisplayPort (or USB-C) display • Compatible with Thunderbolt 3 and USB 3.1 Type-C ports that support DP Alt Mode Reduce clutter with an adapter and display cable, in-one Enjoy astonishing picture quality with support for 4K 60Hz Latching DisplayPort connector ensures a secure connection • • • www.startech.com 1 800 265 1844 Hardware Warranty 3 Years Active or Passive Adapter Active Audio Yes AV Input USB-C DisplayPort - 1.2 AV Output DisplayPort USB-C Chipset ID Chrontel - CH7213C-BF VIA Labs - VL170 Performance Connector(s) Audio Specifications DisplayPort - 7.1 Channel Audio USB-C - 7.1 Channel Audio Supported Resolutions DisplayPort: 3840x2160 (4K) / 60Hz USB-C: 3840x2160 (4K) / 60Hz Video Revision DisplayPort 1.2 Wide Screen Supported Yes Connector A 1 - USB-C (24 pin) DisplayPort Alt Mode Male Input 1 - Thunderbolt™ 3 USB-C (24-pin) (20Gbps) Male Input Special Notes / Requirements Environmental Physical Characteristics Packaging Information Connector B 1 - DisplayPort (20 pin) Male Output Note Maximum performance is dependent upon the specifications of your video source and destination System and Cable Requirements Your USB-C device must support DisplayPort Alt Mode to work with this cable Humidity 10%-85% RH Operating Temperature 0°C to 45°C (32°F to 113°F) Storage Temperature -10°C to 70°C (14°F to 158°F) Color Black Material Plastic Product Height 10.000 Product Length 80.2 in [203.8 cm] Product Width 220.000 Weight of Product 77.000 Package Height 12.000 www.startech.com 1 800 265 1844 What's in the Box Package Length 124.000 Package Width 226.000 Shipping (Package) Weight 84.000 Included in Package 1 - 2 m USB-C to DisplayPort 1.2 Bi-Directional Adapter Cable Product appearance and specifications are subject to change without notice. www.startech.com 1 800 265 1844
CDP2DP2MBD 价格&库存
很抱歉,暂时无法提供与“CDP2DP2MBD”相匹配的价格&库存,您可以联系我们找货
CDP2DP2MBD
  • 1+353.708931+45.90497
  • 10+300.6493810+39.01881
  • 25+281.8306825+36.57648
  • 50+268.3853050+34.83152
  • 100+255.58630100+33.17044
  • 250+239.60547250+31.09642
库存:171
CDP2DP2MBD
  • 1+290.05661
库存:2
