USB C Multiport Adapter - USB-C Mini Travel Dock
w/ 4K HDMI or 1080p VGA - 3x USB 3.0 Hub, SD
Card Reader, GbE, Audio, 100W PD - Portable
Docking Station for Laptop/Tablet
Product ID: DKT30CHVAUSP
This USB-C multiport adapter turns your MacBook Pro, USB-C™ laptop, Chromebook or Android (Samsung
Galaxy S8, Note 9 and above) device into a workstation, anywhere you go. A USB Type-C adapter, ideal
for travel, features everything from the essential HDMI or VGA video outputs and USB ports to an SD card
reader and 100W PD including PD passthrough. All through a single extended length 30 cm Thunderbolt 3
or USB-C attached host cable, providing more flexibility for harder to reach laptop and tablet connections.
Two Video Output Options with HDMI or VGA
This USB-C multiport adapter features both an HDMI and VGA port providing you with two single video
output options for your boardroom presentations or your workstation setup including support for an ultrawide monitor.
www.startech.com
1 800 265 1844
Power & Charge with 100W Power Delivery 3.0
With support for USB PD 3.0 (up to 100W), the USB Type-C multiport adapter lets you power and charge
your laptop, and power your peripherals when connected to a USB-C power adapter. The USB-C
hub features PD passthrough so you can use your laptop’s own charger to power the hub (requires
15W) and power or charge your laptop simultaneously.
All the Essential Ports with USB
The USB-C to USB 3.0 hub gives you one USB-C port (power & data) and two USB-A ports to connect
your latest and legacy USB devices.
Includes Ports to Do More with SD, Audio & Gigabit Ethernet
Access your multimedia content, audio, and network with ease. The multiport adapter provides direct
access to your:
SD, SDHC™ and SDXC™ memory cards or microSD cards via the SD card slot
Audio content via headphones or microphone through the 3.5mm 4- position audio port
Ethernet network via the GbE port using a hard-wired connection
DKT30CHVAUSP is backed by a StarTech.com 3year warranty and free lifetime technical support.
www.startech.com
1 800 265 1844
Certifications, Reports
and Compatibility
Applications
Seamlessly create a familiar and productive workstation wherever
you travel
Creative professionals can use the built-in card reader to access
multimedia
Features
8-IN-1 MULTI PURPOSE DOCK: USB-C multiport adapter eliminates
the need for multiple adapters w/ 4K30Hz HDMI or 1080p VGA,
5Gbps USB (2x USB-A, USB-C), SD slot, Gigabit Ethernet,
headset/mic audio jack
100W POWER DELIVERY 3.0: Use your laptop’s USB-C power adapter
to power the dock and provide up to 85W to power & charge your
laptop, w/ 15W always reserved for the USB type-c travel dock hub
EXTRA LONG CABLE: 1ft (30cm) attached cable on this usb-c mini
dock for extended reach to reduce port/connector strain on 2-in-1
devices like Surface Pro 7, iPad Pro, HP Elite & laptop on riser stands
WIDE DEVICE COMPATIBILITY: Compatible w/ USB-C & Thunderbolt
3 laptops, tablets, or smartphones, this portable USB-C docking
station works w/ HP, Lenovo, Dell, MacBook, Chromebook &
Samsung Galaxy
WIDE OPERATING SYSTEM COMPATIBILITY: With automatic driver
setup, this all-in-one USB-C multiport adapter supports all major
operating systems, including Windows, macOS, ChromeOS, iPadOS
and Android
www.startech.com
1 800 265 1844
Hardware
Warranty
3 Years
4K Support
Yes
Audio
Yes
Bus Type
USB 3.1 Gen 1
Chipset ID
VIA Labs - VL102
VIA Labs - VL161
VIA Labs - VL817
Genesys Logic - GL823K
ITE Tech - IT6564
Realtek - RTL8153B
Cmedia - HS100-B
Performance
Connector(s)
Displays Supported
1
Fast-Charge Port(s)
No
Port Style
Cable Adapters
Ports
7
Audio Specifications
3.5mm Audio
Compatible Networks
10/100/1000 Mbps
Maximum Analog Resolutions
1920 x 1200 @ 60Hz (VGA)
Maximum Cable Length
11.8 in [30 cm]
Maximum Digital Resolutions
3840 x 2160 @30Hz, 4096 x 2160 @24hz, 3440 x 1440
@60Hz (HDMI)
MTBF
372518 hours
Power Reservation
15W
Type and Rate
USB 3.1 Gen 1 - 5 Gbit/s
External Ports
1 - HDMI Receptacle
1 - VGA (15 pin, High Density D-Sub) Receptacle
1 - RJ-45 Receptacle
2 - USB 3.1 USB Type-A (9 pin, Gen 1, 5 Gbps) Receptacle
1 - SD Slot Receptacle
1 - 3.5 mm Audio Receptacle Input
1 - 3.5 mm Audio Receptacle Output
1 - USB Type-C (24 pin) USB 3.0 (5Gbps) Receptacle
www.startech.com
1 800 265 1844
Power
Environmental
Physical
Characteristics
Packaging
Information
What's in the Box
Host Connectors
1 - USB Type-C (24 pin) USB 3.0 (5Gbps) Plug
Power Delivery
100W
Power Source
Not Included (not required for standard applications)
Humidity
5%~90%
Operating Temperature
0~45°C
Storage Temperature
-10~82°C
Cable Length
11.8 in [30 cm]
Color
Black & Space Gray
Material
Aluminum and Plastic
Product Height
116.000
Product Length
0.6 in [1.5 cm]
Product Width
60.000
Weight of Product
114.000
Package Height
30.000
Package Length
170.000
Package Width
142.000
Shipping (Package) Weight
0.3 lb [0.1 kg]
Included in Package
1 - USB-C Docking Station
1 - Quick-Start Guide
Product appearance and specifications are subject to change without notice.
www.startech.com
1 800 265 1844
很抱歉,暂时无法提供与“DKT30CHVAUSP”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+538.911071+69.77287
- 10+478.0777610+61.89677
- 25+455.8323125+59.01665
- 50+439.7011450+56.92815
- 100+424.14252100+54.91377
