DVIVGAMF8IN
DVIVGAMF8IN
    STARTECH
    STARTECH - DVIVGAMF8IN - Connector Adapter, DVI-I, 29 Ways, Plug, VGA, 8 Ways, Receptacle
DVIVGAMF8IN 数据手册
8in DVI to VGA Cable Adapter - DVI-I Male to VGA Female StarTech ID: DVIVGAMF8IN The DVIVGAMF8IN DVI to VGA Cable (8-inch) is used to adapt a DVI Male connector to a VGA female connector and enables you to connect a Flat Panel Display to a PC or MAC® computer with DVI-I output. The VGA female connection added by the dongle is situated approximately 8 inches away from the DVI output connection, which lessens strain on and prevents damage to the DVI connector while reducing the potential of blocking other available ports. The DVI male to VGA female adapter is constructed of high quality materials to ensure dependability, and is backed by StarTech.com's lifetime warranty. Please Note: This product is intended for connections between DVI-I and VGA devices. If your device uses a DVID connector, please refer to StarTech.com's High Resolution Video DVI to VGA Converter DVI2VGACON. Applications Connect a VGA display to a DVI-I video card Features DVI-I (Male) to VGA (Female) Connectors Offers 8” in cable length uk.startech.com 0800 169 0408 Technical Specifications Warranty Lifetime Cable Jacket Type PVC - Polyvinyl Chloride Cable Shield Type Aluminum-Mylar Foil with Braid Connector Plating Nickel Connector A 1 - DVI-I (29 pin) Male Connector B 1 - VGA (15 pin; High Density D-Sub) Female Cable Length 203.2 mm [8 in] Product Length 203.2 mm [8 in] Product Weight 0.1 kg [0.2 lb] Wire Gauge 28 AWG Color Black Package Quantity 1 Shipping (Package) Weight 0.1 kg [0.2 lb] Included in Package 1 - 8in DVI to VGA Cable Adapter - M/F Certifications, Reports and Compatibility uk.startech.com 0800 169 0408
DVIVGAMF8IN 价格&库存
很抱歉,暂时无法提供与“DVIVGAMF8IN”相匹配的价格&库存,您可以联系我们找货
