HB30C5A2CSC
HB30C5A2CSC
    STARTECH
    STARTECH - HB30C5A2CSC - Hub, USB-C, 7 Ports, 5 Gbps, Mains Powered
HB30C5A2CSC 数据手册
7 Port USB C Hub with Fast Charge Port - USB-C to 5x USB-A 2x USB-C (USB 3.0 SuperSpeed 5Gbps) - Self Powered USB 3.1 Gen 1 Type-C Hub w/ Power Adapter - Desktop/Laptop Hub Product ID: HB30C5A2CSC This USB-C hub turns your laptop or desktop USB Type-C or Thunderbolt 3 port into four standard USB-A ports, one USB-A fast-charge port, and two USB-C ports. You can also extend the range of your USB devices by using this hub as a mid-point repeater. The 7-port USB hub provides convenient port access. The extended length of the supplied cable offers the flexibility to position your hub and USB devices as needed, in order to create a comfortable, space-efficient work area. The ports are sufficiently spaced to plug or unplug your USB devices without needing to disconnect other devices from neighboring ports. With extra USB 3.0 ports, you can increase productivity and connect more devices to your computer, or avoid the hassle of swapping connected devices on your port-limited laptop. The hub lets you extend the life of your current USB 3.0 devices while also taking advantage of newer USB-C devices. With the available fast-charge port, the hub helps to ensure that your tablet or smartphone are charged and ready to use when you need them. You can also sync and access your device while it's charging. The USB-A charge port supports USB Battery Charging Specification 1.2. The HB30C5A2CSC is backed by a 2-year StarTech.com warranty and free lifetime technical support. Certifications, Reports and Compatibility Applications • Upgrade and expand the connection capabilities of your MacBook, Ultrabook, laptop, or desktop • Deploy in hot-desk environments to provide USB hub access for multiple devices • Connect a wide variety of peripherals at home or in the office, all from a single USB 3.0 connection Features • 7 PORT USB C HUB: From a USB 3.0 (Gen 1) 5Gbps Type-C host port, add 5x USB-A and 2x USB-C ports; Backwards compatible with USB 2.0/1.1; Includes 3.3ft (1m) USB-C host cable; Thunderbolt 3 Compatible • SELF-POWERED USB HUB: Includes external 12V 4A universal power adapter (NA, EU, UK, JP, AU/NZ) & a dedicated power switch for easy power toggling of all connected downstream devices to conserve energy • SPEEDS UP TO 5Gbps: USB 3.0 SuperSpeed 5Gbps (USB 3.1 Gen 1 / USB 3.2 Gen 1) shared with all downstream devices, supports thumb drives, data storage devices, keyboards, mice, web cams, headsets • FAST CHARGE PORT WITH BC 1.2: Power up to 1.5A (7.5W) features a standalone Dedicated Charging Port (DCP) for hostless charging or works as a Charging Downstream Port (CDP) for data and charging • WIDE OPERATING SYSTEM COMPATIBILITY: USB C laptop/desktop hub is OS Independent, driverless setup, supporting major operating systems including Windows, macOS, Linux, iPadOS, Chrome OS and Android Hardware Warranty 2 Years USB-C Device Port(s) Yes USB-C Host Connection Yes Ports 7 Interface USB 3.0 Bus Type USB 3.0 Industry Standards USB Battery Charging Specification Rev. 1.2 USB-A charging port delivers up to 1.5 amps of power USB 3.0 - Backward compatible with USB 2.0 and 1.1 Chipset ID VIA/VLI - VL813 Maximum Data Transfer Rate 5 Gbps Type and Rate USB 3.0 - 5 Gbit/s UASP Support Yes Performance Supported Charging Modes Charging Downstream Port (CDP) Dedicated Charging Port (DCP) Supported Charging Outputs BC 1.2 (1.5A) Connector Type(s) USB Type-A (9 pin) USB 3.0 (5 Gbps) Connector(s) USB Type-C (24 pin) USB 3.0 (5Gbps) USB 3.0 A (Fast-Charge, 9 pin) USB Type-B (9 pin) USB 3.0 Software OS Compatibility OS Independent; No additional drivers or software required System and Cable Requirements Available USB Type-C port - USB 3.0 (5Gbps) Note The USB Type-C ports are data only. Special Notes / Requirements USB 3.0 is also known as USB 3.1 Gen 1; this connectivity standard offers speeds up to 5Gbps. The hub does not support DP Alt Mode or USB Power Delivery. Indicators LED Indicators Active Power Source AC Adapter Included Input Voltage 100 - 240 AC Input Current 1A Output Voltage 12V DC Output Current 4A Center Tip Polarity Positive Plug Type M Power Power Consumption (In Watts) 48 Operating Temperature 0C to 50C (32F to 122F) Storage Temperature -20C to 70C (-4F to 158F) Humidity 0~95% RH (Non-condensing) at 25C Color Black & Silver Form Factor Desktop Material Plastic Cable Length 39.4 in [100 cm] Product Length 5.9 in [14.9 cm] Product Width 2.6 in [65 mm] Product Height 0.9 in [24 mm] Weight of Product 5.3 oz [150 g] Package Length 8.4 in [21.3 cm] Package Width 5.9 in [14.9 cm] Package Height 2.0 in [51 mm] Shipping (Package) Weight 19.4 oz [550 g] Included in Package USB-C hub Environmental Physical Characteristics Packaging Information What's in the Box 1m USB-C to USB-B cable universal power adapter (NA/JP, UK, EU, ANZ) quick-start guide *Product appearance and specifications are subject to change without notice.
HB30C5A2CSC 价格&库存
很抱歉,暂时无法提供与“HB30C5A2CSC”相匹配的价格&库存,您可以联系我们找货
HB30C5A2CSC
  • 1+877.99061
库存:13
