USB C to DisplayPort Adapter - 8K/4K 60Hz USB-C to DisplayPort 1.4 Adapter Dongle - USB
Type-C to DP Monitor Video Converter - Works w/Thunderbolt 3 - w/12" Long Attached Cable
Product ID: CDP2DPEC
This USB-C to DisplayPort adapter enables you to output DP video and audio from the USB Type-C port on your
laptop, tablet, smartphone or other USB C device.
This USB C adapter is equipped with an extra-long 12" (30cm) attached cable, providing an extended reach to reduce
port and connector strain on 2-in-1 devices or laptops on risers stands.
The adapter lets you harness the video capabilities that are built into your computer's USB Type-C connection, to
deliver the astonishing quality of UHD to your 4K 60Hz display. This makes it easier for you to multitask while working
on the most resource-demanding applications imaginable.
With this adapter, you can also achieve an output resolution of up to 7680x4320 at 60Hz (with a laptop supporting DP
1.4 and DSC) or 7680x4320 at 30Hz (without DSC), which is perfect for performing high-resolution tasks such as
viewing 8K video. Plus, the DP 1.4 adapter is backward compatible with 1080p displays, which makes it a great
accessory for home, office or other workspace applications while future-proofing for 8K implementation.
This USB Type-C video adapter is highly portable with a small footprint and lightweight design that's easy to tuck into
your laptop bag while commuting between your home, office or traveling for business.
The CDP2DPEC is backed by a 3-year StarTech.com warranty and free lifetime technical support.
Certifications, Reports and Compatibility
Applications
• Connect to virtually any 8K or 4K DisplayPort monitor when you're in the office or traveling
• Connect your USB-C equipped tablet or smartphone to a larger display
Features
• HIGH PERFORMANCE: USB C to DisplayPort 1.4 adapter connects a single DP display supporting up to 8K 60Hz
with DSC (8K 30Hz without DSC) & 4K 60Hz UHD (3840x2160) DP Alt Mode HBR3 32.4Gbps 2ch Audio HDCP
2.2/1.4 Backward compatible w/ 1080p
• EXTRA LONG CABLE: USB-C to DisplayPort display adapter with 12" (30cm) attached cable for extended reach to
reduce port/connector strain on 2-in-1 devices like Surface Pro 7, iPad Pro & laptops on risers stands Compact,
portable design
• DEVICE COMPATIBILITY: Works w/ Dell XPS, Precision, Latitude, Lenovo ThinkPad X1 Carbon, Extreme, Surface
Laptop 3, Pro 7, MacBook Pro/Air (Intel Processor & M1 Chip), HP EliteBook, Chromebook Requires Intel 11th Gen
w/DSC (or later) for DP 1.4 8K 60Hz
• DISPLAY COMPATIBILITY: USBC to DP external video adapter/converter has been tested for peak performance at
8K/4K 60Hz on a range of DP monitors incl. brands like Dell UltraSharp, Samsung, Asus ProArt, Acer & LG Supports
ultrawide displays (3440x1440)
• EASY TO USE: USB-C to DP adapter dongle supports driverless setup and is OS independent; Works w/any USB
Type-C (DisplayPort over USB-C) or Thunderbolt 3 (TB3) device Recommend using a StarTech.com DisplayPort 1.4
cable (DP14MM2M) to support DSC 8K 60Hz
Hardware
Warranty
3 Years
Chipset ID
VL103
Maximum Cable Distance
To Display
6.6 ft [2 m]
Video Revision
DisplayPort 1.4
Supported Resolutions
DisplayPort: 7680x4320 (8K) / 60Hz
Wide Screen Supported
Yes
Audio Specifications
DisplayPort - 2 Channel Audio
Connector A
USB-C (24 pin) DisplayPort Alt Mode
Connector B
DisplayPort (20 pin)
System and Cable
Your USB-C port must support DisplayPort over USB-C (DP Alt
Performance
Connector(s)
Special Notes /
Requirements
Requirements
mode) in order to work with this adapter.
Operating Temperature
0C to 45C (32F to 113F)
Storage Temperature
-10C to 70C (14F to 158F)
Humidity
10%-85% RH
Color
Gray
Material
Plastic
Cable Length
12.3 in [31.2 cm]
Product Length
15.4 in [39.0 cm]
Product Width
1.5 in [38.0 mm]
Product Height
0.6 in [15.0 mm]
Weight of Product
0.9 oz [26.0 g]
Package Length
8.7 in [22.0 cm]
Package Width
7.9 in [20.0 cm]
Package Height
0.7 in [18.0 mm]
Shipping (Package)
Weight
1.1 oz [32.0 g]
Included in Package
USB-C to DisplayPort Adapter
Environmental
Physical
Characteristics
Packaging
Information
What's in the Box
*Product appearance and specifications are subject to change without notice.
很抱歉,暂时无法提供与“CDP2DPEC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+218.069851+28.32617
- 10+193.4241810+25.12482
- 25+184.4195425+23.95517
- 50+177.8879050+23.10674
- 100+171.59095100+22.28880
- 250+163.60944250+21.25204
- 500+157.82063500+20.50010
