1 Port USB to Null Modem RS232 DB9 Serial DCE Adapter Cable with FTDI
StarTech ID: ICUSB232FTN
The ICUSB232FTN FTDI USB to Null Modem Serial Adapter Cable (1-Port) converts an available USB 1.1 or 2.0
port into an RS232 Null Modem serial DB9 port, solving DCE/DTE conflicts directly, without requiring additional
cross-wired serial cables or adapters.
This compact adapter features COM retention, allowing the same COM port value to automatically be re-assigned
to the port if the cable is disconnected and re-connected to the host computer, or if the system is rebooted. The
integrated FTDI chipset supports additional customization, advanced features, and compatibility not necessarily
offered by other solutions.
The USB to Null Modem adapter is compatible with a broad list of operating systems including Windows®,
Windows CE, Mac OS and Linux, making it easier to integrate into mixed environments.
Backed by a StarTech.com 2-year warranty and free lifetime technical support.
Applications
Perfect for IT Administrators looking to add legacy functionality to newer notebooks, PCs and servers that
lack an integrated RS232 port
Connect, monitor and control industrial/automotive sensors and equipment
Connect bar code scanners, receipt printers and other point of sale devices
Connect and program LED and Digital signage boards with serial communication ports
Connect a satellite receiver, serial modem, or PDU
Features
USB to Null Modem (Cross-Wired) RS232 Serial Adapter
Integrated FTDI USB UART Chip
Baud Rate up to 921.6Kbps
COM Port assignments maintained across reboot
USB-powered - no external power adapter required
Compatible with USB 1.1 or 2.0 Ports
Compatible with Windows®, Mac OS and Linux
Single cable design for portability
Technical Specifications
Warranty
Interface
Port Style
Ports
Bus Type
Chipset ID
Connector Type(s)
Connector Type(s)
Serial Protocol
Max Baud Rate
Data Bits
FIFO
Parity
Stop Bits
OS Compatibility
System and Cable
Requirements
Color
Enclosure Type
Cable Length
Product Length
Product Width
Product Height
Product Weight
Humidity
Operating Temperature
Storage Temperature
Shipping (Package) Weight
Included in Package
Included in Package
Included in Package
2 Years
Serial
Cable Adapter
1
USB 2.0
FTDI - FT232RL
1 - DB-9 (9 pin; D-Sub) Female
1 - USB A (4 pin) Male
RS-232
921.6 Kbps
7, 8
256 Bytes
None, Odd, Even, Mark, Space
1, 2
Windows® 8 (32/64bit), 7 (32/64), Vista (32/64), XP (32/64), 2000, 98SE, XP
Embedded, CE (4.2+)
Windows® Server 2012, 2008 R2, 2003 (32/64)
Mac OS® 10.x (Tested up to 10.9)
Linux 2.4.x / 2.6.x
One available USB 1.1 (or better) port
Black
Plastic
1 m [3.3 ft]
179 mm [7 in]
33.5 mm [1.3 in]
16.5 mm [0.6 in]
88 g [3.1 oz]
5~95% RH
0°C to 55°C (32°F to 131°F)
-20°C to 85°C (-4°F to 185°F)
0.2 kg [0.5 lb]
1 - USB to RS-232 Null Modem Adapter
1 - Driver CD
1 - Instruction Manual
Certifications, Reports and Compatibility
很抱歉,暂时无法提供与“ICUSB232FTN”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+449.29196
- 5+435.07769
- 10+420.85155
- 25+401.28617
- 50+387.07190
- 100+373.37969
