HB31C2A1CGS
HB31C2A1CGS
    STARTECH
    STARTECH - HB31C2A1CGS - Hub, 3 Port, USB 3.1, 1 m Cable, Bus Powered
HB31C2A1CGS 数据手册
3-Port USB-C Hub with LAN Port - 10 Gbps - 2x USBA & 1x USB-C - Powered Product ID: HB31C2A1CGS Expand the connectivity of your USB-C laptop with this new generation USB-C 3.1 Gen 2 hub offering 10Gbps supporting greater bus bandwidth to connected devices and faster data transfer speeds. This selfpowered 3-Port USB-C hub plugs into the USB Type-C™ or Thunderbolt™ 3 port on your device, adding one LAN port, one USB-C port, and two USB-A ports, so you can quickly connect more USB devices.   Gigabit Network Access  For faster and more consistent network connections, the USB 3.1 Gen 2 hub’s integrated Gigabit Ethernet port provides wired network access that is fully compatible with IEEE 802.3/u/ab standards. The GbE port also supports Wake-on-LAN (WoL), so you can remotely wake your computer over your network.  www.startech.com 1 800 265 1844 Easy Setup & Installation This compact, lightweight USB-Type-C hub is a convenient and compact addition to your laptop setup. The hub is self-powered and includes a universal power adapter to provide better support of USB devices, such as external storage, that may draw more power. The USB-C host cable is detached and with an extended length of 3.3’ (1 m), it provides more flexibility for longer reach connection requirements and plug and play installation.   For added flexibility and security, the mini hub features mounting holes to work with StarTech.com dock mounts such as SSPMSVESA or SSPMSUDWM. Connect USB-C & USB-A Peripherals  With ports for both USB-C and USB-A peripherals, this hub is backwards compatible supporting both legacy and new USB devices. It features one always-on USB-A fast charge port which supports two modes of operation: •1. Data transfer and charging when the laptop is connected and on •2. Dedicated or hostless charging which provides a higher charging current, when the host is off, on standby, or disconnected You can connect video capture devices, portable flash drives, and external hard drives, with fast data transfer speeds of up to 10 Gbps. This 3 port USB Type-C hub enhances your productivity, giving you the connections you need while you work or travel. The IT Pro’s Choice Since 1985 StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales. HB31C2A1CGS is backed by a StarTech.com 2-year warranty and free lifetime technical support.  www.startech.com 1 800 265 1844 Certifications, Reports and Compatibility Features • Adds one USB-C, two USB-A ports (including one fast-charge BC 1.2 port) and a GbE port to your Mac, Windows, Linux or other USB Type C™ laptop’s and USB-C enabled tablets • USB 3.1 Gen 2 hub is self-powered with included universal power adapter Mountable with StarTech.com dock mounts for flexible wall and desktop installations USB Type-C hub supports USB 3.1 Gen 2 data transfer rates up to 10Gbps • • • • Compact design with an extended host cable of 3.3’ (1 m) to accommodate a variety of setups Plug-and-play installation with no drivers required www.startech.com 1 800 265 1844 Hardware Performance Warranty 2 Years Bus Type USB 3.1 Gen 2 Chipset ID Realtek - RTL5428 Realtek - RTL8153B Industry Standards USB 3.2 Gen 2 - Backwards compatible with USB 3.0, 2.0, and 1.1 Interface USB 3.1 Gen 2 Ports 3 USB Pass-Through Yes USB-C Device Port(s) Yes USB-C Host Connection Yes Auto MDIX Yes Compatible Networks 10/100/1000 Mbps Full Duplex Support Yes Maximum Data Transfer Rate 10 Gbps Port Multiplier Yes Supported Charging Modes Charging Downstream Port (CDP) Dedicated Charging Port (DCP) Supported Charging Outputs BC 1.2 (1.5A) Apple 1A Apple 2.4A Connector(s) Type and Rate USB 3.1 Gen 2 - 10 Gbit/s UASP Support Yes Connector Type(s) 1 - USB 3.1 USB Type C (10 pin, Gen 2, 10 Gbps) Receptacle 1 - USB 3.1 USB Type C (10 pin, Gen 2, 10 Gbps) Receptacle 2 - USB 3.1 USB Type-A (9 pin, Gen 2, 10 Gbps) Receptacle 1 - RJ-45 Receptacle www.startech.com 1 800 265 1844 Software OS Compatibility Windows® 10 (32/64 bit) Windows® 8.1 (32/64bit) Windows® 7 (32/64bit) Windows® Server 2008 R2 Windows® Server 2012(32/64bit) Windows® Server 2016 Windows® Server 2019 Mac OS 10.10-10.15 Linux Kernel 4.x LTS and up Ubuntu 14.x LTS - 19.x LTS iPadOS 13.1 and up Chrome OS 61.x and up Android OS 8.x and up Indicators LED Indicators 1 - Green - Power and Link Indicator Power Center Tip Polarity Positive Input Current 0.8A Input Voltage 110V-240V AC Output Current 2A Output Voltage 12V DC Plug Type M Power Consumption (In Watts) 24W Power Source AC Adapter Included Humidity 0% to 95% (non-condensing) at 25°C Operating Temperature 0 to 50°C Storage Temperature -20 to 70°C Cable Length 3.3 ft [1 m] Color Black & Space Gray Form Factor Desktop Material Aluminum and Plastic Product Height 25.000 Product Length 3.9 in [10 cm] Product Width 60.000 Weight of Product 0.000 Package Height 51.000 Package Length 149.000 Package Width 213.000 Environmental Physical Characteristics Packaging Information www.startech.com 1 800 265 1844 What's in the Box Shipping (Package) Weight 1 lb [0.5 kg] Included in Package 1 - USB-C Hub 1 - Universal Power Adapter 4 - Power Adapter Clips (NA/JP, UK, EU, ANZ) 1 - USB-C Host Cable (1 m) Product appearance and specifications are subject to change without notice. www.startech.com 1 800 265 1844
HB31C2A1CGS 价格&库存
很抱歉,暂时无法提供与“HB31C2A1CGS”相匹配的价格&库存,您可以联系我们找货
HB31C2A1CGS
    • 1+1026.04746
    库存:2
