DISPL5M
DISPL5M
    STARTECH
    DISPL5M
DISPL5M 数据手册
5m Long DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k Product ID: DISPL5M The DISPL5M DisplayPort™ 1.2 Cable with latches provides a secure connection between your DisplayPort-equipped devices and allows for a connection distance of up to 5-meters between your source and display. The DP cable is capable of providing higher performance than either HDMI® or dual link DVI with support for high resolutions of up to 4k x 2k (4096 x 2160) @ 60Hz and a maximum HBR2 bandwidth of 21.6 Gbps. The cable also supports Multi-Stream (MST) for daisy chaining multiple monitors and provides optional audio support. The DISPL5M long DisplayPort cable is backed by StarTech.com’s Lifetime Warranty, for guaranteed reliability and ensures that digitally protected content is displayed properly, with both HDCP and DPCP capability. www.startech.com/uk 0800 169 0408 Certifications, Reports and Compatibility Applications • Connecting a DisplayPort Display to a PC or other DisplayPort Source Features • • • • • High-resolution support of up to 4k x 2k Support for High Bit Rate 2 (HBR2) bandwidth of up to 21.6 Gbps Backward compatible with DisplayPort 1.1 Designed and manufactured to DisplayPort 1.2 standards Supports the DPCP (DisplayPort Content Protection) standard in • addition to HDCP Molded latching connectors with strain relief www.startech.com/uk 0800 169 0408 Hardware Connector(s) Physical Characteristics Packaging Information What's in the Box Warranty Lifetime Cable Jacket Type PVC - Polyvinyl Chloride Cable Shield Type Aluminum-Mylar Foil with Braid Connector Plating Nickel Fire Rating CMG Rated (General Purpose) Number of Conductors 19 Connector A 1 - DisplayPort (20 pin) Latching Male Connector B 1 - DisplayPort (20 pin) Latching Male Cable Length 5 m [16.4 ft] Cable OD 7.3 mm [0.3 in] Color Black Connector Style Latching Product Length 5 m [16.4 ft] Product Weight 320 g [11.3 oz] Wire Gauge 28 AWG Package Quantity 1 Shipping (Package) Weight 320 g [11.3 oz] Included in Package 1 - 5m Latching DisplayPort Cable Product appearance and specifications are subject to change without notice. www.startech.com/uk 0800 169 0408
DISPL5M 价格&库存
很抱歉,暂时无法提供与“DISPL5M”相匹配的价格&库存,您可以联系我们找货
DISPL5M
    • 1+444.68325
    库存:32
