ICUSB232C
ICUSB232C
    STARTECH
    STARTECH - ICUSB232C - Adapter Cable, USB Type C to RS-232 (DB9) Serial, 921.6 Kbps
ICUSB232C 数据手册
USB C to Serial Adapter Cable 16" (40cm) - USB Type C to RS232 (DB9) Converter Cable - USB-C Serial Cable for PLCs, Scanners, Printers - Male/Male - Windows/Mac/Linux Product ID: ICUSB232C This USB-C to serial adapter lets you connect your USB-C devices to your legacy serial equipment. It converts a USB-C port on your laptop or computer into a RS232 DB9 serial port, giving you a cost-saving way to connect to serial devices such as point-of-sale terminals, serial modems, industrial equipment, and a wide variety of other RS232 peripherals. The RS232 adapter cable is compatible with Windows, macOS and Linux operating systems, which makes it easy to integrate into mixed environments. The USB-C to serial adapter is USB powered, so you don’t need an additional external power supply. It’s a compact solution that’s easy to bring along with your laptop, when you’re on the go. The ICUSB232C is backed by a StarTech.com 2-year warranty and free lifetime technical support. Certifications, Reports and Compatibility Applications • IT administrators looking to add legacy functionality to newer notebooks, PCs and servers that lack an integrated RS232 port • Connect bar code scanners, receipt printers and other point of sale devices • Connect, monitor and control industrial/automotive sensors and other sensitive equipment • Connect and program LED and digital signage boards Features • USB-C TO SERIAL: Interface with Serial RS-232 (DB9) equipment using this black USB Type-C Serial adapter converter cable; Male DB9 connector features screw-lock nuts; Cable length of 16" [40 cm] • TECH SPECS: 921.6 Kbps baud 512 byte FIFO Data bits of 5/6/7/8 and stop bits 1/1.5/2 Parity Modes of None, Xon/Xoff, RTS/CTS, DTR/DSR Flow control options Odd/Even/Mark/Space/None • APPLICATIONS: Using your laptop's USB-C port, control serial equipment such as PLCs, scanners, sensors, oscilloscopes, medical, scales or receipt printers; Use in manufacturing, scientific, automation • HOST COMPATIBILITY: Driverless setup for easy install; Tested on major operating systems, including Windows 7 and up, macOS 10.11 and up, Linux 2.6 and up; USB bus powered • STARTECH.COM ADVANTAGE: IT professionals choice for over 30 years; This RS232 Serial Adapter is backed for 2-years by StarTech.com, including free 24/5 North America based multi-lingual tech support Hardware Warranty 2 Years Ports 1 Interface Serial Bus Type USB-C Port Style Cable Adapters Industry Standards USB 1.1/2.0 RS232 Chipset ID Prolific - PL2303RA Serial Protocol RS-232 Max Baud Rate 921.6 Kbps Data Bits 5, 6, 7, 8 FIFO 512 Bytes Flow Control None, Xon/Xoff, RTS/CTS, DTR/DSR Parity Odd, Even, Mark, Space, or None Parity Modes Stop Bits 1, 1.5, 2 MTBF 30,000 Hours Performance Connector(s) Connector Type(s) USB Type-C (24-pin) USB 2.0 (480Mbps) DB-9 (9 pin, D-Sub) Software OS Compatibility Windows 7, 8.1, 10 Windows Server 2008 R2, 2012 R2, 2016, 2019 macOS 10.11 and 10.15, 11.0, 12.0 Linux 2.6.x to 4.4.x LTS Versions only Microsoft WHQL Certified Yes System and Cable Requirements One available USB-C port Power Source USB-Powered Operating Temperature 0C to 60C (32F to 140F) Storage Temperature -20C to 80C (-4F to 176F) Humidity 0~65% RH Color Black Product Length 16.9 in [43 cm] Product Width 1.2 in [30 mm] Product Height 0.6 in [15 mm] Weight of Product 1.3 oz [36 g] Package Length 8.7 in [22 cm] Package Width 7.9 in [20 cm] Special Notes / Requirements Power Environmental Physical Characteristics Packaging Information Package Height 0.0 in [0.1 mm] Shipping (Package) Weight 1.8 oz [52 g] Included in Package serial adapter cable What's in the Box quick-start guide *Product appearance and specifications are subject to change without notice.
ICUSB232C 价格&库存
很抱歉,暂时无法提供与“ICUSB232C”相匹配的价格&库存,您可以联系我们找货
ICUSB232C
  • 1+288.89026
库存:14
