ICUSBAUDIO7D
ICUSBAUDIO7D
    STARTECH
    STARTECH - ICUSBAUDIO7D - Adapter, Audio, External Sound Card, USB, SPDIF Digital Audio
ICUSBAUDIO7D 数据手册
7.1 USB Audio Adapter External Sound Card with SPDIF Digital Audio StarTech ID: ICUSBAUDIO7D This versatile External USB Sound Card/Audio Adapter offers a high quality solution for upgrading desktop or laptop sound. Providing a robust USB audio experience, the USB sound card connects to a host computer through a single USB 2.0 connection, to deliver impressive external audio capability that can instantly be swapped between systems, without having to open the computer case for installation. Supporting analog and digital audio for 2 to 7.1 channel audio applications, the external USB sound card provides a cost-saving upgrade from built-in/on-board sound that turns desktop/laptop sound into a home theater-ready audio solution. The external USB sound card features easy-to-use volume control and two external microphone inputs - a convenient solution for any audio application requiring high quality sound with multi-input capability with support for 44.1 KHz and 48 KHz sampling rates for both playback and recording. A more than suitable solution for home theater, gaming or multi-media presentations, the External USB Sound Card is easy to install with plug and play support in Windows XP and Windows Vista operating systems. Designed to deliver a long-lasting and dependable sound solution, the External USB Sound Card/Audio Adapter is backed by our 2-year warranty and free lifetime technical support. Applications Add 7.1 audio support to laptop or small form factor system with no internal expansion options Replace or upgrade the existing integrated audio on a laptop or portable computer Connect your computer to an home theater audio receiver through optical S/PDIF uk.startech.com 0800 169 0408 Features Full 7.1 audio outputs via 3.5mm mini-jacks Optical S/PDIF input (pass through) and output Dual microphone input Built-in volume control buttons Full-duplex recording and playback Supports 48/44.1 KHz sample rate for recording and playback High Speed USB 2.0 compliant host interface, with transfer rates up to 480 Mbps uk.startech.com 0800 169 0408 Technical Specifications Warranty Chipset ID Connector Type(s) External Ports External Ports Audio Specifications 2 Years C-Media - CM6206 1 - USB B (4 pin) Female 2 - Toslink (SPDIF; Optical) Female 8 - 3.5 mm Mini-Jack (3 Position) Female 8 16-bit DAC Channels (7.1 Surround Sound) Supports 44.1 and 48 KHz sampling rates for both playback and recording OS Compatibility Color Product Length Product Width Product Height Product Weight LED Indicators LED Indicators Operating Temperature Storage Temperature Humidity Note Shipping (Package) Weight Included in Package Included in Package Included in Package Included in Package 3.5mm output connectors for Front, Surround, Rear, Centre/bass Windows 2000/ XP(32/64-bit)/ Server 2003(32/64-bit)/ Server 2008 R2/ Vista(32/64-bit)/ 7(32/64-bit)/ 8(32/64-bit) Mac OS X (tested up to 10.8) Linux Silver 100 mm [3.9 in] 60 mm [2.4 in] 25 mm [1 in] 100 g [3.5 oz] 1 - Microphone Mute 1 - Power/Activity 0°C to 55°C (32°F to 131°F) 0°C to 70°C (32°F to 158°F) 20 to 80% NC RH Optical S/PDIF output is not available in Mac OS. 0.2 kg [0.5 lb] 1 - USB to Audio Adapter 1 - USB Cable 1 - Installation CD 1 - Instruction Manual uk.startech.com 0800 169 0408 Certifications, Reports and Compatibility uk.startech.com 0800 169 0408
ICUSBAUDIO7D 价格&库存
很抱歉,暂时无法提供与“ICUSBAUDIO7D”相匹配的价格&库存,您可以联系我们找货
ICUSBAUDIO7D
    库存:2
    ICUSBAUDIO7D
      • 1+438.29758
      库存:6
