DP2HD4K60H
DP2HD4K60H
    STARTECH
    STARTECH - DP2HD4K60H - ADAPTER, DISPLAYPORT TO HDMI, 1 WAY
DP2HD4K60H 数据手册
DisplayPort to HDMI Adapter with HDR - 4K 60Hz Black Product ID: DP2HD4K60H This DisplayPort to HDMI Adapter lets you connect your DP equipped computer to an HDMI display. The adapter supports High Dynamic Range (HDR) and provides sharper images with enhanced video. With brighter colors and greater contrast, the adapter is ideal for: • Creating eye-catching visuals for photography, videography, cinematography • Displaying crisp digital signage walls • Delivering enriched presentations www.startech.com/uk 0800 169 0408 True 4K at 60Hz and HDR The DisplayPort to HDMI adapter is fully compatible with your HDMI 2.0b equipment, supporting resolutions up to 4K 60Hz (3840 x 2160) and bandwidths up to 18Gbps. The adapter offers 4:4:4 chroma subsampling, so every pixel gets its own unique color. It’s also backward compatible with earlier versions of HDMI and DisplayPort at their supported maximum resolutions. With HDR support, you can enjoy lifelike images with increased contrast, brightness and colors and greater luminosity than standard digital imaging. Ideal for Travel This lightweight video adapter is highly portable, with a small footprint design. It's the perfect accessory for your DP supported devices, fitting easily into your carrying case. Hassle-Free Setup To ensure easy operation and installation, this unique DP to HDMI adapter allows for plug-and-play installation without any additional software or drivers. DP2HD4K60H is backed by a 3-year StarTech.com warranty and free lifetime technical support. Notes: • • To achieve HDR, your USB-C port must support DisplayPort 1.4 and your display must support HDMI 2.0b. NVIDIA graphics adapters may not support 4:4:4 chroma subsampling and 5.1/7.1 audio output, when used with this adapter. www.startech.com/uk 0800 169 0408 Certifications, Reports and Compatibility Features • • • • • Astonishing picture quality with support for UHD video resolutions up to 4K 60Hz Supports HDR for expanded contrast ratio and color accuracy Features an electromagnetic interference (EMI) shielding cage to ensure reliable and consistent audio-video signal Maximum portability with a compact, lightweight design Hassle-free setup with an active DisplayPort conversion www.startech.com/uk 0800 169 0408 Hardware Performance Warranty 3 Years Active or Passive Adapter Active Adapter Style Adapters Audio Yes AV Input DisplayPort AV Output HDMI Chipset ID MegaChips - MCDP2900 Industry Standards DPCP (DisplayPort Content Protection) HDCP 2.2 (High Definition Content Protection) DisplayPort 1.4 HDMI 2.0b Ports 1 Audio Specifications 7.1 surround sound Maximum Digital Resolutions 4096 X 2160 @ 24Hz 3840 X 2160 @ 60Hz Supported Resolutions 4096 X 2160 @ 24Hz 3840 X 2160 @ 60Hz Lower resolutions and refresh rates may also be supported Connector(s) Special Notes / Requirements Video Revision HDMI 2.0b Wide Screen Supported Yes Connector A 1 - DisplayPort (20 pin) Latching Male Input Connector B 1 - HDMI (19 pin) Female Output Note This video adapter is not compatible with cables that use RedMere™ technology. In order to achieve maximum performance of this product, both the source and destination devices must support the appropriate specifications Environmental Physical Characteristics Humidity 25%-60%RH Operating Temperature 5°C ~ 35°C (41 F°~95 F°) Storage Temperature -20°C to 60°C (-4°F to 140°F) Cable Length 122 mm [4.8 in] Color Black Enclosure Type Plastic Product Height 11.4 mm [0.4 in] www.startech.com/uk 0800 169 0408 Product Length 29 mm [1.1 in] Product Weight 25 g [0.9 oz] Product Width 253 mm [10 in] Packaging Information Shipping (Package) Weight 0 kg [0.1 lb] What's in the Box Included in Package 1 - DisplayPort to HDMI Adapter Product appearance and specifications are subject to change without notice. www.startech.com/uk 0800 169 0408
DP2HD4K60H
物料型号:DP2HD4K60H
器件简介:这是一个DisplayPort转HDMI适配器,支持4K 60Hz和HDR,适用于连接DP接口的电脑到HDMI显示器。
引脚分配:DisplayPort接口为20针锁定式公头输入,HDMI接口为19针母头输出。
参数特性: - 支持HDR,提供扩展的对比度和色彩准确性 - 支持UHD视频分辨率高达4K 60Hz - 电磁干扰(EMI)屏蔽笼,确保音视频信号的可靠性和一致性 - 紧凑轻便设计,便于携带 - 即插即用安装,无需额外软件或驱动程序 - 3年StarTech.com保修和免费终身技术支持
功能详解: - 支持DisplayPort 1.4和HDMI 2.0b - 4:4:4色度子采样,每个像素都有其独特的颜色 - 支持7.1环绕声音频规格 - 支持4096x2160@24Hz和3840x2160@60Hz分辨率
应用信息:适用于创建引人注目的视觉效果、显示清晰的数字标牌墙、提供丰富的演示。
封装信息: - 产品尺寸:253mm x 29mm x 11.4mm - 产品重量:25g - 颜色:黑色 - 外壳类型:塑料
DP2HD4K60H 价格&库存
很抱歉,暂时无法提供与“DP2HD4K60H”相匹配的价格&库存,您可以联系我们找货
DP2HD4K60H
    • 1+426.547681+55.35811
    • 10+378.3483310+49.10271
    • 25+360.7442425+46.81802
    • 50+347.9753650+45.16085
    • 100+335.66014100+43.56256
    • 250+320.04939250+41.53657
    库存:15
    DP2HD4K60H
    • 1+349.77996
    库存:38
