HB30CM4AB
HB30CM4AB
    STARTECH
    STARTECH - HB30CM4AB - Hub, 4 Port, USB 3.0, 285 mm Cable, Bus Powered
HB30CM4AB 数据手册
4 Port USB C Hub - 4x USB-A - 5Gbps USB 3.0 Type-C Hub (USB 3.2/3.1 Gen 1) - Bus Powered Portable USB-C to USB-A Adapter Laptop Hub - 11.2" (28.5cm) Cable w/ Cable Management Product ID: HB30CM4AB This 4 Port USB-C Hub enables you to connect four SuperSpeed USB 3.2 Gen 1 (5 Gbps) peripherals to your USB-C laptop or computer, an ideal solution for adding USB ports to a device that has limited USB ports available. It features a wrap-around cable manager, allowing you to tuck away the built-in cable for easy portability. Note: USB 3.2 Gen 1 (5 Gbps) is also know as USB 3.1 Gen 1 (5 Gbps), and USB 3.0 (5 Gbps). With this USB-C hub you can connect four USB-A devices to a single USB-C port on your USB-C host device. The USB Type-C hub shares up to 15W (5V/3A) of power between connected devices, making it an ideal solution for connecting SSD/thumb drives, data storage, keyboards, mice, web cams and USB headsets. The USB hub is backward compatible with USB 2.0 (480 Mbps). Featuring a durable plastic housing that's lightweight, and a sleek warp-around cable management system, this USB hub is the perfect travel companion for your laptop. Its small footprint ensures it will store easily in your laptop bag, and the wrap-around cable manager prevents tangles, ensuring easy accessibility. The USB hub is bus powered so there's no bulky external power adapter. The USB hub is OS independent ensuring support on a wide range of platforms including Windows, macOS, Linux, iPadOS, Chrome OS and Android. The built-in host cable is 11 in. (28 cm) long, providing enough length to easily integrate into any workstation, reaching your host device even when it's placed on a laptop riser or stand. The USB-C host connection works with any USB-C or Thunderbolt 3 laptop, tablet, smartphone or 2-in-1, such as Surface Pro 7, Surface Book, iPad Pro, MacBook/MacBook Pro/MacBook Air, XPS or X1 Carbon. HB30CM4AB is backed by a StarTech.com 2-year warranty and free lifetime 24/5 multi-lingual North American based technical support. StarTech.com has been the IT professionals' choice for over 30 years. Certifications, Reports and Compatibility Applications • Connect SSD/thumb drives, data storage devices, keyboards, mice, web cams and USB headsets to your USB-C computer • Store in your laptop bag while traveling Features • 4 PORT USB-C HUB: Expand the connectivity of a USB-C laptop or desktop PC by adding 4x USB-A ports with this USB 3.2/3.1 Gen 1 SuperSpeed 5Gbps adapter hub; Supports USB 3.0/2.0 devices • 15W SHARED POWER: Bus Powered USB Type-C hub w/ speeds up to 5Gbps & power up to 15W shared w/ all downstream devices; Supports SSD/thumb drives, data storage, keyboards, mice, web cams, headsets • ORGANIZED & PORTABLE: Compact USB-C hub with hideaway cable management to prevent tangles in laptop bags or pockets; Lightweight travel hub w/ durable plastic housing, 11" (28 cm) attached USB-C cable • COMPATIBILITY: OS independent, works with Windows, macOS, Linux, iPadOS, Chrome OS, Android; Long host cable for USB-C/Thunderbolt 3 laptops on stands or 2-in-1s (Surface Pro 7/Book 3, iPad Pro/Air) • STARTECH.COM ADVANTAGE: IT professionals’ choice for over 30 years; This USB-C expander hub is backed for 2-years by StarTech.com, including free 24/5 North America based multi-lingual tech support Hardware Warranty 2 Years USB-C Device Port(s) No USB-C Host Connection Yes Fast-Charge Port(s) No Ports 4 Interface USB 3.2 Gen 1 Bus Type USB 3.2 Gen 1 (5 Gbps) Industry Standards USB 3.2 - Backward compatible with USB 3.0, 2.0 and 1.1 Chipset ID Realtek - RTS5411E Maximum Data Transfer Rate 5Gbps Type and Rate USB 3.1 Gen 1 - 5 Gbit/s Performance UASP Support Yes Connector Type(s) USB Type-C (24 pin) USB 3.0 (5Gbps) Connector(s) USB 3.1 USB Type-A (9 pin, Gen 1, 5 Gbps) Software OS Compatibility OS Independent Power Source Bus Powered Operating Temperature 0C to 50C (32F to 122F) Storage Temperature -20C to 70C (-4F to 158F) Humidity 0% to 95% (non-condensing) at 25C (77F) Color Black & Space Gray Form Factor Compact Material Plastic Cable Length 11.0 in [28 cm] Product Length 5.3 in [13.5 cm] Product Width 2.0 in [50.0 mm] Product Height 0.8 in [20.0 mm] Weight of Product 2.6 oz [73.0 g] Package Length 5.6 in [14.2 cm] Package Width 6.7 in [17.0 cm] Package Height 1.2 in [30.0 mm] Shipping (Package) Weight 4.6 oz [130.6 g] Power Environmental Physical Characteristics Packaging Information What's in the Box Included in Package USB-C Hub *Product appearance and specifications are subject to change without notice.
HB30CM4AB 价格&库存
很抱歉,暂时无法提供与“HB30CM4AB”相匹配的价格&库存,您可以联系我们找货
