DisplayPort to HDMI VGA Adapter - 4K 60Hz
Product ID: DP2VGAHD20
This DisplayPort to HDMI VGA adapter offers a portable solution for connecting your DP laptop to
a VGA or HDMI display. The adapter supports High Dynamic Range (HDR) and provides sharper images
with enhanced video.
Two-in-One Video Connectivity with Travel in Mind
Avoid the hassle of carrying different adapters, with a 2-in-1 DisplayPort monitor adapter. Featuring
both VGA and HDMI outputs, you can conveniently connect your laptop to any HDMI or VGA-equipped
display, using this multiport video converter.
With its small footprint and lightweight design, the travel adapter fits easily into your laptop bag, making
it perfect for professionals on the go.
www.startech.com
1 800 265 1844
Astonishing 4K Picture Quality
The HDMI output on this DisplayPort video adapter lets you harness the video capabilities that are built
into your computer's DP connection, delivering the astonishing quality of UHD to your 4K
60Hz HDMI display. Plus, the VGA output supports HD resolutions up to 1920 x 1080, ensuring you won’t
have to sacrifice picture quality when connected to a VGA monitor or projector.
With HDR support, you can enjoy lifelike images with increased contrast, brightness and colors and
greater luminosity than standard digital imaging.
Hassle-Free Setup
With no additional software or drivers to install, this DP (male) to HDMI (female) and VGA (female)
dongle offers a plug-and-play setup for a user-friendly experience. It allows you to walk into virtually any
boardroom ready to present, making a great first impression.
DP2VGAHD20 is backed by a 3-year StarTech.com warranty and free lifetime technical support.
www.startech.com
1 800 265 1844
Certifications, Reports
and Compatibility
Applications
Connect to virtually any HDMI and VGA display while traveling or in
the office
Output video to a secondary HDMI or VGA monitor
Stream, view and edit 4K video on your HDMI display
Features
Maximize your laptop’s video compatibility with a 2-in-1 adapter:
DisplayPort™ to HDMI® or VGA
Astonishing picture quality with UHD video resolutions up to 4K 60Hz
Supports HDR for expanded contrast ratio and color accuracy
Compact, lightweight adapter that you can easily carry in your laptop
bag
www.startech.com
1 800 265 1844
Hardware
Warranty
3 Years
Active or Passive Adapter
Active
Passive
Audio
Yes
AV Input
DisplayPort - 1.2
AV Output
HDMI
VGA
Performance
Connector(s)
Chipset ID
ITE Tech - IT6564
Audio Specifications
DisplayPort - 7.1 Channel Audio
VGA: No Audio Support
Supported Resolutions
DisplayPort: 3840x2160 (4K) / 60Hz
VGA: 1920x1080 / 60Hz
Video Revision
HDMI 2.0
Wide Screen Supported
Yes
Connector A
1 - DisplayPort (20 pin) Male
Connector B
1 - HDMI (19 pin) Female
1 - VGA (15 pin, High Density D-Sub) Female
Special Notes /
Requirements
Note
To achieve HDR, your DisplayPort port must support
DisplayPort 1.4 and your display must support HDMI 2.0b
Environmental
Humidity
10~85% RH
Operating Temperature
0°C to 60°C (32°F to 140°F)
Storage Temperature
-10°C to 70°C (14°F to 158°F)
Color
Black
Material
Plastic
Product Height
15.000
Product Length
9.1 in [23.2 cm]
Product Width
60.000
Weight of Product
39.000
Package Height
20.000
Package Length
177.000
Package Width
80.000
Shipping (Package) Weight
59.000
Physical
Characteristics
Packaging
Information
www.startech.com
1 800 265 1844
What's in the Box
Included in Package
1 - DisplayPort to HDMI and VGA Adapter
Product appearance and specifications are subject to change without notice.
www.startech.com
1 800 265 1844
很抱歉,暂时无法提供与“DP2VGAHD20”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+369.948701+48.01259
- 10+328.1619810+42.58944
- 25+312.8889025+40.60727
- 50+301.8153250+39.17012
- 100+291.13433100+37.78393
- 250+277.59339250+36.02656
