ICUSB2322I
ICUSB2322I
    STARTECH
    STARTECH - ICUSB2322I - Hub, USB to Serial, 2 Ports, Bus Powered
ICUSB2322I 数据手册
2 Port Industrial Wall Mountable USB to Serial Adapter Hub with DIN Rail Clips Product ID: ICUSB2322I The ICUSB2322I 2-Port Industrial USB to Serial Hub with DIN Rail Clips converts a single USB port into two RS232 serial ports, enabling you to connect to, monitor and control your serial devices. Featuring rugged metal construction, with sturdy wall-mounting brackets and top-hat DIN Rail clips (included), this USB to Serial Hub provides versatile mounting options and a robust solution for both harsh industrial environments and simple desktop installations. This USB powered adapter also retains assigned serial COM port values once connected, allowing the same values to be automatically reassigned to the ports provided by the adapter. Backed by a StarTech.com 2-year warranty and free lifetime technical support. Certifications, Reports and Compatibility Applications • Perfect for IT Administrators looking to add legacy functionality to newer notebooks, PCs and servers that lack an integrated RS232 port • Connect, monitor and control industrial/automotive sensors and equipment • Connect bar code scanners, receipt printers and other point of sale devices • Connect a satellite receiver, serial modem, or PDA with serial sync • Connect and program LED and Digital signage boards with serial communication ports Features • 2-port USB to RS232 serial adapter • Rugged metal construction • Wall-mountable, with included DIN Rail clips • COM retention: COM Port assignments maintained across reboot • Baud Rate up to 921.6 Kbps • Powered by an available USB port - no external power adapter required Hardware Warranty 2 Years Ports 2 Interface Serial Bus Type USB 2.0 Port Style External Hub Chipset ID FTDI - FT232RL Serial Protocol RS-232 Max Baud Rate 921.6 Kbps Data Bits 7, 8 FIFO 256 Bytes Parity Odd, Even, Mark, Space, None Stop Bits 1, 2 External Ports USB B (4 pin) Performance Connector(s) DB-9 (9 pin, D-Sub) Software OS Compatibility Windows CE (4.2, 5.0, 6.0), XP Embedded, 98SE, 2000, XP, Vista, 7, 8, 8.1, 10 Windows Server 2003, 2008 R2, 2012, 2012 R2, 2016, 2019 macOS 10.6 to 10.15, 11.0 Linux Kernel 3.0.x - 5.4.x (LTS Versions Only) Indicators LED Indicators Each, Tx/Rx Activity indicators Power Source USB-Powered Input Voltage 5V DC Plug Type M Operating Temperature 0C to 55C (32F to 131F) Storage Temperature -20C to 85C (-4F to 185F) Humidity 5~95% RH Color Black Material Steel Cable Length 6.0 ft [1.8 m] Product Length 4.1 in [10.4 cm] Product Width 2.6 in [66 mm] Product Height 0.9 in [24 mm] Weight of Product 5.7 oz [162 g] Package Length 8.4 in [21.4 cm] Package Width 5.7 in [14.5 cm] Package Height 1.6 in [41 mm] Shipping (Package) 12.8 oz [362 g] Power Environmental Physical Characteristics Packaging Information Weight What's in the Box Included in Package USB to RS-232 Serial Adapter DIN rail kit 6 ft USB A to B cable Driver CD Instruction Manual *Product appearance and specifications are subject to change without notice.
ICUSB2322I 价格&库存
很抱歉,暂时无法提供与“ICUSB2322I”相匹配的价格&库存,您可以联系我们找货
