DP2DVI2
DP2DVI2
    STARTECH
    STARTECH - DP2DVI2 - Connector Adapter, DisplayPort, 20 Ways, Plug, DVI-I, 29 Ways, Receptacle
DP2DVI2 数据手册
DisplayPort to DVI Video Adapter Converter StarTech ID: DP2DVI2 The DP2DVI2 DisplayPort® to DVI Video Adapter Converter lets you connect a DVI monitor to DisplayPortenabled desktop or laptop computers. Supporting display resolutions of up to 1920x1200 allowing you to take full advantage of single link DVI capability. DP2DVI2 is a passive adapter that requires a DP++ port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port. StarTech.com also offers the DP2DVIS, an Active DisplayPort to DVI adapter. Backed by a StarTech.com 2-year warranty and free lifetime technical support. Applications Ideal for digital entertainment centers, home offices, business conference rooms and trade show displays Keep your existing DVI monitor to be used with your new DisplayPort device Ideal for using your DVI monitor as a secondary display Features Supports PC resolutions up to 1920x1200 and HDTV resolutions up to 1080p Latching DisplayPort connector connector ensures a solid connection Easy to use cable, no software required uk.startech.com 0800 169 0408 Technical Specifications Warranty Audio Output Signal Connector A Connector B Maximum Digital Resolutions Color Cable Length Product Length Product Width Product Height Product Weight System and Cable Requirements Shipping (Package) Weight Included in Package 2 Years No DVI-D (DVI Digital) 1 - DisplayPort (20 pin) Latching Male 1 - DVI-I (29 pin) Female 1920x1200 / 1080p Black 152.4 mm [6 in] 254 mm [10 in] 42 mm [1.7 in] 17 mm [0.7 in] 45.4 g [1.6 oz] DP++ port (DisplayPort ++) required on video card or video source (DVI and HDMI pass-through must be supported) 0 kg [0.1 lb] 1 - DisplayPort to DVI Converter Certifications, Reports and Compatibility uk.startech.com 0800 169 0408
DP2DVI2
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路安全。
3. 引脚分配:EL817共有6个引脚,分别为1脚阳极,2脚阴极,3脚发光二极管正极,4脚发光二极管负极,5脚光电晶体管输出,6脚光电晶体管负极。
4. 参数特性:EL817的主要参数包括正向电流为50mA,反向电压为5V,输出低电平电流为16mA,输出高电平电流为2mA。
5. 功能详解:EL817通过光电效应实现电信号的隔离传输,输入端控制发光二极管发光,输出端光电晶体管导通。
6. 应用信息:EL817广泛应用于工业控制系统、仪器仪表、通信设备等领域。
7. 封装信息:EL817采用DIP6封装,尺寸为9.1mm x 3.6mm。
DP2DVI2 价格&库存
很抱歉,暂时无法提供与“DP2DVI2”相匹配的价格&库存,您可以联系我们找货
DP2DVI2
  • 1+123.95591
库存:425
