HB30C4AB
HB30C4AB
    STARTECH
    STARTECH - HB30C4AB - 4 Port USB 3.0 Hub, USB-C to 4x USB-A
HB30C4AB 数据手册
4-Port USB-C Hub - USB-C to 4x USB-A - USB 3.0 Hub - Bus Powered Product ID: HB30C4AB Here’s a must-have accessory if you have a USB-C™ equipped computer but need more USB-A ports. This portable USB 3.0 hub expands your laptop or desktop connectivity by adding four USB Type-A ports through a single USB Type-C™ or Thunderbolt™ 3 port. And, because it’s USB bus-powered, you don’t need to connect an external power adapter, which makes travel more convenient and workstations less cluttered. Keep using your current peripherals and devices If you’re looking to extend the life of your existing USB-A peripheral devices, then this hub is the perfect solution. By converting your computer’s USB-C port into four USB-A ports, you can continue to use all of your existing USB 3.0 devices such as flash drives, external hard drives, and printers (USB 3.0 is also known as USB 3.1 Gen 1). Now you can save money by avoiding the added cost and hassle of purchasing new USB-C equipped peripherals. www.startech.com/uk 0800 169 0408 Add USB ports, virtually anywhere you go With its compact and lightweight design, this USB hub is tailored for mobility. You can easily tuck it into your laptop bag when traveling, which makes it easy to expand your connectivity almost anywhere you need to. Plus, with a small-footprint design the 4-port hub takes up minimal desk space when connected in your work area. Bus-powered design makes travel more convenient­­ This versatile USB-C hub is bus-powered, which means it draws its power directly from your computer’s USB-C port. This means there are fewer cables to carry with you when you travel because it doesn’t need an external power adapter. Add four USB 3.0 ports in seconds This USB hub is multi-platform compatible, which means it will work with a wide range of laptops. It also works with a range of operating systems such as Windows®, Mac, Linux® and Chrome OS™. It installs automatically once you connect it to your laptop, so you can be up and running in seconds. The HB30C4AB is backed by a StarTech.com 2-year warranty and free lifetime technical support. www.startech.com/uk 0800 169 0408 Certifications, Reports and Compatibility Applications • • Turn your computer’s USB-C port into four USB 3.0 Type-A ports Carry the hub with you while you're traveling, and connect your USB devices wherever you go • Perfect for home, office, hot-desk, BYOD (Bring Your Own Device), and CYOD (Choose Your Own Device) environments Ideal for desktop, laptop, Ultrabook, Chromebook Pixel, and MacBook users who don’t have enough USB 3.0 ports available • Features • • • • • • • • • A cost-effective way to add four USB-A ports to your computer through a USB-C port A small-footprint design that’s lightweight and compact, for maximum portability USB bus-powered for use with the most common devices, with no external power required for most use cases Built-in USB Type-C cable for less clutter Universal, multi-platform compatible, with fast and easy installation, and native support in most operating systems (Windows, Mac, Chrome OS, Linux) Plug-and-play, and supports hot-swapping or hot-plugging Integrated cable features a small and reversible USB-C connector, and it’s Thunderbolt 3 data port compatible Backward compatible, for use with your older USB 3.0 and 2.0 devices Dongle-style USB hub provides three SuperSpeed USB 3.0 (USB 3.1 Gen 1) ports, with throughput support up to 5Gbps www.startech.com/uk 0800 169 0408 Hardware Performance Connector(s) Warranty 2 Years Bus Type USB 3.0 Chipset ID VIA/VLI - VL812 Fast-Charge Port(s) No Industry Standards USB 3.0 - Backward compatible with USB 2.0 and 1.1 Interface USB 3.0 Ports 4 USB-C Device Port(s) No USB-C Host Connection Yes Maximum Data Transfer Rate 5 Gbps Type and Rate USB 3.0 - 5 Gbit/s Connector Type(s) 4 - USB Type-A (9 pin) USB 3.0 Female 1 - USB Type-C (24 pin) USB 3.0 Male Software OS Compatibility OS Independent; No additional drivers or software required Special Notes / Requirements Note USB 3.0 is also known as USB 3.1 Gen 1; this connectivity standard offers speeds up to 5Gbps. System and Cable Requirements Available USB Type-C port - USB 3.0 (5Gbps) Power Power Source USB-Powered Environmental Humidity 10~85% RH (Non-condensing) Operating Temperature 0°C to 45°C (32°F to 113°F) Storage Temperature -10°C to 70°C (14°F to 158°F) Cable Length 146 mm [5.7 in] Color Black Enclosure Type Plastic Form Factor Compact Product Height 15 mm [0.6 in] Product Length 80 mm [3.1 in] Product Weight 35 g [1.2 oz] Product Width 41 mm [1.6 in] Packaging Information Shipping (Package) Weight 103 g [3.6 oz] What's in the Box Included in Package 1 - 4-port USB 3.0 hub Physical Characteristics www.startech.com/uk 0800 169 0408 Product appearance and specifications are subject to change without notice. www.startech.com/uk 0800 169 0408
HB30C4AB 价格&库存
很抱歉,暂时无法提供与“HB30C4AB”相匹配的价格&库存,您可以联系我们找货
HB30C4AB
    • 1+395.93409
    库存:63
