BRACKET125PT
BRACKET125PT
    STARTECH
    STARTECH - BRACKET125PT - Drive Bracket, SATA, IDE, 2.5" SSD/HDD Mount, Black
BRACKET125PT 数据手册
2.5" SSD/HDD Mounting Bracket for 3.5" Drive Bay - Tool-less Installation Product ID: BRACKET125PT This mounting bracket lets you quickly install a 2.5" SSD or HDD into a single 3.5" bay in a desktop PC or server, with no tools required. The tool-less mounting bracket supports a 2.5" solid-state drive or hard drive from 7 mm to 9.5 mm in height. Save time with easy, tool-less drive installation The mounting bracket’s tool-less design makes it fast and easy to install a 2.5" drive in a computer or server, without the need for additional hardware or tools. It’s ideal for system administrators and integrators who are building or upgrading a computing solution for a wide range of businesses and organizations, including schools and hospitals, saving valuable time and effort on installation projects. www.startech.com 1 800 265 1844 Designed for trouble-free use The lightweight mounting bracket is designed for trouble-free, reliable performance. To install a drive, you simply secure it into the mounting bracket, without using tools. Then, you put the bracket into a 3.5" drive bay in your computer and the bracket holds the drive in place using the tool-less plastic pegs. The BRACKET125PT is backed by a StarTech.com 2-year warranty and free lifetime technical support. www.startech.com 1 800 265 1844 Certifications, Reports and Compatibility Applications • • • • Provides system integrators and builders with a time-saving way to install drives into systems Makes installation projects more efficient for a wide range of small to medium businesses, organizations and institutions such as schools and hospitals Offers an easy way to install drives into desktop computers in business or home office settings Replace a single 3.5" drive with one 2.5" SSD or HDD Features • • • • Install one 2.5” SSD or HDD into a single 3.5” bay Tool-less drive and bay installation Supports drives 7 mm or 9.5 mm in height Compatible with most 2.5" SSD/HDD drives including: IDE, SAS, SATA, U.2 and more www.startech.com 1 800 265 1844 Hardware Warranty 2 Years Compatible Drive Types SATA & IDE SAS U.2 (PCIe, NVMe, SFF-8639) Drive Installation Fixed Drive Size 2.5in Number of 2.5 inch bays 1 Supported Drive Height(s) 7mm 9.5mm Physical Characteristics Packaging Information What's in the Box Color Black Enclosure Type Plastic Max Drive Height 0.4 in [9.5 mm] Product Height 0.5 in [13 mm] Product Length 5.9 in [15 cm] Product Width 4 in [10.2 cm] Weight of Product 1.2 oz [33 g] Package Height 0.8 in [21 mm] Package Length 6.1 in [15.6 cm] Package Width 4.4 in [11.1 cm] Shipping (Package) Weight 2.1 oz [60 g] Included in Package 1 - 2.5” SSD/HDD mounting bracket 6 - plastic pegs 1 - quick-start guide Product appearance and specifications are subject to change without notice. www.startech.com 1 800 265 1844
BRACKET125PT 价格&库存
很抱歉,暂时无法提供与“BRACKET125PT”相匹配的价格&库存,您可以联系我们找货
BRACKET125PT
  • 1+83.83139
库存:32
