USB-C to HDMI Adapter
Product ID: CDP2HD
This USB-C™ to HDMI® adapter lets you output HDMI video and audio from a USB Type-C™ device such
as a MacBook or Chromebook™ laptop. This adapter works with USB-C devices that pass a DisplayPort
video signal. It's also compatible with Thunderbolt™ 3 ports.
Ultimate portability
This USB type-C video adapter is highly portable with a small footprint and lightweight design. The
adapter is the perfect accessory for your MacBook or Chromebook, fitting easily into your laptop bag or
carrying case, which is great for BYOD (Bring Your Own Device) applications at the office.
Hassle-free connection with USB Type-C
This adapter lets you utilize the versatile USB Type-C port on your portable device. USB Type-C is
a reversible connector, so it doesn't matter which way you plug it in, the adapter will always work, saving
you the hassle and embarrassment of fiddling with your device when you're trying to deliver a
presentation.
www.startech.com/uk
0800 169 0408
Astonishing picture quality
At four times the resolution of high-definition 1080p, you’ll be amazed at the picture quality of a 4K
monitor or television. The adapter lets you harness the video capabilities built into your USB TypeC connection, to deliver the astonishing quality of Ultra HD to your 4K display. 4K resolution gives you
additional screen space to simplify your approach to detailed work such as editing video and viewing large
spreadsheets. Plus, the adapter is backward compatible with 1080p displays, which makes it a great
accessory for home, office or other workspace applications.
The CDP2HD is backed by a 2-year StarTech.com warranty and free lifetime technical support.
Note: Your USB-C equipped device must support video to work with this adapter.
www.startech.com/uk
0800 169 0408
Certifications, Reports
and Compatibility
Applications
Keep the adapter with you while traveling, to connect to any HDMI
monitor, television or projector you come across
Connect your BYOD MacBook or Chromebook to a provided HDMI
display at work
Walk into any boardroom, ready to deliver a presentation from your
USB-C laptop
Connect an HDMI display to your USB-C laptop to use as a secondary
monitor
Features
Hassle-free connection with the reversible USB-C connector
Maximum portability with a small footprint and lightweight design
Thunderbolt 3 port compatible
Astonishing picture quality for detailed applications with support for
Ultra HD video resolutions up to 4K
7.1 audio support
www.startech.com/uk
0800 169 0408
Warranty
2 Years
Audio
Yes
Converter Type
Adapters
Output Signal
HDMI
Ports
1
Audio Specifications
7.1 surround sound
Supported Resolutions
1024x768
1280x720 (High-definition 720p)
1920x1080 (High-definition 1080p)
1920x1200
2560x1440
2560x1600
3840 x 2160 (Ultra HD 4K) @30hz
Wide Screen Supported
Yes
Connector A
1 - USB-C (24 pin) DisplayPort Alt Mode Male Input
Connector B
1 - HDMI (19 pin) Female Output
Accent Color
Black
Color
Black
Enclosure Type
Plastic
Product Height
9 mm [0.4 in]
Product Length
147 mm [5.8 in]
Product Weight
27 g [1 oz]
Product Width
23 mm [0.9 in]
Packaging
Information
Shipping (Package) Weight
32 g [1.1 oz]
What's in the Box
Included in Package
1 - USB-C to HDMI adapter
Hardware
Performance
Connector(s)
Physical
Characteristics
Product appearance and specifications are subject to change without notice.
www.startech.com/uk
0800 169 0408
很抱歉,暂时无法提供与“CDP2HD”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+357.770191+46.28713
