DP2HDMM1MB
DP2HDMM1MB
    STARTECH
    DP2HDMM1MB
DP2HDMM1MB 数据手册
DisplayPort to HDMI Converter Cable - 3 ft (1m) 4K Product ID: DP2HDMM1MB This 3-foot DisplayPort™ to HDMI® adapter cable lets you connect your DisplayPort equipped Ultrabook™, laptop or desktop computer to an HDMI television, monitor or projector with no additional adapters or cables required. The passive adapter supports video resolutions up to Ultra HD 4K. Astonishing picture quality This adapter cable ensures you can maintain an astonishing picture quality, four times the resolution of 1080p, when converting DisplayPort to HDMI. The adapter is also backward compatible with lower resolution displays and video sources. With support for high-definition resolutions of 1080p and 720p, you can future-proof your existing setup for 4K video. www.startech.com/nl 1 800 265 1844 Hassle-free setup For the simplest and most discreet installation, this DP to HDMI adapter connects directly from your DisplayPort video source to the HDMI port on your display. It doesn't need a power source, unlike some converter dongles that require active power and separate bulky video cabling. Clutter-free installation At 3ft in length, this adapter cable delivers a compact connection that eliminates excess to ensure a tidy, professional installation. For longer installations, we also offer a 6 ft DP to HDMI cable (DP2HDMM2MB), enabling you to choose the right cable length for your custom installation needs. The DP2HDMM1MB is backed by a 2-year StarTech.com warranty and free lifetime technical support. www.startech.com/nl 1 800 265 1844 Certificaties, rapporten en compatibiliteit Toepassingen • • • • Connect a DisplayPort computer to an HDMI display at your classroom desk or workstation Use in your boardroom or office workstations for installations requiring 3 feet of cable Install in your home workstation to make your DisplayPort computer compatible with your HDMI display Connect your DP video source to a 4K HDMI display Eigenschappen • • • • • • Astonishing video quality with support for video resolutions up to 4K at 30 Hz Reduce clutter with a compact 3ft adapter cable Avoid the hassle of converters that require additional cabling and power adapters with a plug-and-play cable adapter Supports HDMI 4K @ 30 Hz Plug-and-play installation No power adapter required www.startech.com/nl 1 800 265 1844 Warranty 2 Years Active or Passive Adapter Passive Adapter Style Adapters Audio Yes AV Input DisplayPort AV Output HDMI Industry Standards DPCP (DisplayPort Content Protection) HDCP (High Definition Content Protection) DisplayPort 1.2 HDMI 1.4 Ports 1 Audio Specifications 7.1 surround sound Maximum Digital Resolutions 4K x 2K @ 30 Hz Supported Resolutions 4k x 2K (Ultra HD) 1920x1200 1920x1080 (1080p) 1280x720 (720p) Wide Screen Supported Yes Connector A 1 - DisplayPort (20 pin) Male Input Connector B 1 - HDMI (19 pin) Male Output Humidity 10%-85% Operating Temperature 0°C to 70°C (32°F to 158°F) Storage Temperature -10°C to 70°C (14°F to 158°F) Cable Length 39.4 in [1000 mm] Color Black Product Height 0.5 in [12 mm] Product Length 39.8 in [1010 mm] Product Weight 1.8 oz [49.6 g] Product Width 0.8 in [21 mm] Packaging Information Shipping (Package) Weight 2.1 oz [60 g] What's in the Box Included in Package 1 - DP to HDMI adapter cable Hardware Performance Connector(s) Environmental Physical Characteristics Uitvoering en specificaties van het product zijn zonder aankondiging vatbaar voor wijzigingen. www.startech.com/nl 1 800 265 1844
DP2HDMM1MB 价格&库存
很抱歉,暂时无法提供与“DP2HDMM1MB”相匹配的价格&库存,您可以联系我们找货
DP2HDMM1MB
  • 1+202.58038
库存:136
