4 Port USB C Hub 10Gbps - Metal Industrial USB Type-C Hub w/ 3xUSB-A & 1xUSB-C - ESD &
Surge Protection - USB-C or USB-A Host - Self-Powered Mountable USB 3.2/3.1 Gen 2 Hub
Product ID: HB31C3A1CME
This 4-Port industrial USB hub enables you to connect four SuperSpeed USB 3.2 Gen 2 (10 Gbps) peripherals to
your USB-A or USB-C computer. The hub features three USB-A and one USB-C peripheral ports, each with a
screw-lock connector, and a metal industrial housing ideal for commercial environments.
With this USB-C hub you can connect three USB-A devices, and one USB-C device, to a single USB-C or USB-A
port on your host device. The hub supports USB 3.2 Gen 2 (10 Gbps), and is backward compatible with USB 3.2 Gen
1 (5 Gbps) and USB 2.0 (480 Mbps).
Note: USB 3.2 Gen 2 (10 Gbps) is also known as USB 3.1 Gen 2 (10 Gbps), USB 3.2 Gen 1 (5 Gbps) is also know as
USB 3.1 Gen 1 (5 Gbps), and USB 3.0 (5 Gbps).
The USB hub is self powered using either the included 36W (12V/3A) AC to DC power adapter, or the built-in terminal
block connector that supports a 7-24V DC input. The hub shares up to 30W of power between connected devices
and each port supports BC 1.2 providing 12W (2.4A) of power on all ports up to a 30W draw.
This USB hub has a rugged-metal enclosure with built-in mounting ears that enable you to mount it to any wall or
surface. The hub features 15kV Air and 8kV Contact electrostatic discharge protection, with 350W surge protection.
Each port on the Hub has a screw lock, avoiding the possibility of accidental cable disconnection and a 3.3 ft (1m)
USB-C & USB-A host cables is included that features a locking screw.
The USB hub is OS independent ensuring support on a wide range of platforms including Windows, macOS, Linux,
iPadOS, Chrome OS and Android.
HB31C3A1CME is backed by a StarTech.com 2-year warranty and free lifetime 24/5 multi-lingual North American
based technical support. StarTech.com has been the IT professionals' choice for over 30 years.
Certifications, Reports and Compatibility
Applications
• Connect equipment to a computer in industrial environments
• Power and charge devices
Features
• INDUSTRIAL 4 PORT USB-C HUB: Expand the connectivity of a USB-C or USB-A computer by adding 3x USB-A &
1x USB-C ports; SuperSpeed 10Gbps USB 3.2/3.1 Gen 2 hub; 3.3 ft (1m) USB-C & USB-A host cables included (w/
screw-lock)
• ESD PROTECTION: Featuring 15kV Air and 8kV Contact electrostatic discharge protection & 350W surge
protection, this rugged metal-enclosed hub is suitable for harsh industrial/commercial environments
• POWER & CHARGE: Self powered USB C hub w/ 36W power adapter & terminal block connector (7-24V DC
inputs); Charging w/BC 1.2 for 30W total on all ports Provides 12W (2.4A) on all ports up to a total 30W draw
• INSTALLATION FLEXIBILITY: Mountable USB Type-C Hub with built-in ear mounting allows for wall/surface
mounting; All USB-A & USB-C ports on hub feature screw-lock connectors to prevent accidental cable release
• COMPATIBILITY: USB expansion hub is OS independent, supports Windows, macOS, Linux, iPadOS, Chrome OS,
Android; Thunderbolt 3 & USB 3.0/2.0 compatible; For use in manufacturing, automation, labs, schools, IT
Hardware
Warranty
2 Years
USB-C Device Port(s)
Yes
USB-C Host Connection
Yes
Fast-Charge Port(s)
Yes
Ports
4
Bus Type
USB 3.2 Gen 2 10Gbps
Chipset ID
VIA/VLI - VL822
Maximum Data Transfer
Rate
10 Gbps
Type and Rate
USB 3.2 Gen 2 - 10 Gbit/s
UASP Support
Yes
Performance
Supported Charging
Modes
Dedicated Charging Port (DCP)
Charging Downstream Port (CDP)
Supported Charging
Outputs
BC 1.2 (1.5A)
Apple 1A
Apple 2.4A
Connector(s)
Connector Type(s)
USB 3.1 USB Type-A (9 pin, Gen 2, 10 Gbps)
USB Type-C (24 pin) USB 3.1 (10Gbps)
Software
OS Compatibility
OS Independent; No additional drivers or software required
System and Cable
Requirements
Available USB 3.2 Gen 2 (10 Gbps) Type-C port
LED Indicators
Power LED
Special Notes /
Requirements
Indicators
USB Device Link LED
Power
Power Source
AC Adapter Included
Input Voltage
100 - 240 AC
Input Current
1A
Output Voltage
12V DC
Output Current
3A
Center Tip Polarity
Positive
Plug Type
M
Power Consumption (In
Watts)
36
Environmental
Operating Temperature
0C to 70C (32F to 158F)
Storage Temperature
-10C to 55C (14F to 131F)
Humidity
0~85% RH
Color
Black
Form Factor
Industrial
Material
Steel
Product Length
6.0 in [15.2 cm]
Product Width
2.3 in [59.6 mm]
Product Height
0.9 in [23.5 mm]
Weight of Product
9.9 oz [280.0 g]
Package Length
11.4 in [29.0 cm]
Package Width
5.9 in [14.9 cm]
Package Height
2.8 in [70.0 mm]
Shipping (Package)
Weight
2.7 lb [1.2 kg]
Included in Package
USB Hub
Physical
Characteristics
Packaging
Information
What's in the
Box
Universal Power Adapter (NA, JP, UK, EU, ANZ)
Terminal Block Connector
USB Type-C to Type-C Cable
USB Type-C to Type-A Cable
Quick-Start Guide
*Product appearance and specifications are subject to change without notice.
很抱歉,暂时无法提供与“HB31C3A1CME”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1576.887141+204.39460
- 10+1398.9756710+181.33389
- 25+1333.9052825+172.89952
- 50+1291.3937350+167.38922
