HD2VGAE2
HD2VGAE2
    STARTECH
    STARTECH - HD2VGAE2 - Connector Adapter, HDMI, 1 Ways, Plug, VGA, 1 Ways, Receptacle
HD2VGAE2 数据手册
HDMI® to VGA Adapter Converter for Desktop PC / Laptop / Ultrabook - 1920x1080 StarTech ID: HD2VGAE2 The HD2VGAE2 HDMI® to VGA adapter allows you to connect an HDMI output from your laptop, ultrabook, or desktop computer onto a VGA monitor or projector, saving the cost of upgrading to an HDMI compatible display. Intended for outputting user generated content such as presentations, and work documents, the HDMI to VGA converter can also work to increase your productivity by extending your computer's desktop onto a secondary monitor, doubling available workspace. With no need for an external power source, and support for resolutions up to 1080p (1920x1080), this active HDMI to VGA adapter offers a compact and portable solution for connecting a High-Definition VGA display. Looking for an HDMI to VGA coverter for your Chromebook? Use the HD2VGAMICRO. The HD2VGAE2 HDMI® to VGA Adapter is backed by a StarTech.com 2-year warranty and free lifetime technical support. Applications Connect HDMI-enabled devices such as your laptop, ultrabook, or desktop computer to a VGA projector or display Features Maximum resolution of 1920x1080 (1080p) No external power adapter required uk.startech.com 0800 169 0408 Technical Specifications Warranty Audio Converter Type Industry Standards Ports Connector A Connector B Maximum Analog Resolutions Maximum Digital Resolutions Supported Resolutions Wide Screen Supported Note 2 Years No Format Converter High Speed HDMI® 1 1 - HDMI (19 pin) Male Input 1 - VGA (15 pin; High Density D-Sub) Female Output 1920x1200 1920x1200 1920x1200, 1920x1080 (1080p), 1600x1200 @ 60Hz Yes This adapter will not work with Samsung Chromebooks. HD2VGAMICRO is recommended for this application. Color Black Enclosure Type Plastic Product Height 15 mm [0.6 in] Product Length 245 mm [9.6 in] Product Weight 39 g [1.4 oz] Product Width 40 mm [1.6 in] Humidity 40% to 85% RH Non-Condensing Operating Temperature 0°C to 60°C (32°F to 140°F) Storage Temperature -10°C to 70°C (14°F to 158°F) Shipping (Package) 0 kg [0.1 lb] Weight Included in Package 1 - HDMI® to VGA Converter Adapter uk.startech.com 0800 169 0408 Certifications, Reports and Compatibility uk.startech.com 0800 169 0408
HD2VGAE2 价格&库存
很抱歉,暂时无法提供与“HD2VGAE2”相匹配的价格&库存,您可以联系我们找货
HD2VGAE2
    • 1+410.988731+53.41615
    • 10+364.5303410+47.37796
    • 25+347.5634825+45.17278
    • 50+335.2619050+43.57394
    • 100+323.39656100+42.03181
    • 250+308.35672250+40.07708
    库存:81
    HD2VGAE2
    • 1+337.10632
    库存:63
