HDADFM5IN
HDADFM5IN
    STARTECH
    STARTECH - HDADFM5IN - DVI to HDMI Audio / Video Adapter, 5" Cable, HDMI Receptacle, Micro HDMI Plug
HDADFM5IN 数据手册
5in High Speed HDMI Adapter Cable - HDMI to HDMI Micro – F/M Product ID: HDADFM5IN The HDADFM5IN 5-inch HDMI to HDMI Micro Cable adapter enables you to use a standard HDMI male-to-male cable to connect your portable devices (BlackBerry PlayBook, Smartphones, etc.) to most video displays. With a Standard HDMI female connector (type A) on one end and an HDMI Micro (type D) male connector on the other, you can easily make this conversion and connect to computer monitors, HDTV or HDMI projectors virtually everywhere you go. The HDMI/HDMI Micro cable features high quality, gold-tipped connectors that ensure peak connectivity, and is backed by StarTech.com's Lifetime Warranty. Certifications, Reports and Compatibility Applications • A simple solution that allows you to connect HDMI Micro devices such as your BlackBerry PlayBook or smartphone to a HD display or Television using a regular HDMI Male to Male cable. Features • HDMI Micro connector allows connection of portable HDMI devices to HDMI displays or TVs • High quality design and construction for optimimum performance and portability • All-in-one cable design for transmitting digital audio and video through a single cable Hardware Warranty Lifetime Connector Plating Gold Cable Jacket Material PVC - Polyvinyl Chloride Cable Shield Material Aluminum-Mylar Foil with Braid Connector A HDMI (19 pin) Connector B Micro HDMI (19 pin) Color Black Wire Gauge 34 AWG Cable Length 5.0 in [12.7 cm] Product Length 5.0 in [12.7 cm] Product Width 0.8 in [20.0 mm] Product Height 0.4 in [10.0 mm] Weight of Product 0.7 oz [20.0 g] Package Quantity 1 Package Length 8.9 in [22.5 cm] Package Width 4.9 in [12.5 cm] Package Height 0.5 in [13.0 mm] Shipping (Package) Weight 0.9 oz [25.0 g] Included in Package 5in HDMI to HDMI Micro Adapter - F/M Connector(s) Physical Characteristics Packaging Information What's in the Box *Product appearance and specifications are subject to change without notice.
HDADFM5IN 价格&库存
很抱歉,暂时无法提供与“HDADFM5IN”相匹配的价格&库存,您可以联系我们找货
HDADFM5IN
  • 1+148.64711
库存:97
