ICUSB232PRO
ICUSB232PRO
    STARTECH
    STARTECH - ICUSB232PRO - Converter, USB 2.0 A Plug to RS-232 Serial, 921.6 Kbps
ICUSB232PRO 数据手册
1 ft USB to RS232 Serial DB9 Adapter Cable with COM Retention Product ID: ICUSB232PRO The ICUSB232PRO 1 ft USB to RS232 Serial DB9 Adapter Cable with COM Retention offers a professional grade solution for connecting legacy or industrial RS232 serial devices to a laptop or desktop computer through USB eliminating the expense of upgrading serial peripherals for compatibility. A time-saving and convenient USB/Serial solution, the adapter retains assigned serial COM port values in nonvolatile memory, allowing the same values to automatically be assigned to the adapter serial port if disconnected and reconnected, or disconnected from one USB port and installed in another. A versatile connectivity solution that bridges legacy serial peripheral devices with newer USB-capable computers, the USB to Serial adapter offers broad operating system compatibility including Windows, Linux and Mac OS, for easy integration into mixed environments. Backed by a StarTech.com 2-year warranty and free lifetime technical support. Certifications, Reports and Compatibility Applications • Perfect for IT Administrators looking to add legacy functionality to newer notebooks, PCs and servers that lack an integrated RS232 port • Connect, monitor and control industrial/automotive sensors and equipment • Connect bar code scanners, receipt printers and other point of sale devices • Connect a satellite receiver, serial modem, or PDA with serial sync • Connect and program LED and Digital signage boards with serial communication ports Features • USB to Straight-Through RS232 Serial Adapter • COM Port assignments maintained across reboot • Supports data transfer rates of up to 920kpbs • Powered by an available USB port - no external power adapter required • Provides dual buffers for upstream and downstream data transfer • Supports remote wake up and power management control • Supports automatic handshake mode Hardware Warranty 2 Years Ports 1 Interface Serial Bus Type USB 2.0 Port Style Cable Adapters Chipset ID Prolific - PL2303 Serial Protocol RS-232 Max Baud Rate 921.6 Kbps Connector Type(s) DB-9 (9 pin, D-Sub) Performance Connector(s) USB Type-A (4 pin) USB 2.0 Software OS Compatibility Windows PocketPC 2003 / 2000, Windows Mobile 5/6, CE 4.2/5.2, Embedded System 2009, XP Embedded, POS Ready 2009, 98SE, 2000, ME, XP, Vista, 7, 8, 8.1, 10 Windows Server 2003, 2008 R2, 2012, 2016, 2019 macOS 10.6 to 10.15, 11.0 Linux 2.4.x to 4.19.x LTS Versions only Special Notes / Requirements System and Cable Requirements PC with an available USB 1.1 (or above) port Operating Temperature -10C to 80C (14F to 176F) Storage Temperature -20C to 100C (-4F to 212F) Humidity 5~85% RH Color Black Material Plastic Cable Length 12.0 in [30.5 cm] Product Length 15.7 in [40 cm] Product Width 1.3 in [34 mm] Product Height 0.6 in [15 mm] Weight of Product 1.1 oz [30 g] Package Length 6.9 in [17.5 cm] Package Width 5.7 in [14.5 cm] Package Height 1.2 in [30 mm] Shipping (Package) Weight 3.4 oz [97 g] Included in Package USB to Serial Adapter Environmental Physical Characteristics Packaging Information What's in the Box Driver CD Instruction Manual *Product appearance and specifications are subject to change without notice.
ICUSB232PRO 价格&库存
很抱歉,暂时无法提供与“ICUSB232PRO”相匹配的价格&库存,您可以联系我们找货
ICUSB232PRO
  • 1+386.855401+50.14383
  • 10+343.1176210+44.47458
  • 25+327.1551325+42.40554
  • 50+315.5760150+40.90466
  • 100+304.40767100+39.45703
  • 250+290.25066250+37.62201
ICUSB232PRO
  • 1+317.70534
库存:70
