CFM300S120
CFM300S120
    CINCON
    开放框架 AC DC 转换器 1 输出 12V 90 ~ 264 VAC 输入
CFM300S120 数据手册
https://www.cincon.com V13 CFM300S SERIES 300 WATT AC-DC POWER SUPPLY WITH PFC Features * Universal Input Range 90 ~ 264Vac * Active PFC Meets EN61000-3-2 Class C&D * High Efficiency up to 94% * High Power Density up to 14.1W/Inch3 * Over Temperature Protection * Continuous Short Circuit Protection * Remote Voltage Sense * PS On/Off Remote Control * Power Good & Power Fail Signal * +5V Stand-by Output Power * 12V Fan Output * No Load Power ConsumptionPG>50ms The TTL goes high with 50ms to 250ms after power set up The TTL goes low at least 5ms before Vo below 90% rated value Humidity …………………………….…….… 93% RH max. Non-Condensing Altitude ………..……………………………………………..………..... 5000m Cooling ……..… Natural Convection for 200W~250W (See Derating Curve) Forced Air Flow Convection(10CFM) for 300W Switching Frequency ………………………....... 60~80KHz typ. @ Full Load MTBF ……… MIL-HDBK-217F, GB, 25℃/115VAC ……….… 160Khrs. typ. Dimensions Open Frame Versions …………….. 5.000x3.000x1.421 Inches (127.00x76.20x36.1mm) -C Covered Versions .…….. 5.355x3.425x1.591 Inches (136.00x87.00x40.40mm) Weight Open Frame Versions ………………….….………….. 420g (0.925 Pounds) -C Covered Versions .…………………..…………….. 550g (1.21 Pounds) SAFETY AND EMC: Emission and Immunity ……………………………..... EN55032/35 Class B EN61000-3-2, EN61000-3-3, FCC CFR 47 Part 15 Subpart B IEC61000-4-2, IEC61000-4-3, IEC61000-4-4, IEC61000-4-5 IEC61000-4-6, IEC61000-4-8, IEC61000-4-11 Safety ……………………………………..…..…. Class I, IEC/EN/UL 62368-1 NOTE: 1. Add a 0.1uF ceramic capacitor and a 10uF E.L. capacitor to output for ripple&noise measuring @20MHz BW. 2. Voltage accuracy is set at 100% rated load and 25℃.Ta. 3. Line regulation is measured from High Line to Low Line with rated load. 4. Load regulation is measured from Full to 10% load. 5. Typical efficiency at 230 VAC and full load at 25°C. 6. No load power consumption
CFM300S120 价格&库存
很抱歉,暂时无法提供与“CFM300S120”相匹配的价格&库存,您可以联系我们找货
CFM300S120
  • 1+776.879281+97.16980
  • 5+739.951555+92.55099
  • 10+724.5867210+90.62920
  • 25+704.7488525+88.14794
  • 50+690.1087650+86.31680
  • 100+675.76998100+84.52334
库存:37
