V15
CFM40/60S SERIES
40/60 WATT OPEN FRAME
AC-DC MODULES
Features
* Universal Input Range 90~264VAC
* 2”x 4” Size
* Industry Standard Pin Out
* Efficiency to 87%
* Continuous Short Circuit Protection
* Meets EN55032 Class B and CISPR/FCC Class B
* Approved IEC/EN/UL62368-1
CFM40 Series
MODEL
OUTPUT
VOLTAGE
OUTPUT
CURRENT
RIPPLE &
NOISE
VOLTAGE
ACCURACY
LINE
REGULATION
LOAD
REGULATION
% EFF.
(Typ.)
CFM40S033
CFM40S050
CFM40S090
CFM40S120
CFM40S150
CFM40S240
CFM40S300
CFM40S360
CFM40S480
3.3 V
5V
9V
12 V
15 V
24 V
30 V
36 V
48 V
6A
6A
4.45 A
3.34 A
2.67 A
1.67 A
1.33 A
1.11 A
0.834 A
50mV
1%
1%
1%
1%
1%
1%
1%
1%
±1%
±1%
±1%
±1%
±1%
±1%
±1%
±1%
±1%
±0.5%
±0.5%
±0.5%
±0.5%
±0.5%
±0.5%
±0.5%
±0.5%
±0.5%
±1%
±1%
±1%
±1%
±1%
±1%
±1%
±1%
±1%
70%
76%
84%
85%
85%
85%
86%
87%
87%
CFM60 Series
MODEL
OUTPUT
VOLTAGE
OUTPUT
CURRENT
RIPPLE &
NOISE
VOLTAGE
ACCURACY
LINE
REGULATION
LOAD
REGULATION
% EFF.
(Typ.)
CFM60S033
CFM60S050
CFM60S090
CFM60S120
CFM60S150
CFM60S240
CFM60S300
CFM60S360
CFM60S480
3.3 V
5V
9V
12 V
15 V
24 V
30 V
36 V
48 V
8A
8A
6.67 A
5A
4A
2.5 A
2A
1.67 A
1.25 A
50mV
1%
1%
1%
1%
1%
1%
1%
1%
±1%
±1%
±1%
±1%
±1%
±1%
±1%
±1%
±1%
±0.5%
±0.5%
±0.5%
±0.5%
±0.5%
±0.5%
±0.5%
±0.5%
±0.5%
±1%
±1%
±1%
±1%
±1%
±1%
±1%
±1%
±1%
72%
77%
84%
85%
86%
86%
86%
88%
88%
1
V15
Specifications
CFM40/60S Series Derating Curve
Open Frame versions:
Voltage …....………........….......................................................... 90~264Vac
120~370Vdc
Frequency …………………………………………………………..... 47 to 63Hz
CFM40S033, 40S050, 40S090, 60S033, 60S050, 60S090
100%
Inrush Current ……………… Cold Start@25℃ ............. 50A max. @240Vac
Leakage Current ……………………………………..….…….…… 1mA Typical
OUTPUT SPECIFICATIONS:
Holdup Time …………………………..………………...… 8ms typ. @115Vac
Short Circuit Protection …………………..…… Hiccup Mode (Auto Recover)
Over Voltage Protection ………………………….. TVS Component to Clamp
Temperature Coefficient ……………………............................... ±0.05%/℃
Rated Load(%)
INPUT SPECIFICATIONS:
75%
20LFM(Natural Convection)
50%
25%
0%
GENERAL SPECIFICATIONS:
SAFETY AND EMC:
Emission and Immunity ……………. EN55032 Class B, FCC Part 15 Class B
EN61000-6-3, EN61000-3-2, EN61000-3-3
EN55024, EN61204-3, EN61000-6-1
Safety ……………………………. IEC/EN/UL62368-1, IEC/EN/UL60950-1
NOTE:
1. Add a 0.1uF ceramic capacitor and a 10uF E.L. capacitor to output for
ripple&noise measuring @20MHz BW.
2. Line regulation is measured from high line to low line with full load.
3. Load regulation is measured from full to 10% load.
4. Input connector mates with Molex housing 09-50-3031 and Molex
2878 series crimp terminal.
5. Output connector mates with Molex housing 09-50-3041 and Molex
6. Safety approvals do not apply to the covered versions, only to the openframe versions.
70
Rated Load(%)
75%
50%
25%
0%
40
50
Ambient Temperature(oC)
60
70
Covered versions: CFM40/60XXX-CA
CFM40S120, 40S150, 40S240, 40S300, 40S360, 40S480
100%
Rated Load(%)
MTBF ………….….… MIL-HDBK-217F, GB, 25℃/115VAC … 200Khrs min.
Altitude ……………………..……………………………….…….……… 2000m
Dimensions:
Open Frame ….… 4.000x2.000x1.200Inches (101.60x50.80x30.48mm)
-P …………..…… 4.000x2.000x1.275Inches (101.60x50.80x32.38mm)
Covered ….......... 4.606x2.441x1.5750Inches (117.00x62.00x40.00mm)
Weight ……………………………. CFM40/60: 170g/175g (0.38/0.39 Pounds)
CFM40/60 Covered: 210g/215g (0.46/0.47 Pounds)
60
CFM60S120, 60S150, 60S240, 60S300, 60S360, 60S480
100%
75%
50%
25%
0%
40
50
60
70
CFM40S033, CFM40S050, CFM60S033, CFM60S050
100%
Rated Load(%)
Isolation ………………………..……………..…… Input to Output = 4,242VDC
Operating Temperature ................................ 0 ~ 70℃(see Derating Curve)
Storage Temperature …………………………....….......…........ -20~85℃
Humidity ....................................................... 93% RH max. Non-Condensing
Cooling ………………………..………………………..... Natural Convection
Switching Frequency ……………………………….…….……. 66KHz Typical
40
50
75%
50%
25%
0%
40
50
60
70
Rated Load(%)
CFM40S090, 60S090, 60S120, 60S150, 60S240, 60S300
CFM60S360, 60S480
100%
75%
50%
25%
0%
10
40
50
60
70
V15
Mechanical Specification
All Dimensions are in inches(mm)
Tolerance:Inches:X.XXX±0.02
Millimeters:X.XX±0.5
CFM40SXXX-P/CFM60SXXX-P
CFM40SXXX/CFM60SXXX
CFM40SXXX/CFM60SXXX-CA
(Input and Output connector with PIN)
1.969 [50.00]
2.000 [50.80]
1.701 [43.20]
0.150 [3.80]
0.846 [21.50]
0.236 [6.00]
VR
2.362 [60.00]
PE
0.071 [1.80]
3.701 [94.00]
0.063 [1.60]
PE
0.236 [6.00]
0.039 [1.00]
0.039 [1.00]
Typical at 25˚C, nominal line and 75% load, unless otherwise Specified
3
1.701 [43.20]
0.370 [9.40]
2.441 [62.00]
4
.5*
x0
M3
0.197 [5.00]
8]
3.1
[Φ
0.197 [5.00]
0.063 [1.60]
0.098 [2.50]max
Vout(-)
1.575 [40.00]
5
.12
Φ0
4-
PE
Vout(+)
ACL
1.275[32.38]max
VR
0.17 [4.40]
PE
ACN
0.098 [2.50]max
-Vout
8]
3.1
[Φ
2.000 [50.80]
1.701 [43.20]
LED
+Vout
ACL
0.15 [3.80]
0.150 [3.80]
LED
ACN
5
.12
Φ0
4-
4.000 [101.60]
3.701 [94.00]
0.150 [3.80]
0.063 [1.60]
0.150 [3.80]
1.200 [30.48]max
3.520 [89.40]
0.150 [3.80]
0.246 [6.25]
0.150 [3.80]
0.156 [3.96]
0.657 [16.69]
4.000 [101.60]
0.614 [15.60]
0.311 [7.90]
4.606 [117.00]
很抱歉,暂时无法提供与“CFM40S240-P”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+221.876071+28.82058
