CHB150-48S12
CHB150-48S12
    CINCON
    半砖
    隔离模块 直流转换器 1 输出 12V 12.5A 36V - 75V 输入
CHB150-48S12 数据手册
V28 CHB150 SERIES ︳ 99 - 150 WATT WIDE INPUT DC-DC CONVERTERS SINGLE OUTPUT FEATURES * 99 - 150W Isolated Output * Efficiency to 89% * 500KHz Switching Frequency * 2:1 Input Range * Regulated Outputs * Continuous Short Circuit Protection * Five-Sided Metal Case * Half-Brick Size Meets Industrial Standard * UL60950-1 Approval * Without Tantalum Capacitor Inside (Except 3.3&5Vout) MODEL NUMBER INPUT OUTPUT OUTPUT CURRENT VOLTAGE VOLTAGE MIN. MAX. INPUT CURRENT % CAPACITOR NO LOAD FULL LOAD EFF. LOAD MAX. CHB150-48S33 36-75 VDC 3.3 VDC 0 mA 30 A 25 mA 2.5 A 82 30000uF CHB150-48S05 36-75 VDC 5 VDC 0 mA 30 A 25 mA 3.6 A 86 30000uF CHB150-48S12 36-75 VDC 12 VDC 0 mA 12.5 A 25 mA 3.5 A 89 12500uF CHB150-48S15 36-75 VDC 15 VDC 0 mA 10 A 25 mA 3.5 A 89 10000uF CHB150-48S24 36-75 VDC 24 VDC 0 mA 6.25 A 25 mA 3.5 A 89 6250uF NOTE: 1. Nominal Input Voltage 48VDC 1 V28 SPECIFICATIONS All Specifications Typical At Nominal Line, Full Load, and 25℃ Unless Otherwise Noted INPUT SPECIFICATIONS: GENRAL SPECIFICATIONS: Input Voltage Range ....……………..................... 48V.................. 36-75V Input Surge Voltage (100ms max.) ………..….… 48V ....... 100Vdc max. Under Voltage Lockout …...…... 48Vin Power Up ….....………. 34V 48Vin Power Down …….…. 32.5V Positive Logic Remote ON/OFF (note3&4) Input Filter ………………………………………………..….……... Pi Type Efficiency .................….......................................................…....... See Table Isolation Voltage ..................... Input/Output ....………..……. 1500VDC min. Input/Case, Output/Case …. 1500VDC min. Isolation Resistance .............................…................................ 107 ohm min. Isolation Capacitance …………………..……………….…..…… 1000pF typ. Switching Frequency ....................................…......................... 500KHz typ. OUTPUT SPECIFICATIONS: Operating Case Temperature …………..............……............ -40℃ to 100℃ Voltage Accuracy …........................................………............ ±1.0% max. Transient Response: 25% Step Load Change ………………..…
CHB150-48S12 价格&库存
很抱歉,暂时无法提供与“CHB150-48S12”相匹配的价格&库存,您可以联系我们找货
CHB150-48S12
  • 1+898.890661+112.43063
  • 5+865.405375+108.24239
  • 10+851.3473510+106.48405
  • 25+833.0782825+104.19901
  • 60+815.9649060+102.05852
库存:1
