EC2SA14NH
EC2SA14NH
    CINCON
    SIP5 模块
    隔离模块 直流转换器 2 输出 12V -12V 83mA,83mA 10.8V - 13.2V 输入
EC2SA14NH 数据手册
http://www.cincon.com REVISION: May 16, 2019 V10 ︳ EC2SANH SERIES 2WATT, UNREGULATED OUTPUT DC-DC CONVERTERS FEATURES * Industry Standard SIP-7 Packages * Efficiency up to 88% * 3000VDC Isolation * Unregulated Outputs * Industry Standard Pinout * No Tantalum Capacitors inside MODEL NUMBER INPUT VOLTAGE OUTPUT VOLTAGE OUTPUT INPUT CURRENT CURRENT % CAPACITOR LOAD MAX. NO LOAD FULL LOAD EFF. EC2SA01NH 5 VDC 5 VDC 400 mA 40 mA 488 mA 82 220uF EC2SA02NH 5 VDC 12 VDC 167 mA 50 mA 477 mA 84 220uF EC2SA03NH 5 VDC 15 VDC 134 mA 55 mA 473 mA 85 220uF EC2SA04NH 5 VDC ±12 VDC ±83 mA 50 mA 469 mA 85 100uF EC2SA05NH EC2SA06NH 5 VDC 5 VDC ±15 VDC ±5 VDC ±67 mA ±200 mA 45 mA 40 mA 462 mA 482 mA 87 83 EC2SA11NH 12 VDC 5 VDC 400 mA 20 mA 203 mA 82 100uF 100uF 220uF EC2SA12NH 12 VDC 12 VDC 167 mA 20 mA 192 mA 87 220uF EC2SA13NH 12 VDC 15 VDC 134 mA 20 mA 193 mA 87 220uF EC2SA14NH 12 VDC ±12 VDC ±83 mA 20 mA 193 mA 86 100uF EC2SA15NH 12 VDC ±15 VDC ±67 mA 20 mA 193 mA 87 100uF EC2SA16NH 12 VDC ±5 VDC ±200 mA 20 mA 198 mA 84 100uF 220uF EC2SA21NH 24 VDC 5 VDC 400 mA 10 mA 102 mA 82 EC2SA22NH 24 VDC 12 VDC 167 mA 10 mA 96 mA 87 220uF EC2SA23NH 24 VDC 15 VDC 134 mA 10 mA 95 mA 88 220uF EC2SA24NH 24 VDC ±12 VDC ±83 mA 10 mA 96 mA 87 100uF EC2SA25NH 24 VDC ±15 VDC ±67 mA 10 mA 95 mA 88 100uF EC2SA26NH 24 VDC ±5 VDC ±200 mA 10 mA 100 mA 83 100uF NOTE: 1. Nominal Input Voltage 5, 12 or 24 VDC 2. An External Input Capacitor 1uF tantalum for 24Vin Models are recommended to Reduce Input Ripple Voltage. 1 http://www.cincon.com REVISION: May 16, 2019 V10 SPECIFICATIONS All Specifications Typical At Nominal Line, Full Load, and 25℃Unless Otherwise Noted INPUT SPECIFICATIONS : GENERAL SPECIFICATIONS : Input Voltage Range ..............................……………………..... ±10% Input Surge Voltage (100ms max.) ………... 5V ................ 9Vdc max. 12V …......... 18Vdc max. 24V ……… 30Vdc max. Input Filter (note 5) ..………..……………………….…..……… Capacitive Efficiency .........................................…………..…………............ See Table Isolation Voltage .................................……....………......... 3000 VDC min. 9 Isolation Resistance .....................…….……..………..……… 10 ohm min. Isolation Capacitance …………………..…………………………….. 18 pF typ. Switching Frequency ..................................................................... 60KHz typ. OUTPUT SPECIFICATIONS : Operating Ambient Temperature Range ...………...…….... -40℃ to +105℃ Voltage Accuracy …………………....……………….........… ±3.0% max. De-rating, Above 85℃ …………………..……………… See Derating Curve Voltage Balance (Dual) …………………………………….... ±1.0% max. Ripple and Noise, 20MHz BW (note 3) ………….... 200mV pk-pk max. Temperature Coefficient ......................….…………...... ±0.05%/℃ max. Short Circuit Protection.....................…… Continuous, Self-Recovery Line Regulation (note 1) ….………...………….…………..... ±1.2% max. Load Regulation (note 2) …………..……...........………….... ±10% max. Case temperature (note 4) ……..………….………..…..…... +120℃ max. Cooling ……………………………………..….……….. Natural Convection Storage Temperature Range ...…............………....…....... -55℃ to +125℃ Humidity .......................................................... 95% RH max. Non condensing MTBF ……. MIL-HDBK-217F, GB …..…..………………….…… 3.3Mhrs min. Dimensions …….…….....…....…. 0.77x0.28x0.40 inches(19.6x7.2x10.2 mm) NOTE: Case Material ……………….……………….…… Non-conductive black plastic 1. Line regulation is per 1.0% change in input voltage. 2. Load regulation is for load change from 100% to 20%. 3. The output noise is measured with 0.33uF ceramic capacitor. 4. Maximum case temperature under any operating condition should Weight ………..……………………………………………………………….. 2.7g not be exceeded 120℃. 5. The EC2SA2XNH input terminal need to parallel with 1uF tantalum capacitor. Typical Derating curve for Natural Convection 120% 85 100% LOAD(%) CASE SIP-7 Dimensions: All Dimensions In Inches(mm) Tolerance Inches Millimeters X.XX±0.01 X.X±0.25 X.XXX±0.005 X.XX±0.13 ±0.002 ±0.05 Pin 80% 60% 40% 105 Natural Convection 20% 0% -40 -20 0 20 Pin 1 2 5 6 7 0.09 [2.3] PIN CONNECTION Single Output Dual Output +V Input +V Input -V Input -V Input -V Output -V Output No Pin Common +V Output +V Output 0.16 [4.1] 0.02 [0.5] 0.40 [10.2] 0.100 [2.54] 0.28 [7.2] 0.74 [18.8] 5 6 7 0.02 [0.5] 0.01 [0.3] 0.07 [1.8] 1 2 60 o 0.77 [19.6] 0.300[7.62] 40 Ambient Temperature( C) 2 80 100
EC2SA14NH 价格&库存
很抱歉,暂时无法提供与“EC2SA14NH”相匹配的价格&库存,您可以联系我们找货
