EC6AW-110D12
EC6AW-110D12
    CINCON
    DIP9 模块
    隔离模块 直流转换器 2 输出 12V -12V 416mA,416mA 43V - 160V 输入
EC6AW-110D12 数据手册
EC6AW-110 SERIES 10 WATT 4:1 INPUT ISOLATED DC-DC CONVERTER Features  Efficiency up to 88.5%  Fixed Switching Frequency  Regulated Outputs  Remote On/Off  Low No Load Power Consumption  Fully Protected (OCP/OVP/UVLO)  3000Vdc I/O Isolation  Operating Ambient Temperature -40 to +100℃  1.25”x0.8”x0.5” Size Meet Industrial Standard  Meets EN 50155 with External Circuits  UL 60950-1 2nd (Basic Insulation) Approval  Shock & Vibration Meets EN 50155 (EN 61373)  Fire & Smoke Meets EN 45545-2  3050m Operating Altitude  Safety Meets UL/IEC/EN 62368-1 OUTPUT CURRENT INPUT CURRENT % EFF. CAPACITOR MODEL INPUT OUTPUT NUMBER VOLTAGE VOLTAGE MIN. MAX. NO LOAD FULL LOAD (1) LOAD MAX. EC6AW-110S33 EC6AW-110S05 EC6AW-110S12 EC6AW-110S15 EC6AW-110D05 EC6AW-110D12 EC6AW-110D15 43-160 VDC 43-160 VDC 43-160 VDC 43-160 VDC 43-160 VDC 43-160 VDC 43-160 VDC 3.3 VDC 5 VDC 12 VDC 15 VDC ±5 VDC ±12 VDC ±15 VDC 0 mA 0 mA 0 mA 0 mA 0 mA 0 mA 0 mA 2500 mA 2000 mA 835 mA 666 mA ±1000mA ±416mA ±333mA 6 mA 6 mA 6 mA 6 mA 6 mA 6 mA 6 mA 89 mA 105 mA 104 mA 103 mA 107 mA 105 mA 104 mA 85 87 88 88.5 85 87 87.5 2500μF 2000μF 835μF 666μF 1000μF 416μF 333μF NOTE: 1. Nominal Input Voltage 110 VDC. 2. To meet EN50155 and RIA12 refer to application note. PART NUMBER Series EC6AW-110- Nominal Input Voltage II EC6AW-110 110:110 VDC Number of Outputs O S:Single D:Dual Nominal Output Voltage XX 3.3:3.3VDC 05:5.0VDC 12:12VDC 15:15VDC 05:±5 VDC Remote On/Off Logic L None:Positive N:Negative 12:±12 VDC 15:±15 VDC Part Number Example: EC6AW-110S12: 1.25”x0.8”, 10W, 4:1 43-160Vdc Input, Single 12Vdc Output, Positive Logic www.cincon.com 1 REVISION: V13 EC6AW-110 Series TECHNICAL SPECIFICATIONS (All specifications are typical at nominal input, full load at 25℃ unless otherwise noted.) ABSOLUTE MAXIMUM RATINGS PARAMETER NOTES and CONDITIONS Device Min. -0.3 Input Voltage Continuous All Input Surge Voltage 100ms max. All Operating Ambient Temperature with derating (see derating curve) All Operating Case Temperature At the center part of case plate All Storage Temperature Typ. -40 Max. Units 160 Vdc 200 Vdc 85 ℃ 100 ℃ 125 ℃ All -55 Device Min. Typ. Max. Units All 43 110 160 Vdc Vdc INPUT CHARACTERISTICS PARAMETER NOTES and CONDITIONS Operating Input Voltage Input Under Voltage Lockout Turn-On Voltage Threshold 100% Load All 38.5 40 41.5 Turn-Off Voltage Threshold 100% Load All 36.5 38 39.5 Lockout Hysteresis Voltage 100% Load All Maximum Input Current Vin=43V, full load All No-Load Input Current Vin=110V, Io=0A 2 290 mA See Model Number Table Input Filter Pi filter All Inrush Current (I2t) As per ETS300 132-2 All Input Reflected Ripple Current P-P thru 12uH inductor, 5Hz to 20MHz All Vdc Vdc mA 0.1 30 A2s mA OUTPUT CHARACTERISTICS PARAMETER NOTES and CONDITIONS Device Min. Voltage Set Point Accuracy Vin=Nominal, full load, Tc=25℃ All Output Voltage Balance Vin=Nominal, full load, Tc=25℃ Dual Typ. Max. Units -1.0 +1.0 % -2.0 +2.0 % Output Voltage Regulation Load Regulation Full load to no load Single ±0.5 Dual ±1.0 % Line Regulation Vin=High line to low line, full load All ±0.2 % Cross Regulation Load cross variation 25%/100% Dual ±5.0 % Temperature Coefficient Tc=-40℃ to 85℃ All ±0.02 %/℃ 3.3Vo 75 Output Voltage Ripple and Noise (5Hz to 20MHz bandwidth) Peak-to-Peak Full load, 1.0uF ceramic capacitors Output Current Range Vin=Nominal Over Current Protection Hiccup mode. Auto recovery www.cincon.com 75 100 15Vo 100 ±5Vo 75 ±12Vo 100 ±15Vo 100 See Model Number Table All Short Circuit Protection External Load Capacitance 5Vo 12Vo All Full load (resistive) 110 140 A 170 % Continuous, Auto Recovery See Model Number Table 2 mV uF REVISION: V13 EC6AW-110 PARAMETER Over Voltage Protection NOTES and CONDITIONS Zener or TVS clamp Device Min. Typ. 3.3Vo 3.9 5Vo 6.2 12Vo 15 15Vo 18 ±5Vo ±6.2 ±12Vo ±15 ±15Vo ±18 Series Max. Units Vdc EFFICIENCY PARAMETER NOTES and CONDITIONS 100% Load Vin=110V, Full load Device Min. Typ. Max. See Model Number Table Units % DYNAMIC CHARACTERISTICS PARAMETER NOTES and CONDITIONS Device Min. Typ. Max. Units Output Voltage Current Transient Error Band Recovery Time Turn-On Delay and Rise Time Turn-On Delay Time, From On/Off Control Turn-On Delay Time, From Input Output Voltage Rise Time 75% to 100% of Io_max. step load change di/dt=0.1A/us (within 1% Vout nominal) Full load (constant resistive load) All ±5 % All 250 us Von/off to 10%Vo_set, Remote on All 5 ms Vin_min. to 10%Vo_set, Power up All 5 ms 10%Vo_set to 90%Vo_set All 10 ms ISOLATION CHARACTERISTICS PARAMETER Isolation Voltage (100% factory Hi-Pot tested @2sec.) Isolation Resistance Isolation Capacitance NOTES and CONDITIONS Device 1 Minute; input to output All Input to output All Input to output All Min. Typ. Max. Units 3000 Vdc 1000 MΩ 1000 pF FEATURE CHARACTERISTICS PARAMETER NOTES and CONDITIONS Switching Frequency Output ripple frequency Device Min. Typ. Max. Units All 215 240 265 KHz 0 3.5 or Open Circuit 1.2 V 160 V 160 V 1.2 V 1 mA 30 uA 4 mA On/Off Control, Positive Remote On/Off Logic, Refer to -Vin Pin Logic Low (Module Off) Von/off at Ion/off=1.0mA All Logic High (Module On) Von/off at Ion/off=0.0uA, Pin open=On All On/Off Control, Negative Remote On/Off Logic, Refer to -Vin Pin Logic High (Module Off) Logic Low (Module On) On/Off Current (for Both Remote On/Off Logic) Leakage Current (for Both Remote On/Off Logic) Off Converter Input Current www.cincon.com Von/off at Ion/off=0.0uA, Pin open=Off All Von/off at Ion/off=1.0mA All Ion/off at Von/off=0V All Logic high, Von/off=15V All Shutdown input idle current All 3 3.5 or Open Circuit 0 0.3 2 REVISION: V13 EC6AW-110 Series GENERAL SPECIFICATIONS PARAMETER MTBF NOTES and CONDITIONS Device Io=100% of Io_max.; MIL-HDBK - 217F_Notice 1, GB, 25℃ Weight Typ. Max. Units All 1200 K hours All 16 grams Case Material Plastic, DAP, UL 94V-0 Base plate Material Plastic, LCP, UL 94V-0 Potting Material Shock/Vibration UL 94V-0 Base: Copper Plating: Nickel with Matte Tin MIL-STD-810F/EN6 1373 Compliant Humidity 95% RH max. Non Condensing Altitude 3050m Operating Altitude, 12000m Transport Altitude Thermal Shock MIL-STD-810F Fire & Smoke EN 45545-2 Compliant Pin Material Min. EMC SPECIFICATIONS (External components required, please refer to application note.) EMI Meet EN 55011/EN 55032/EN 50155 (with external filter) ESD EN 61000-4-2 Class A Level 3: Air ±8kV, Contact ±6kV Perf. Criteria A Radiated Immunity EN 61000-4-3 Level 3: 80~1000MHz, 20V/m Perf. Criteria A Fast Transient EN 61000-4-4 Level 4: On power input port, ±4kV, external components required Perf. Criteria A Surge EN 61000-4-5 Level 4: Line to line, ±2 kV, external components required Perf. Criteria A Conducted Immunity EN 61000-4-6 Level 3: 0.15~80MHz, 10V Perf. Criteria A Interruptions of Voltage Supply EN 50155 Class S3: 20ms interruptions Perf. Criteria A Supply Change Over EN 50155 Class C2: During a supply break of 30ms Application Note Link Packaging Information Link www.cincon.com Perf. Criteria A EC6AW-110 Series App Notes Packaging Information 4 REVISION: V13 EC6AW-110 Series Immunity to Environmental Conditions Phenomenon EN50155; 2017 Reference Clause(s) Reference Standard Test Conditions Class OT4 Temperature: -40℃ Duration: 2 hrs Class OT4 & Cycle B Temperature: 70℃ Duration: 6 hrs Extended temperature: 85℃ Extended Duration: 10min Result Low Temperature Start-up test 13.4.4 EN 60068-2-1 Dry Heat Test 13.4.5 EN 60068-2-2 Low Temperature Storage Test 13.4.6 EN 60068-2-1 Temperature: -40℃ Duration: 16 hrs Pass Cyclic Damp Heat Test 13.4.7 EN 60068-2-30 Temperature: 25℃ - 55℃ Humidity: 90% RH Duration: 48 hrs Pass EN 61373 Temperature: 25℃±10℃ Humidity: 50%±25% RH Frequency range: 5 ~ 150 Hz Vertical: 0.98 ⁄ Transverse: 0.44 ⁄ Longitudinal: 0.69 ⁄ Duration: 10 min / axis Pass EN 61373 Temperature: 25℃±10℃ Humidity: 50% ±25% RH Frequency range: 5 ~ 150 Hz Vertical: 5.72 ⁄ Transverse: 2.5 ⁄ Longitudinal: 3.96 ⁄ Duration: 5 hrs / axis Pass EN 61373 Temperature: 25℃±10℃ Humidity: 50% ±25% RH Frequency range: 5 ~ 150 Hz ±Vertical: 30 ⁄ ±-Transverse: 30 ⁄ ±Longitudinal: 50 ⁄ Duration: 30ms x18 (Each axis 3 shocks) Pass Random Vibration Test Simulated Long Life Test at Increased Random Vibration Levels Shock Test 13.4.11 13.4.11 13.4.11 Pass Pass EN45545-2 Fire & Smoke Test Conditions Item Standard EN 45545-2: 2013 EN ISO 4589-2: 2006 EN 45545-2: 2013 EN ISO 5659-2: 2013 EN 45545-2: 2013 NF X70-100: 2006 EN 45545-2: 2013 EN ISO 4589-2: 2006 EN 45545-2: 2013 EN ISO 5659-2: 2013 EN 45545-2: 2013 NF X70-100: 2006 EN45545-2: 2013 EN ISO 4589-2 EN 45545-2:2013 EN 60695-2-11:2001 EN 45545-2: 2013 EN 60695-11-10: 2013 Oxygen Index Test R22 Smoke Density Test Smoke Toxicity Test Oxygen Index Test R23 Smoke Density Test Smoke Toxicity Test R24 Oxygen Index Test R25 Glow - Wire Test R26 Vertical Flame Test www.cincon.com 5 Hazard Level HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 REVISION: V13 EC6AW-110 Series CHARACTERISTIC CURVE Power Derating Curve EC6AW-110S12 Derating Curve EC6AW-110S33 & 05 Derating Curve 100% 120% 67 -40 Output Power (%) Output Power (%) 120% 80% 60% 40% 20% 0% 69 -40 100% 80% 60% 40% 20% 0% -40 -20 0 20 40 60 80 100 -40 -20 Ambient Temperature (℃) EC6AW-110S15 Derating Curve -40 71 Output Power (%) Output Power (%) 40 60 80 100 120% 80% 60% 40% 20% 0% -40 100% 60 80% 60% 40% 20% 0% -40 -20 0 20 40 60 80 100 -40 -20 Ambient Temperature (℃) 0 20 40 60 80 100 Ambient Temperature (℃) EC6AW-110D15 Derating Curve EC6AW-110D12 Derating Curve 120% 120% 64 -40 100% Output Power (%) Output Power (%) 20 EC6AW-110D05 Derating Curve 120% 100% 0 Ambient Temperature (℃) 80% 60% 40% 20% 0% 100% -40 65 80% 60% 40% 20% 0% -40 -20 0 20 40 60 80 100 -40 Ambient Temperature (℃) www.cincon.com -20 0 20 40 60 80 100 Ambient Temperature (℃) 6 REVISION: V13 EC6AW-110 Series Performance Data EC6AW-110S33 Eff Vs Io @25 Deg. C EC6AW-110S33 Pd Vs Po @25 Deg. C 4 Power Dissipation (W) 100% Efficiency (%) 90% 80% 43V 70% 72V 60% 96V 110V 50% 160V 40% 10% 43V 72V 3 96V 110V 2 160V 1 0 20% 30% 40% 50% 60% 70% 80% 90% 100% 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) Output Power (%) EC6AW-110S05 Eff Vs Io @25 Deg. C EC6AW-110S05 Pd Vs Po @25 Deg. C 4 Power Dissipation (W) 100% Efficiency (%) 90% 80% 43V 70% 72V 60% 96V 110V 50% 160V 40% 10% 43V 72V 3 96V 110V 2 160V 1 0 20% 30% 40% 50% 60% 70% 80% 90% 100% 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) Output Power (%) EC6AW-110S12 Eff Vs Io @25 Deg. C EC6AW-110S12 Pd Vs Po @25 Deg. C 4 Power Dissipation (W) 100% Efficiency (%) 90% 80% 43V 70% 72V 60% 96V 110V 50% 160V 40% 10% 43V 72V 3 96V 110V 2 160V 1 0 20% 30% 40% 50% 60% 70% 80% 90% 100% 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) Output Power (%) EC6AW-110S15 Eff Vs Io @25 Deg. C EC6AW-110S15 Pd Vs Po @25 Deg. C 4 Power Dissipation (W) 100% Efficiency (%) 90% 80% 43V 70% 72V 60% 96V 110V 50% 160V 40% 10% 43V 72V 3 96V 110V 2 160V 1 0 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) www.cincon.com 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) 7 REVISION: V13 EC6AW-110 EC6AW-110D05 Eff Vs Io @25 Deg. C EC6AW-110D05 Pd Vs Po @25 Deg. C 4 Power Dissipation (W) 100% Efficiency (%) 90% 80% 43V 70% 72V 60% 96V 110V 50% 160V 40% 10% 43V 72V 3 96V 110V 2 160V 1 0 20% 30% 40% 50% 60% 70% 80% 90% 100% 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) Output Power (%) EC6AW-110D12 Eff Vs Io @25 Deg. C EC6AW-110D12 Pd Vs Po @25 Deg. C 3 Power Dissipation (W) 100% Efficiency (%) 90% 80% 43V 70% 72V 60% 96V 110V 50% 160V 40% 10% 43V 72V 2 96V 110V 160V 1 0 20% 30% 40% 50% 60% 70% 80% 90% 100% 0% 10% 20% 30% 40% 50% 60% 70% 80% 90%100% Output Power (%) Current Load (%) EC6AW-110D15 Eff Vs Io @25 Deg. C EC6AW-110D15 Pd Vs Po @25 Deg. C 3 Power Dissipation (W) 100% Efficiency (%) 90% 80% 43V 70% 72V 60% 96V 110V 50% 160V 40% 10% Series 43V 72V 96V 110V 160V 2 1 0 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) www.cincon.com 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) 8 REVISION: V13 EC6AW-110 Series MECHANICAL SPECIFICATION PIN CONNECTION SEE NOTE Pin Single Output Dual Output 1 Remote On/Off Remote On/Off 2,3 -V Input -V Input 9 NP Common 11 NC -V Output 14 +V Output +V Output 16 -V Output Common +V Input +V Input 2 3 0.10 [2.5] 23 22 BOTTOM VIEW 16 9 14 11 0.200 [5.08] 1.25 [31.8] 1 22,23 0.600 [15.24] 0.80 [20.3] 0.15 [3.8] * NC-NO CONNECTION WITH PIN * NP-NO PIN 0.50 [12.7] NOTE:Pin Size is 0.02±0.002 Inch (0.5±0.05 mm)DIA All Dimensions In Inches (mm) Tolerances Inches: X.XX= ±0.02 , X.XXX= ±0.010 Millimeters: X.X= ±0.5 , X.XX=±0.25 sales@cincon.com.tw www.cincon.com 9 REVISION: V13
EC6AW-110D12 价格&库存
很抱歉,暂时无法提供与“EC6AW-110D12”相匹配的价格&库存,您可以联系我们找货
