EC7BW-110S15
EC7BW-110S15
    CINCON
    DIP6 模块
    隔离模块 直流转换器 1 输出 15V 1.33A 43V - 160V 输入
EC7BW-110S15 数据手册
EC7BW-110 SERIES 20 WATT 4:1 INPUT ISOLATED DC-DC CONVERTER Features  Efficiency up to 90%  Fixed Switching Frequency  Regulated Outputs  Remote On/Off  Low No Load Power Consumption  Fully protected (OCP/OVP/UVLO)  3000Vdc I/O Isolation  Operating Case Temperature -40 to +105℃  2”x1”x0.4” Size Meet Industrial Standard  UL 60950-1 2nd (Basic Insulation) Approval  EN 50155 Compliant with External Circuits  Shock & Vibration EN 50155 (EN 61373) Compliant  Fire & Smoke EN 45545-2 Compliant  4000m Operating Altitude  Safety Meets IEC/EN/UL 62368-1 OUTPUT CURRENT INPUT CURRENT % EFF. CAPACITOR NO LOAD FULL LOAD (1) LOAD MAX. 205.4 mA 88.5 5600uF 3 mA 202.0 mA 90 1000uF 1330 mA 3 mA 203.1 mA 89.5 1000uF 0 mA ±833 mA 3 mA 204.3 mA 89 680uF 0 mA ±667 mA 3 mA 205.4 mA 88.5 350uF MODEL INPUT OUTPUT NUMBER VOLTAGE VOLTAGE MIN. MAX. EC7BW-110S05 43-160 VDC 5 VDC 0 mA 4000 mA 3 mA EC7BW-110S12 43-160 VDC 12 VDC 0 mA 1670 mA EC7BW-110S15 43-160 VDC 15 VDC 0 mA EC7BW-110D12 43-160 VDC ±12 VDC EC7BW-110D15 43-160 VDC ±15 VDC NOTE: 1. Nominal input voltage 110 VDC. 2. To meet EN50155 and RIA12 refer to application note. PART NUMBER Series EC7BW- Nominal Input Voltage II Number of Outputs O EC7BW 110:110 VDC S:Single D:Dual Nominal Output Voltage XX 05: 5.0VDC 12: 12VDC 15: 15VDC 12: ±12VDC 15: ±15VDC Remote On/Off Logic L None:Positive N:Negative Part Number Example: EC7BW-110S12N: 2”x1”, 20W, 4:1 43-160Vdc Input, Single 12Vdc Output, Negative Logic www.cincon.com 1 REVISION: V15 EC7BW-110 Series TECHNICAL SPECIFICATIONS (All specifications are typical at nominal input, full load at 25℃ unless otherwise noted.) ABSOLUTE MAXIMUM RATINGS PARAMETER NOTES and CONDITIONS Device Min. -0.3 Input Voltage Continuous All Input Surge Voltage 100ms max. All Operating Ambient Temperature with derating All Operating Case Temperature At the center part of case All Storage Temperature Typ. -40 Max. Units 160 Vdc 200 Vdc 85 ℃ 105 ℃ 125 ℃ All -55 Device Min. Typ. Max. Units All 43 110 160 Vdc Turn-On Voltage Threshold All 38.5 40.0 41.5 Vdc Turn-Off Voltage Threshold All 36.5 38.0 39.5 Vdc Lockout Hysteresis Voltage All INPUT CHARACTERISTICS PARAMETER NOTES and CONDITIONS Operating Input Voltage Input Under Voltage Lockout Maximum Input Current Vin=43V, Full load No-Load Input Current Vin=110V, Io=0A 2 All Vdc 540 mA See Model Number Table Input Filter Pi filter All Inrush Current (I2t) As per ETS300 132-2. All Input Reflected Ripple Current P-P thru 12uH inductor, 5Hz to 20MHz All mA 0.1 30 A2s mA OUTPUT CHARACTERISTICS PARAMETER NOTES and CONDITIONS Device Min. Voltage Set Point Accuracy Vin=110V, Full load, Tc=25℃ All Output Voltage Balance Vin=110V, Full load, Tc=25℃ Dual Typ. Max. Units -1.5 +1.5 % -1.0 +1.0 % Output Voltage Regulation Load Regulation Full Load to no load Single ±0.5 Dual ±1.0 % Line Regulation Vin=High line to low line, full load All ±0.2 % Cross Regulation Load cross variation 10%/100% Dual ±5.0 % Temperature Coefficient Tc=-40℃ to 85℃ All ±0.03 %/℃ Output Voltage Ripple and Noise (5Hz to 20MHz bandwidth) Peak-to-Peak Full load, 1uF ceramic capacitors RMS. Output Current Range Vin= 43 to 160V Over Current Protection Hiccup Mode. Auto recovery 15Vo 100 ±12Vo 100 ±15Vo 100 All 40 See Model Number Table 110 All External Load Capacitance Full load (resistive) Output Voltage Trim Range Po≦max. rated power, Io ≦ Io_max. www.cincon.com 75 100 All Short Circuit Protection Over Voltage Protection 5Vo 12Vo 125 Zener or TVS clamp 2 mV mA 160 % Continuous, Auto Recovery See Model Number Table Single mV -10 uF +10 5Vo 6.2 12Vo 15 15Vo 18 ±12Vo ±15 ±15Vo ±18 % Vdc REVISION: V15 EC7BW-110 Series EFFICIENCY PARAMETER NOTES and CONDITIONS 100% Load Vin=110, Full load Device Min. Typ. Max. See Model Number Table Units % DYNAMIC CHARACTERISTICS PARAMETER NOTES and CONDITIONS Device Min. Typ. Max. Units Output Voltage Current Transient Error Band Recovery Time Turn-On Delay and Rise Time Turn-On Delay Time, From On/Off Control Turn-On Delay Time, From Input Output Voltage Rise Time 75% to 100% of Io_max. step load change di/dt=0.1A/us (within 1% Vout nominal) All ±5 % All 250 us Von/off to 10%Vo_set, Remote on All 7 ms ms Vin_min. to 10%Vo_set, Power up 10%Vo_set to 90%Vo_set All 7 Single 8 Dual 18 ms ISOLATION CHARACTERISTICS PARAMETER Isolation Voltage (100% factory Hi-Pot tested @2sec.) Isolation Resistance Isolation Capacitance NOTES and CONDITIONS 1 minute; Input to output Device Min. Typ. All Input to output All Input to output All Max. Units 3000 Vdc 1000 MΩ 1000 pF FEATURE CHARACTERISTICS PARAMETER NOTES and CONDITIONS Switching Frequency Output ripple frequency Device Min. Typ. Max. Units All 225 250 275 KHz On/Off Control, Positive Remote On/Off Logic, Refer to -Vin Pin Logic Low (Module Off) Von/off at Ion/off=1.0mA All 0 1.2 V Logic High (Module On) Von/off at Ion/off=0.0uA, Pin open=On All 3.5 75 V Von/off at Ion/off=0.0uA, Pin open=Off All 3.5 75 V Von/off at Ion/off=1.0mA All 0 1.2 V Ion/off at Von/off=0V All 1 mA Logic high, Von/off=15V All 30 uA Shutdown input idle current All 2 5 mA Typ. Max. Units On/Off Control, Negative Remote On/Off Logic, Refer to -Vin Pin Logic High (Module Off) Logic Low (Module On) On/Off Current (for Both Remote On/Off Logic) Leakage Current (for Both Remote On/Off Logic) Off Converter Input Current 0.3 GENERAL SPECIFICATIONS PARAMETER MTBF NOTES and CONDITIONS Io=100% of Io_max.; MIL-HDBK - 217F_Notice 1, GB, 25℃ Weight Case Material Copper Base plate Material Plastic DAP Potting Material UL 94V-0 Base: Copper Plating: Nickel with Matte Tin MIL-STD-810F/EN 61373 Compliant Pin Material Shock/Vibration Device All 880 K hours All 35 grams Humidity 95% RH max. Non Condensing Altitude 4000m Operating Altitude, 12000m Transport Altitude Thermal Shock MIL-STD-810F Fire & Smoke EN 45545-2 Compliant www.cincon.com 3 Min. REVISION: V15 EC7BW-110 Series EMC SPECIFICATIONS (External components required, please refer to application note.) EMI EN 50155 Compliant (with external filter) ESD EN 61000-4-2 Level 3: Air ±8kV, Contact ±6kV Perf. Criteria A Radiated Immunity EN 61000-4-3 Level 3: 80~1000MHz, 20V/m Perf. Criteria A Fast Transient EN 61000-4-4 Level 4: On power input port, ±2kV, external components required Perf. Criteria A Surge EN 61000-4-5 Level 3: Line to line, ±1kV, external components required Perf. Criteria A Conducted Immunity EN 61000-4-6 Level 3: 0.15~80MHz, 10V Perf. Criteria A EN 50155 Class S3: 20ms interruptions, with external hold up circuit and Perf. Criteria A capacitor required EN 50155 Class C2: During a supply break of 30ms, with external hold up Perf. Criteria A circuit and capacitor required EC7BW-110 Series App Notes Interruptions of Voltage Supply Supply Change Over Application Note Link Class A Packaging Information Link Packaging Information Immunity to Environmental Conditions Phenomenon EN50155; 2017 Reference Clause(s) Reference Standard Low Temperature Start-up test 13.4.4 EN 60068-2-1 Dry Heat Test 13.4.5 EN 60068-2-2 Low Temperature Storage Test 13.4.6 EN 60068-2-1 Cyclic Damp Heat Test 13.4.7 EN 60068-2-30 Random Vibration Test 13.4.11 EN 61373 Simulated Long Life Test at Increased Random Vibration Levels 13.4.11 EN 61373 Shock Test 13.4.11 EN 61373 www.cincon.com 4 Test Conditions Class OT4 Temperature: -40℃ Duration: 2 hrs Class OT4 & Cycle B Temperature: 70℃ Duration: 6 hrs Extended temperature: 85℃ Extended Duration: 10min Temperature: -40℃ Duration: 16 hrs Temperature: 25℃- 55℃ Humidity: 90% RH Duration: 48 hrs Frequency range: 5 ~ 150 Hz Vertical: 1.01 ⁄ Transverse: 0.450 ⁄ Longitudinal: 0.700 ⁄ Duration: 10 min / axis Frequency range: 5 ~ 150 Hz Vertical: 5.72 ⁄ Transverse: 2.55 m⁄s Longitudinal: 3.96 ⁄ Duration: 5 hrs / axis ±Vertical: 30 m⁄s ±Transverse: 30 ⁄ ±Longitudinal: 50 ⁄ Duration: 30ms x18 (Each axis 3 shocks) Result Pass Pass Pass Pass Pass Pass Pass REVISION: V15 EC7BW-110 Series EN45545-2 Fire & Smoke Test Conditions Item Standard Oxygen Index Test R22 Smoke Density Test Smoke Toxicity Test Oxygen Index Test R23 Smoke Density Test Smoke Toxicity Test R24 Oxygen Index Test R25 Glow - Wire Test R26 Vertical Flame Test Hazard Level EN 45545-2: 2020 EN ISO 4589-2: 2017 EN 45545-2: 2020 EN ISO 5659-2: 2017 EN 45545-2: 2020 EN 17084 Method 2: 2018 EN 45545-2: 2020 EN ISO 4589-2: 2017 EN 45545-2: 2020 EN ISO 5659-2: 2017 EN 45545-2: 2020 EN 17084 Method 2: 2018 EN 45545-2: 2013 EN ISO 4589-2 EN 45545-2:2013+A1:2016 EN 60695-2-11:2014 EN 45545-2: 2013+A1:2015 EN 60695-11-10: 2013 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 CHARACTERISTIC CURVE Power Derating Curve EC7BW-110 Derating Curve (Vin=110V) Output Power (%) 120% -40 100% 73 80% 60% 40% Natural Convection 20% 105 0% -40 -20 0 20 40 60 80 100 Ambient Temperature (℃) Performance Data EC7BW-110S05 Eff Vs Io @25 Deg. C EC7BW-110S05 Pd Vs Po @25 Deg. C 5 Power Dissipation (W) Efficiency (%) 100% 90% 80% 43V 110V 70% 160V 60% 10% 43V 4 110V 160V 3 2 1 0 20% 30% 40% 50% 60% 70% 80% 90% 100% 0% Current Load (%) www.cincon.com 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) 5 REVISION: V15 EC7BW-110 Series EC7BW-110S12 Eff Vs Io @25 Deg. C EC7BW-110S12 Pd Vs Po @25 Deg. C 5 Power Dissipation (W) Efficiency (%) 100% 90% 80% 43V 110V 70% 160V 60% 10% 43V 4 110V 160V 3 2 1 0 20% 30% 40% 50% 60% 70% 80% 90% 100% 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) Output Power (%) EC7BW-110S15 Eff Vs Io @25 Deg. C EC7BW-110S15 Pd Vs Po @25 Deg. C 5 Power Dissipation (W) Efficiency (%) 100% 90% 80% 43V 110V 70% 160V 60% 10% 43V 4 110V 160V 3 2 1 0 20% 30% 40% 50% 60% 70% 80% 90% 100% 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) Output Power (%) EC7BW-110D12 Eff Vs Io @25 Deg. C EC7BW-110D12 Pd Vs Po @25 Deg. C 5 Power Dissipation (W) 100% Efficiency (%) 90% 80% 70% 43V 60% 110V 50% 40% 10% 160V 43V 4 110V 160V 3 2 1 0 20% 30% 40% 50% 60% 70% 80% 90% 100% 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) Output Power (%) EC7BW-110D15 Eff Vs Io @25 Deg. C EC7BW-110D15 Pd Vs Po @25 Deg. C 5 Power Dissipation (W) 100% Efficiency (%) 90% 80% 70% 43V 60% 110V 50% 40% 10% 160V 43V 4 110V 160V 3 2 1 0 20% 30% 40% 50% 60% 70% 80% 90% 100% 0% Current Load (%) www.cincon.com 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) 6 REVISION: V15 EC7BW-110 Series MECHANICAL SPECIFICATION 0.10 [2.5] 1.00 [25.4] 0.400 0.400 [10.16] [10.16] 5 4 Pin BOTTOM VIEW 1 2 3 4 5 6 0.04 [1.0] 1.800 [45.72] 2.00 [50.8] 3 0.10 [2.5] 1 2 6 0.600 [15.24] -V Input -V Input +V Output +V Output Trim -V Output Common -V Output Remote On/Off NOTE: Pin Size is 0.04±0.004 Inch (1.0±0.1 mm)DIA All Dimensions In Inches (mm) Tolerances Inches: X.XX= ±0.02 , X.XXX= ±0.010 Millimeters: X.X= ±0.5 , X.XX= ±0.25 0.20 [5.1] 0.200 [5.08] PIN CONNECTION Single Dual +V Input +V Input 0.40 [10.2] 0.22 min. [5.6] CINCON Electronics Co. Ltd. Add: 14F, No. 306, Sec.4, Hsin Yi Rd., Taipei, Taiwan Tel: 886-2-27086210 Fax: 886-2-27029852 E-mail: sales@cincon.com.tw Web: www.cincon.com 7 REVISION: V15
EC7BW-110S15 价格&库存
很抱歉,暂时无法提供与“EC7BW-110S15”相匹配的价格&库存,您可以联系我们找货
