CFM500M180
CFM500M180
    CINCON
    AC/DC CONVERTER 18V 500W
CFM500M180 数据手册
CFM500M SERIES 500 WATT MEDICAL AC-DC POWER SUPPLY WITH PFC Features  Universal Input Range 80~264Vac  High Efficiency up to 94.5%  3”x 5” Compact Size  Class I & II  No Load Power Consumption95% Reduction Criterion A Voltage Interruptions IEC 61000-4-11:2020, >95% Reduction Criterion B Application Note Link CFM500M Series App Notes CHARACTERISTIC CURVE Power Derating Curve Forced Air Flow Forced Air Flow Output power & Input voltage Output power vs Ambient Temperature Output Power (W) Output Power (W) 500 Forced Air Flow @Ta. 50℃ 450 400 350 80 100 120 140 160 180 Input voltage(V) 200 220 240 260 500 450 400 350 300 250 200 150 100 50 0 Forced Air Flow @ 230Vac -40 -20 Natural Convection Output power & Input Voltage Output Power (W) Output Power (W) 350 300 250 200 80 100 120 140 160 180 200 220 240 260 60 80 500 450 400 350 300 250 200 150 100 50 0 CFM500M120 @ 230Vac CFM500M120C @ 230Vac CFM500M120 @ 115Vac CFM500M120C @ 115Vac -40 -20 0 20 40 60 80 Ambient Temperature (℃) Input Voltage(V) www.cincon.com 40 Output power vs Ambient Temperature CFM500M120 @Ta. 30℃ CFM500M120C @Ta. 30℃ CFM500M120 @Ta. 50℃ CFM500M120C @Ta. 50℃ 400 20 Natural Convection 500 450 0 Ambient Temperature (℃) 4 REVISION: V15 CFM500M Output power & Input Voltage Output power vs Ambient Temperature Output Power (W) Output Power (W) 500 450 400 350 300 CFM500M180 @Ta. 30℃ CFM500M180C @Ta. 30℃ CFM500M180 @Ta. 50℃ CFM500M180C @Ta. 50℃ 250 200 80 100 120 140 160 180 200 220 240 260 500 450 400 350 300 250 200 150 100 50 0 CFM500M180 @ 230Vac CFM500M180C @ 230Vac CFM500M180 @ 115Vac CFM500M180C @ 115Vac -40 -20 Output power & Input Voltage Output Power (W) Output Power (W) 450 400 350 CFM500M240 @Ta. 30℃ CFM500M240C @Ta. 30℃ CFM500M240 @Ta. 50℃ CFM500M240C @Ta. 50℃ 200 80 100 120 140 160 180 200 220 240 260 500 450 400 350 300 250 200 150 100 50 0 CFM500M240 @ 115Vac CFM500M240C @ 115Vac -40 -20 Output Power (W) Output Power (W) 400 350 CFM500M360 @Ta. 30℃ CFM500M360C @Ta. 30℃ CFM500M360 @Ta. 50℃ CFM500M360C @Ta. 50℃ 100 120 140 160 180 200 220 240 260 40 60 80 500 450 400 350 300 250 200 150 100 50 0 CFM500M360 @ 230Vac CFM500M360C @ 230Vac CFM500M360 @ 115Vac CFM500M360C @ 115Vac -40 -20 0 20 40 60 80 Ambient Temperature (℃) Output power & Input Voltage Output power vs Ambient Temperature Output Power (W) Output Power (W) 20 Input Voltage(V) 500 450 400 350 300 CFM500M480 @Ta. 30℃ CFM500M480C @Ta. 30℃ CFM500M480 @Ta. 50℃ CFM500M480C @Ta. 50℃ 250 200 80 0 Output power vs Ambient Temperature 450 80 80 CFM500M240C @ 230Vac Output power & Input Voltage 200 60 Ambient Temperature (℃) 500 250 40 CFM500M240 @ 230Vac Input Voltage(V) 300 20 Output power vs Ambient Temperature 500 250 0 Ambient Temperature (℃) Input Voltage(V) 300 Series 100 120 140 160 180 200 220 240 260 CFM500M480 @ 230Vac CFM500M480C @ 230Vac CFM500M480 @ 115Vac CFM500M480C @ 115Vac -40 -20 0 20 40 60 80 Ambient Temperature (℃) Input Voltage(V) www.cincon.com 500 450 400 350 300 250 200 150 100 50 0 5 REVISION: V15 Conduction Convection with External Baseplate (48x24.8x0.12cm) CFM500M Output power & Input Voltage Output power vs Ambient Temperature Output Power (W) Output Power (W) 500 450 400 350 CFM500M120 @Ta. 30℃ 300 CFM500M120C @Ta. 30℃ CFM500M120 @Ta. 50℃ 250 CFM500M120C @Ta. 50℃ 200 80 100 120 140 160 180 200 220 240 260 500 450 400 350 300 250 200 150 100 50 0 CFM500M120 @ 230Vac CFM500M120C @ 230Vac CFM500M120 @ 115Vac CFM500M120C @ 115Vac -40 -20 Output power & Input Voltage Output Power (W) Output Power (W) 450 400 350 CFM500M180 @Ta. 30℃ CFM500M180C @Ta. 30℃ CFM500M180 @Ta. 50℃ CFM500M180C @Ta. 50℃ 200 80 100 120 140 160 180 200 220 240 260 500 450 400 350 300 250 200 150 100 50 0 CFM500M180 @ 115Vac CFM500M180C @ 115Vac -40 -20 Output Power (W) Output Power (W) 400 350 CFM500M240 @Ta. 30℃ CFM500M240C @Ta. 30℃ CFM500M240 @Ta. 50℃ CFM500M240C @Ta. 50℃ 100 120 140 160 180 200 220 240 260 500 450 400 350 300 250 200 150 100 50 0 Output Power (W) Output Power (W) 400 350 CFM500M360 @Ta. 30℃ CFM500M360C @Ta. 30℃ CFM500M360 @Ta. 50℃ CFM500M360C @Ta. 50℃ 100 120 140 160 180 200 220 240 260 CFM500M240 @ 115Vac CFM500M240C @ 115Vac -40 -20 0 20 40 60 80 500 450 400 350 300 250 200 150 100 50 0 CFM500M360 @ 230Vac CFM500M360C @ 230Vac CFM500M360 @ 115Vac CFM500M360C @ 115Vac -40 -20 0 20 40 60 80 Ambient Temperature (℃) Input Voltage(V) www.cincon.com 80 Output power vs Ambient Temperature 450 80 60 Ambient Temperature (℃) 500 200 40 CFM500M240C @ 230Vac Output power & Input Voltage 250 20 CFM500M240 @ 230Vac Input Voltage(V) 300 0 Output power vs Ambient Temperature 450 80 80 Ambient Temperature (℃) 500 200 60 CFM500M180C @ 230Vac Output power & Input Voltage 250 40 CFM500M180 @ 230Vac Input Voltage(V) 300 20 Output power vs Ambient Temperature 500 250 0 Ambient Temperature (℃) Input Voltage(V) 300 Series Conduction Convection with External Baseplate (48x24.8x0.12cm) 6 REVISION: V15 CFM500M Output power & Input Voltage Output power vs Ambient Temperature Output Power (W) Output Power (W) 500 450 400 350 CFM500M480 @Ta. 30℃ 300 CFM500M480C @Ta. 30℃ 250 CFM500M480 @Ta. 50℃ CFM500M480C @Ta. 50℃ 200 80 100 120 140 160 180 200 220 Series 240 260 500 450 400 350 300 250 200 150 100 50 0 CFM500M480 @ 230Vac CFM500M480C @ 230Vac CFM500M480 @ 115Vac CFM500M480C @ 115Vac -40 -20 0 20 40 60 80 Ambient Temperature (℃) Input Voltage(V) Output Power vs Case Temperature (Tc) Output Power (W) 500 400 300 200 100 0 -40 -20 0 20 40 Case Temperature (℃) 60 80 Performance Data CFM500M120 (Eff Vs Io) CFM500M180 (Eff Vs Io) 95% 95% Efficiency (%) 100% Efficiency (%) 100% 90% 85% 80% 115V 75% 230V 70% 10% 20% 30% 40% 50% 60% 70% 80% 90% 85% 80% 115V 75% 230V 70% 10% 90% 100% 20% 30% Current Load (%) CFM500M240 (Eff Vs Io) Efficiency (%) 95% Efficiency (%) 95% 90% 85% 80% 115V 75% 40% 50% 60% 70% 80% 90% 100% Current Load (%) www.cincon.com 70% 80% 90% 100% 90% 85% 80% 115V 75% 230V 30% 60% CFM500M360 (Eff Vs Io) 100% 20% 50% Current Load (%) 100% 70% 10% 40% 70% 10% 230V 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) 7 REVISION: V15 CFM500M Series CFM500M480 (Eff Vs Io) 100% Efficiency (%) 95% 90% 85% 80% 115V 75% 70% 10% 230V 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) www.cincon.com 8 REVISION: V15 CFM500M Series MECHANICAL SPECIFICATION CFM500MXXX www.cincon.com 9 REVISION: V15 CFM500M Series MECHANICAL SPECIFICATION CFM500MXXXC sales@cincon.com.tw www.cincon.com 10 REVISION: V15
CFM500M180 价格&库存
很抱歉,暂时无法提供与“CFM500M180”相匹配的价格&库存,您可以联系我们找货
CFM500M180
  • 1+1301.610501+167.69200
  • 5+1212.059005+156.15470
  • 25+1033.0437025+133.09140
  • 100+936.56314100+120.66140
库存:13
CFM500M180
  • 1+1207.72976
  • 5+1124.65035
  • 25+958.56341
  • 100+869.03983
库存:13
