CFB600W-110S12
CFB600W-110S12
    CINCON
    全砖
    隔离模块 直流转换器 1 输出 12V 50A 43V - 160V 输入
CFB600W-110S12 数据手册
CFB600W-110S SERIES 600 WATT 4:1 INPUT ISOLATED DC-DC CONVERTER Features ⚫ Efficiency Up to 88% ⚫ Fixed Switching Frequency ⚫ Regulated Outputs ⚫ Remote On/Off ⚫ Fully Protected (OTP/OCP/OVP/UVLO) ⚫ 2250Vdc I/O Isolation ⚫ Operating Case Temperature -40 to +100℃ ⚫ Full-Brick Size Meet Industrial Standard 4.60”x2.40”x0.5” ⚫ UL 60950-1 2nd (Basic Insulation) Approval ⚫ EN 50155 Compliant with External Circuits ⚫ Shock & Vibration EN 50155 (EN 61373) Compliant ⚫ Fire & Smoke EN 45545-2 Compliant ⚫ 2000m Operating Altitude ⚫ Safety Meets IEC/EN 62368-1 OUTPUT CURRENT INPUT CURRENT MODEL INPUT OUTPUT NUMBER VOLTAGE VOLTAGE MIN. MAX. NO LOAD FULL LOAD CFB600W-110S12 43-160 VDC 12 VDC 0 mA 50 A 25 mA 6.3 A 87 10000uF CFB600W-110S24 43-160 VDC 24 VDC 0 mA 25 A 25 mA 6.2 A 88 10000uF CFB600W-110S28 43-160 VDC 28 VDC 0 mA 21.4 A 25 mA 6.2 A 88 10000uF CFB600W-110S48 43-160 VDC 48 VDC 0 mA 12.5 A 25 mA 6.2 A 88 10000uF % EFF. CAPACITOR LOAD MAX. NOTE: 1. Nominal Input Voltage 110 VDC 2. Measure at Nominal Input Voltage. 3. An External Input Capacitor 220uf For All Models Are Recommended To Reduce Input Ripple Voltage. 3. The Output Terminal Required a Minimum Capacitor 470uF to Maintain Specified Regulation. PART NUMBER Nominal Input Voltage II Series CFB600W- CFB600W 110:110 VDC Number of Outputs O S:Single Nominal Output Voltage XX 12:12VDC Remote On/Off Logic L 24:24VDC None: Negative 28:28VDC 48:48VDC P: Positive Mounting Inserts -Y (Option) None: Clear Mounting Inserts (3.5mm DIA.) -C0: M3x0.5 Mounting Inserts Part Number Example: CFB600W-24S28P: Full Brick, 600W, 4:1 43-160Vdc Input, Single 28Vdc Output, Positive Logic, Clear Mounting Insert www.cincon.com 1 REVISION: V12 CFB600W-110S Series TECHNICAL SPECIFICATIONS (All specifications are typical at nominal input, full load at 25°C unless otherwise noted.) ABSOLUTE MAXIMUM RATINGS PARAMETER NOTES and CONDITIONS Device Min. Input Voltage Input Surge Voltage Continuous All -0.3 100ms max. All Operating Case Temperature At the center part of base plate All All Device Min. All Storage Temperature Typ. Max. Units 160 Vdc 180 Vdc -40 100 ℃ -55 105 ℃ Typ. Max. Units 43 110 160 Vdc INPUT CHARACTERISTICS PARAMETER NOTES and CONDITIONS Operating Input Voltage Input Under Voltage Lockout Turn-On Voltage Threshold Full load All 41 42 43 Vdc Turn-Off Voltage Threshold Full load All 39 40 41 Vdc Lockout Hysteresis Voltage Full load All 2.0 Vdc Maximum Input Current Vin=43, Full load All 16 A No-Load Input Current Vin=110V, Io=0A Input Filter Pi Filter All Inrush Current (I2t) As per ETS300 132-2 All Input Reflected Ripple Current P-P Thru 12uH Inductor, 5Hz to 20MHz All See Model Number Table mA 1.0 90 A2s mA OUTPUT CHARACTERISTICS PARAMETER NOTES and CONDITIONS Device Min. Voltage Set Point Accuracy Vin=110V, Full load, TC=25℃ All -1.0 Load Regulation Full load to no load Line Regulation Vin=High line to low line, full load Temperature Coefficient TC=-40℃ to 100℃ Typ. Max. Units +1.0 % All ±0.5 % All ±0.2 % All ±0.03 %/℃ 12Vo 120 24Vo 240 28Vo 280 48Vo 480 12Vo 60 24Vo 100 28Vo 100 Output Voltage Regulation Output Voltage Ripple and Noise (5Hz to 20MHz Bandwidth) Peak-to-Peak Full Load, 10uF tantalum capacitor and 1uF ceramic capacitors, 48Vo: 10uF aluminum capacitor and 1.0uF ceramic capacitors RMS. 48Vo Vin= 43 to 160V Over Current Protection Continuous current. Auto recovery All 105 Over Voltage Protection Limited voltage, % of nominal Vo All 115 External Load Capacitance See Model Number Table All Auxiliary Output Current 7 All Vout Ready: Low level, sink current Vout not Ready: Open drain output, applied voltage All Output Voltage Trim Range Po≦max. Rated Power, Io ≦ Io_max. All Output Voltage Remote Sense Range Po≦max. rated power, Io ≦ Io_max. % of nominal Vo All www.cincon.com 140 % 140 % uF See Model Number Table Auxiliary Output Voltage Power Good Signal (IOG) 125 A Continuous, Auto Recovery All Full Load (Resistive) 2 mV 200 Output Current Range Short Circuit Protection mV -40 10 13 V 20 mA 20 mA 50 V +10 % +10 % REVISION: V12 CFB600W-110S PARAMETER NOTES and CONDITIONS Load Share Accuracy (50%-100% load) Device Min. All -10 Device Min. Typ. Series Max. Units +10 % Max. Units EFFICIENCY PARAMETER NOTES and CONDITIONS 100% Load Vin=110V Typ. See Model Number Table % DYNAMIC CHARACTERISTICS PARAMETER NOTES and CONDITIONS Device Min. Typ. Max. Units ±3 ±5 % Output Voltage Current Transient Error Band Recovery Time Turn-On Delay and Rise Time Turn-On Delay Time, From On/Off Control Turn-On Delay Time, From Input Output Voltage Rise Time 75% to 100% of Io_max. Step load change di/dt=0.1A/us (within 1% Vout nominal) Full load (constant resistive load) All All 500 us Von/off to 10%Vo_set, Remote on All 75 ms Vin_min. to 10%Vo_set, Power up All 135 250 ms 10%Vo_set to 90%Vo_set All 25 50 ms Typ. Max. Units ISOLATION CHARACTERISTICS PARAMETER Isolation Voltage (100% Factory Hi-Pot tested @2sec.) Isolation Resistance NOTES and CONDITIONS Device Min. 1 Minute; input to output 2250 1 Minute; input to case (base plate) All 2250 1 Minute; output to case (base plate) Input to output All 20 Input to output Isolation Capacitance Vdc 1500 MΩ 4000 Input to case (base plate) All None Output to case (base plate) pF None FEATURE CHARACTERISTICS PARAMETER NOTES and CONDITIONS Switching Frequency Pulse width modulation (PWM), fixed Device Min. Typ. Max. Units All 225 250 275 KHz On/Off Control, Positive Remote On/Off Logic, Refer to -Vin Pin Logic Low (Module Off) Von/off at Ion/off=1.0mA All 1 10 mA Logic High (Module On) Von/off at Ion/off=0.0uA, Pin open=On All 0 0.01 mA On/Off Control, Negative Remote On/Off Logic, Refer to -Vin Pin Logic High (Module Off) Von/off at Ion/off=0.0uA, Pin open=Off All 0 0.01 mA Logic Low (Module On) Von/off at Ion/off=1.0mA All 1 10 mA Off Converter Input Current Shutdown input idle current All 50 mA Over Temperature Shutdown Temperature at the center part of base plate, non-latching All 110 ℃ All 90 ℃ Over Temperature Recovery GENERAL SPECIFICATIONS PARAMETER NOTES and CONDITIONS MTBF Io=100% of Io_max.; MIL-HDBK - 217F_Notice 1, GB, 25℃ Weight Case Material Plastic, DAP Base plate Material Aluminum Potting Material UL 94V-0 Base: Copper Plating: Nickel with Matte Tin EN 61373 Compliant Pin Material Shock/Vibration www.cincon.com 3 Device Min. Typ. Max. Units All 450 K hours All 220 grams REVISION: V12 CFB600W-110S Series GENERAL SPECIFICATIONS Humidity 95% RH max. Non Condensing Altitude 2000m Operating Altitude, 12000m Transport Altitude Thermal Shock MIL-STD-810F Fire & Smoke EN 45545-2 Compliant EMI Meets EN 50155 Compliant (with external filter) ESD EN 61000-4-2 Level 3: Air ±8kV, Contact ±6kV Perf. Criteria B Radiated immunity EN 61000-4-3 Level 3: 80~1000MHz, 20V/m Perf. Criteria A Fast Transient EN 61000-4-4 Level 3: On power input port, ±2kV, external input capacitor required Perf. Criteria A Surge EN 61000-4-5 Level 2: Line to earth, ±2kV, Line to line, ±1kV Perf. Criteria B Conducted immunity EN 61000-4-6 Level 3: 0.15~80MHz, 10V Perf. Criteria A Interruptions of Voltage Supply EN 50155 Class S3: 20ms with external hold up circuit Perf. Criteria A Supply Change Over EN 50155 Class C2: 30ms with external hold up circuit Perf. Criteria A Application Note Link CFB600W-110S Series App Notes Packaging Information Link www.cincon.com Packaging Information 4 REVISION: V12 CFB600W-110S Series Immunity to Environmental Conditions Phenomenon EN 50155; 2021 Reference Clause(s) Reference Standard Low Temperature Start-up test 13.4.4 EN 60068-2-1 Dry Heat Test 13.4.5 EN 60068-2-2 Low Temperature Storage Test 13.4.6 EN 60068-2-1 Cyclic Damp Heat Test 13.4.7 EN 60068-2-30 Random Vibration Test 13.4.11 EN 61373 Simulated Long Life Test at Increased Random Vibration Levels 13.4.11 EN 61373 Shock Test 13.4.11 EN 61373 Test Conditions Result Class OT4 Temperature: -40℃ Duration: 2 hrs Class OT4 Temperature: 70℃ Dry heat thermal test Cycle A Temperature: -40℃ Duration: 16 hrs Temperature: +55℃ and +25℃ Humidity: 90~96% RH Duration: 48 hrs Temperature: 25℃±10℃ Humidity: 50% ±25% RH Frequency range: 5 ~ 150 Hz 2 X axis: 0.45 𝑚⁄𝑠 2 Y axis: 0.70 𝑚⁄𝑠 2 Z axis: 1.01 𝑚⁄𝑠 Duration: 10 min / axis Temperature: 25℃±10℃ Humidity: 50% ±25% RH Frequency range: 5 ~ 150 Hz 2 X axis: 2.55 𝑚⁄𝑠 2 Y axis: 3.96 m⁄s 2 Z axis: 5.72 𝑚⁄𝑠 Duration: 5 hrs / axis Temperature: 25℃±10℃ Humidity: 50% ±25% RH a.Test Condition 1 (±Y axes) Units are operating. Pulse shape: Half-sine waveform Impact acceleration: 50 m/s2 Duration Time: 30 ms Vibration Axial:3 Axis,6 Faces Shock Time :3 times Total Time:18 times b.Test Condition 2 (±X and ±Z axes) Units are non-operating. Pulse shape : Half-sine waveform Impact acceleration : 30 m/s2 Duration Time : 30 ms Vibration Axial:3 Axis,6 Faces Shock Time :3 times Total Time:18 times Pass Pass Pass Pass Pass Pass Pass EN 45545-2 Fire & Smoke Test Conditions Item Standard EN 45545-2: 2013+A1:2015 EN ISO 4589-2: 2017 EN 45545-2: 2013+A1:2015 EN ISO 5659-2: 2017 EN 45545-2: 2013+A1:2015 NF X70-100-1 and -2: 2006 EN 45545-2: 2013+A1:2015 EN ISO 4589-2: 2017 EN 45545-2: 2013+A1:2015 EN ISO 5659-2: 2013 EN 45545-2: 2013+A1:2015 NF X70-100-1 and -2: 2006 EN 45545-2: 2013 EN ISO 4589-2 EN 45545-2+A1:2016 EN 60695-2-11:2014 EN 45545-2: 2013 EN 60695-11-10: 2013 Oxygen Index Test R22 Smoke Density Test Smoke Toxicity Test Oxygen Index Test R23 Smoke Density Test Smoke Toxicity Test R24 Oxygen Index Test R25 Glow - Wire Test R26 Vertical Flame Test www.cincon.com 5 Hazard Level HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 REVISION: V12 CFB600W-110S Series CHARACTERISTIC CURVE Power Derating Curve CFB600W-110S Derating Curve without Heatsink (Vin=110V) Natural 200 ft./min. 300 ft./min. 400 ft./min. 500 ft./min. 600 ft./min. 700 ft./min. 800 ft./min. 80 70 60 50 40 Output Power (%) Output Power (%) 90 30 20 10 0 0 10 20 30 40 50 60 70 Ambient Temperature (℃) 80 90 CFB600W-110S Derating Curve with Heatsink FBL254 (Vin=110V) 110 100 90 80 70 60 50 40 30 20 10 0 100 Natural 100 ft./min. 200 ft./min. 300 ft./min. 400 ft./min. 0 10 20 30 40 50 60 70 Ambient Temperature (℃) 80 90 100 Performance Data CFB600W-110S12 Eff Vs Io @25 Deg. C CFB600W-110S12 Pd Vs Po @25 Deg. C 120 Power Dissipation (W) 100% 43V 110V 160V Efficiency (%) 100 90% 80% 43V 110V 160V 70% 60% 10% 20% 30% 40% 50% 60% 70% 80% 80 60 40 20 0 90% 100% 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) Output Power (%) CFB600W-110S24 Eff Vs Io @25 Deg. C CFB600W-110S24 Pd Vs Po @25 Deg. C 120 Power Dissipation (W) 100% 43V 110V 160V Efficiency (%) 100 90% 80% 43V 110V 160V 70% 60% 10% 20% 30% 40% 50% 60% 70% 80% 60 40 20 0 90% 100% Current Load (%) www.cincon.com 80 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) 6 REVISION: V12 CFB600W-110S CFB600W-110S28 Eff Vs Io @25 Deg. C CFB600W-110S28 Pd Vs Po @25 Deg. C 120 Power Dissipation (W) 100% 43V 110V 160V Efficiency (%) 100 90% 80% 43V 110V 160V 70% 60% 10% 20% 30% 40% 50% 60% 70% 80% 80 60 40 20 0 90% 100% 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) Output Power (%) CFB600W-110S48 Eff Vs Io @25 Deg. C CFB600W-110S48 Pd Vs Po @25 Deg. C 120 Power Dissipation (W) 100% 43V 110V 160V Efficiency (%) 100 90% 80% 43V 110V 160V 70% 60% 10% 20% 30% 40% 50% 60% 70% 80% 80 60 40 20 0 90% 100% Current Load (%) www.cincon.com Series 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) 7 REVISION: V12 CFB600W-110S Series MECHANICAL SPECIFICATION All Dimensions in Inches[mm] Tolerance Inches:x.xx=±0.02 , x.xxx=±0.01 Millimeters:x.x=±0.5 , x.xx=±0.25 Pin ±0.004 ±0.1 0.301[7.64] 0.150[3.81] 0.150[3.81] 0.150[3.81] 0.150[3.81] 0.400[10.16] ON/OFF 2.40[61.0] 0.050[1.27] 1 2 3 4 5~7 8~10 11 12 13 14 15 16 0.199[5.05] 4.20[106.7] -V Input +V Input -On/Off +On/Off +V Output -V Output -Sense +Sense TRIM PC IOC AUX 0.50[12.7] 0.22[5.5] Mounting Inserts 2.00[50.8] - + 1.400[35.56] 0.400[10.16] +Vin 0.900[22.86] 0.100[2.54] 0.300[7.62] PIN CONNECTION PIN NUMBER CONNECTION -Vin 0.201[5.10] 0.150[3.81] 0.150[3.81] 4.60[116.8] sales@cincon.com.tw www.cincon.com 8 REVISION: V12
CFB600W-110S12 价格&库存
很抱歉,暂时无法提供与“CFB600W-110S12”相匹配的价格&库存,您可以联系我们找货
CFB600W-110S12
  • 1+2247.070411+281.05703
  • 5+2202.132485+275.43632
  • 10+2136.0690310+267.17330
  • 25+2077.3540825+259.82940
  • 50+1591.9211850+199.11287
库存:5
