CFM351M240
CFM351M240
    CINCON
    开放框架 AC DC 转换器 1 输出 24V 90 ~ 264 VAC 输入
CFM351M240 数据手册
V19 CFM351M SERIES ︳ 350 WATT AC-DC POWER SUPPLY WITH PFC Features * Universal Input Range 90~264Vac * Meets EN60601-1 and EN55011 Class B * 350W with Free Air Convection @ 220Vac * Active PFC Meets EN61000-3-2 Class D * High Efficiency up to 93% Typical * Remote Voltage Sense * PS On/Off Remote Control * +5V Stand-by Output Power * 12V Fan Output * Meets 2MOPP MODEL VOLTAGE OUTPUT OUTPUT CURRENT(A) RATED1 RATED2 RIPPLE & NOISE VOLTAGE ADJ.RANGE VOLTAGE ACCURACY LINE REG. LOAD REG. % EFF. (Typ.) Main Output Voltage CFM351M050 +5 V 60 40 100 mVp-p 4.75~5.25 ±1.0% ±0.5% ±1% 88% CFM351M120 +12 V 29.2 25 120 mVp-p 11.4~12.6 ±1.0% ±0.5% ±1% 92% CFM351M240 +24 V 14.6 12.5 150 mVp-p 22.8~25.2 ±1.0% ±0.5% ±1% 93% CFM351M480 +48 V 7.3 6.25 150 mVp-p 45.6~50.4 ±1.0% ±0.5% ±1% 93% 0.3 0.3 ---- ---- ---- ---- 0.3 0.3 ---- ---- ---- ---- Stand-by Output Voltage All +5.0 V Fan Output Voltage All +12.0 V Note: 1. RATED1: 10CFM Air Flow 2. RATED2: Natural Convection (at 110 ~ 200 Vac, Refer to Derating Curve) Specifications are subject to change without notice. 1 V19 Specifications CFM351M Series Derating Curve INPUT SPECIFICATIONS: 350W with 10CFM Air Flow 100 80 Rate Load(%) AC Input Voltage …....…………....…........................................... 90~264Vac 120~370V d c Frequency ………………………………………….……………..... 47 to 63Hz Inrush Current ……………….…………....................... 50A max. @240Vac Leakage Current @ 264Vac ……………………………….…..… 300uA max. OUTPUT SPECIFICATIONS: 60 40 20 Total Rated Output Power ……………………………………………… 350W Remote Voltage Sense …………….… Compensates for Wire Voltage Drop Adjustment Range on Vout ………………………….…………………..… ±5% Hold-up Time …………………………………………………….…… 16ms typ. Over Voltage Protection ………………..….…… Recycle AC Input to Restart Short Circuit Protection …………................... Hiccup Mode (Auto Recovery) Temperature Coefficient …………………………….……….. ±0.05%/℃ max. 0 -20 -10 0 10 20 30 40 50 Ambient Temperature(℃) 100 Rate Load(%) 80 Isolation ………………………………………...… Input to Output = 5656Vdc Operating Temperature ............………...... -20 ~ 70℃ (See Derating Curve) Storage Temperature ……………………………...….......……....... -40~85℃ Humidity …………………………..….......….. 93% RH max. Non Condensing Switching Frequency .…………............................................. 55kHz Typical 60 40 12V,24V,48V 20 MTBF …...… MIL-HDBK-217F, GB, 25℃/115Vac ….……...…. 100Khrs min. Altitude …………………………………………………………………… 3000m Dimensions …….. 6.500x4.000x1.516 Inches (165.00x101.60x38.60 mm) Weight ……………………………………………………... 640g (1.42Pounds) 5V 0 90 110 130 150 170 190 210 230 Rate Load(%) Emission and Immunity …………………………. EN60601-1-2;2015 ed. 4.0 EN55011 Class B, FCC CFR 47 Part 15 IEC61000-3-2, 3, IEC61000-4-2, 3, 4, 5, 6, 8, 11 Safety ………………………………..……. IEC60601-1:2005+A1:2012 ed 3.1 EN60601-1:2006+A11:2011+A1+A12 ed 3.1, UL ANSI/AAMI ES60601-1:2005 100 80 60 40 20 0 NOTE: -20 -10 0 1. Add a 0.1uF ceramic capacitor and a 47uF E.L. capacitor to output for ripple&noise measuring @20MHz BW. 10 20 30 40 50 Ambient Temperature(℃) 2. Voltage accuracy is set at 60% rated load and 25℃.Ta. 3. Line regulation is measured from high line to low line with rated load. 4. Load regulation is measured at 60%±40% rated. 5. CN1: LONG CHU P3060 Series or Equivalent CN2: JST B2B-PH-K-S or Equivalent CN5: LONG CHU P220V Series or Equivalent Mechanical Specification 1 2 6 5 4 CN2 CN5 LED VR +Vo L 10CFM min 1 2 3 1.516[[38.60] max. 0.098[2.50]max. 6.071[154.20] CN2 CN5 LED VR +Vo CN1 0.215[5.45] 0.063[1.60] 1 2 6 5 4 L -Vo N 6.500[165.10] 10mm FAN ] 4.000[101.60] 1 2 3 .50 0.215[5.45] 4-Φ Φ3 38[ 0 .1 3.571[90.70] 10mm FAN -Vo N FAN location for CFM351M050 only CN5 PIN CONNECTION CN2 PIN CONNECTION Pin Function Pin Function Pin Function 1 GND 4 -SENSE 1 FAN output+ 2 +5VSB 5 ENABLE 2 FAN output- 3 +SENSE 6 GND NOTE: Pull down Enable to activate the PSU All Dimensions In Inches(mm) Tolerances Inches: X.XX= ±0.04 , X.XXX= ±0.010 Millimeters: X.X= ±1.0 , X.XX=±0.25 Typical at 25℃, 230Vac and 60% rated load, unless otherwise Specified 2 250 lnput Voltage(Vac) SAFETY AND EMC: CN1 70 350W with Natural Convection GENERAL SPECIFICATIONS: 10CFM min 60 60 70
CFM351M240 价格&库存
很抱歉,暂时无法提供与“CFM351M240”相匹配的价格&库存,您可以联系我们找货
