CFM60T SERIES
60W TRIPLE OUTPUT
AC-DC MODULES
Features
⚫ Universal Input Range 90~264Vac
⚫ Efficiency to 83%
⚫ 2”x 4” Size
⚫ Meets Class I
⚫ Approval IEC/EN/UL 62368-1
⚫ Approval EN 55032 Class B and
CISPR/FCC Class B
⚫ Continuous Short Circuit Protection
MODEL
OUTPUT
NUMBER
VOLTAGE
CFM60T-01
CFM60T-02
CFM60T-03
CFM60T-04
5V(V1)
12V(V2)
-12V(V3)
5V(V1)
15V(V2)
-15V(V3)
5V(V1)
24V(V2)
-12V(V3)
3.3V(V1)
5V(V2)
-12V(V3)
OUTPUT CURRENT
VOLTAGE
RIPPLE&
ACCURACY
NOISE
LINE
LOAD
O/P
REGULATION REGULATION POWER
%EFF.
(Typ.)
Min.
Rated
Max.
NOTE1
NOTE2
NOTE3
NOTE4
Max.
NOTE5
0A
0A
0A
0A
0A
0A
0A
0A
0A
0A
0A
0A
4.0 A
3.0 A
0.5 A
4.0 A
2.5 A
0.3 A
4.0 A
1.5 A
0.5 A
6.0 A
3.0 A
0.5 A
5.0 A
3.7 A
0.65 A
5.0 A
3.1 A
0.5 A
5.0 A
1.8 A
0.6 A
7.5 A
3.7 A
0.65 A
±2%
±5%
±5%
50 mV
120 mV
120 mV
±1%
±1%
±1%
±4%
±3%
±5%
62W
83%
±2%
±4%
±5%
50 mV
150 mV
150 mV
±1%
±1%
±1%
±4%
±3%
±5%
62W
83%
±2%
±3%
±5%
50 mV
240 mV
120 mV
±1%
±1%
±1%
±4%
±3%
±5%
62W
83%
±4%
±5%
±5%
50 mV
50 mV
120 mV
±1%
±1%
±2%
±5%
±4%
±5%
40.8W
78%
Note:
1. Voltage accuracy is set at 60% rated load and 25℃ Ta.
2. Add a 0.1uF ceramic capacitor and a 10uF E.L. capacitor to output for ripple & noise measuring @20MHz B.W.
3. Line regulation is measured from 103Vac~127Vac & 207Vac~253Vac with rated load.
4. Load regulation is defined by changing ±40% of measured output load from 60% rated load at other outputs set to 60% rated load.
5. Typical efficiency at 230 Vac and rated load at 25℃.
www.cincon.com
1
REVISION: V16
CFM60T
Series
PART NUMBER
Series
CFM60
CFM60
Number of Outputs
T
T:Triple Output
Nominal Output Voltage
-XX
V1:5V
01:V2:12V
V3:-12V
V1:5V
02:V2:15V
V3:-15V
V1:5V
03:V2:24V
V3:-12V
V1:3.3V
04:V2:5V
V3:-12V
Type
-X (Option)
None:Open Frame
Part Number Example:
CFM60T-01: Open Frame Type, 60W, Triple Output V1:5V, V2:12V, V3:-12V
www.cincon.com
2
REVISION: V16
CFM60T
Series
TECHNICAL SPECIFICATIONS
(All specifications are typical at nominal input, 100% full load at 25℃ unless otherwise noted.)
ABSOLUTE MAXIMUM RATINGS
PARAMETER
NOTES and CONDITIONS
Device
Input Voltage
Safety approvals only to the AC
input
All
Operating Temperature
See Derating Curve
Min.
Typ.
Max.
Units
90
264
Vac
120
370
Vdc
All
Storage Temperature
All
-20
85
Operating Altitude
All
2000
m
Max.
Units
INPUT CHARACTERISTICS
PARAMETER
Device
Min.
Operating Voltage Range
All
100
240
Vac
Input Frequency Range
All
47
63
Hz
Maximum Input Current
100% full load, Vin=100Vac
Leakage Current
Inrush Current
Vin=240Vac, Cold start at 25℃
Typ.
All
1.5
A
All
3.5
mA
All
50
A
Max.
Units
OUTPUT CHARACTERISTICS
PARAMETER
Device
CFM60T-01
CFM60T-02
Output Voltage Set Point
Vin=Nominal Vin, Io=60% load,
Tc=25℃
CFM60T-03
CFM60T-04
CFM60T-01
CFM60T-02
Operating Output Current Range
Vin=90Vac~264Vac , See Derating
Curve
CFM60T-03
CFM60T-04
Holdup Time
www.cincon.com
Vin=115Vac
All
3
Min.
Typ.
V1
4.9
5.0
5.1
V2
11.4
12.0
12.6
V3
-12.6
-12.0
-11.4
V1
4.9
5.0
5.1
V2
14.4
15.0
15.6
V3
-15.75
-15.0
-14.25
V1
4.9
5.0
5.1
V2
23.28
24.0
24.72
V3
-12.6
-12.0
-11.4
V1
3.17
3.3
3.43
V2
4.75
5.0
5.25
V3
-12.6
-12.0
-11.4
V1
5.0
V2
3.7
V3
0.65
V1
5.0
V2
3.1
V3
0.5
V1
5.0
V2
1.8
V3
0.6
V1
7.5
V2
3.7
V3
0.65
8
Vdc
A
ms
REVISION: V16
CFM60T
PARAMETER
Device
Min.
Typ.
Series
Max.
Units
Output Voltage Regulation
CFM60T-01
Load Regulation
Defined by changing ±40% of
rated load at other output set to 60%
rated load.
CFM60T-02
CFM60T-03
CFM60T-04
CFM60T-01
CFM60T-02
Line Regulation
Vin=103Vac to 127Vac
Vin=207Vac to 253Vac
CFM60T-03
CFM60T-04
V1
±4
V2
±3
V3
±5
V1
±4
V2
±3
V3
±5
V1
±4
V2
±3
V3
±5
V1
±5
V2
±4
V3
±5
V1
±1
V2
±1
V3
±1
V1
±1
V2
±1
V3
±1
V1
±1
V2
±1
V3
±1
V1
±1
V2
±1
V3
Over Current Protection
Hiccup mode (auto recovery)
All
All
CFM60T-01
CFM60T-02
Over Voltage Protection
CFM60T-03
CFM60T-04
CFM60T-01
Output Ripple and Noise
1. Add a 0.1uF ceramic capacitor
and a 10uF aluminum electrolytic
capacitor to output
2. Oscilloscope is 20MHz bandwidth
3. Ambient temperature=25℃
CFM60T-02
CFM60T-03
CFM60T-04
Efficiency
www.cincon.com
1. Vin=230Vac
2. Output is 100% full load
4
±2
120
180
V1
7
V2
15
V1
7
V2
18
V1
7
V2
28
V1
6
V2
V1
V2
V3
V1
V2
V3
V1
V2
V3
V1
V2
V3
7
50
120
120
50
150
150
50
240
120
50
50
120
CFM60T-01
CFM60T-02
83
CFM60T-03
83
CFM60T-04
78
83
Vdc
mV
REVISION: V16
CFM60T
Series
ISOLATION CHARACTERISTICS
PARAMETER
Device
Min.
Input to Output
1 Minute
All
Isolation Resistance
Input to Output
All
100
Device
Min.
Typ.
Max.
4242
Units
Vdc
MΩ
FEATURE CHARACTERISTICS
PARAMETER
Switching Frequency
Pout=max. rated power
All
Typ.
Max.
65
Units
kHz
GENERAL SPECIFICATIONS
PARAMETER
MTBF
Humidity
Shock
Vibration
Io=100%; Ta=25℃ per MIL-HDBK-217F
I o=100%; Ta=25℃ Telcordia SR332
Non-condensing
Meet MIL-STD-810F Table
516.5,Table 516.5-I 10ms, each axis
3 times(±X、±Y、±Z axis)
Meet MIL-STD-810F Table 514.5CVIII,15~2000Hz, X、Y、Z axis, 1
hour (each axis),. Total 3 hrs.
Weight
All
Min.
Typ.
Max.
300
Units
k
hours
2590
All
93
% RH
All
75
g
All
4
g
160
grams
All
Dimensions
Safety
Device
All
4.000x2.000x1.260 Inches
(101.60x50.80x32.00 mm)
Conducted Disturbance
Class I, IEC/EN/UL 62368-1
EN 55032:2015+A11:2020, Class B
EN 61000-3-2:2019, EN 61000-3-3:2013+A1:2019, FCC CFR 47 Part 15
EN 55032:2015+A11:2020, FCC CFR 47 Part 15
Class B
Radiated Disturbance
Class B
Harmonic Current Emissions
EN 61000-3-2:2019
Class A
Voltage Fluctuations & Flicker
EMC Immunity
EN 55035:2017+A11:2020, IEC 61000-4-2, 3, 4, 5, 6, 8, 11
Electrostatic Discharge (ESD)
Radio-Frequency, Continuous
Electrical Fast Transient (EFT)
IEC 61000-4-2:2008, Air Discharge: ±8kV Contact, Discharge: ±4kV
Criterion A
IEC 61000-4-3:2020
Criterion A
IEC 61000-4-4:2012, ±1kV
Criterion A
Surge
Conducted Disturbances, Induced
by RF Fields
Power Frequency Magnetic Field
IEC 61000-4-5:2014+A1:2017, L-N: ±0.5kV, ±1kV, L-E(Ground): ±0.5kV, ±1kV, ±2kV
Criterion A
IEC 61000-4-6:2013+COR1:2015
Criterion A
IEC 61000-4-8:2009
Criterion A
Voltage Dips
IEC 61000-4-11:2020, Dips: 30% Reduction, Dips: >95% Reduction
Criterion A
Voltage Interruptions
IEC 61000-4-11:2020, >95% Reduction
Criterion B
EMC Emission
Application Note Link
www.cincon.com
Ed.3.0
CFM60T Series App Notes
5
REVISION: V16
CFM60T
Series
CHARACTERISTIC CURVE
Power Derating Curve
100%
Rate Load (%)
75%
50%
25%
20 LFM(Natural Convection)
0%
40
50
60
Ambient Temperature(℃)
Performance Data
CFM60T-01 (Eff Vs Io)
CFM60T-02 (Eff Vs Io)
90%
90%
Efficiency (%)
100%
Efficiency (%)
100%
80%
70%
115V
60%
50%
10%
230V
20%
30%
40%
50%
60%
70%
80%
80%
70%
60%
50%
10%
90% 100%
115V
230V
20%
30%
Current Load (%)
CFM60T-03 (Eff Vs Io)
Efficiency (%)
90%
Efficiency (%)
90%
80%
70%
115V
60%
230V
30%
40%
50%
60%
70%
80%
90% 100%
Current Load (%)
www.cincon.com
60%
70%
80%
90% 100%
CFM60T-04 (Eff Vs Io)
100%
20%
50%
Current Load (%)
100%
50%
10%
40%
80%
70%
115V
60%
50%
10%
230V
20%
30%
40%
50%
60%
70%
80%
90% 100%
Current Load (%)
6
REVISION: V16
CFM60T
Series
MECHANICAL SPECIFICATION
sales@cincon.com
www.cincon.com
7
REVISION: V16
很抱歉,暂时无法提供与“CFM60T-02”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+385.240341+49.73130
- 10+373.5106910+48.21710
- 100+343.66135100+44.36380
