CHB150-110S SERIES
150 WATT 3:1 INPUT
ISOLATED DC-DC CONVERTER
Features
Efficiency Up to 92.5%
Fixed Switching Frequency
Regulated Outputs
Remote On/Off
Fully Protected (OTP/OCP/OVP/UVLO)
2250Vdc I/O Isolation
Operating Case Temperature -40 to +100℃
Half Brick Size Meet Industrial Standard
2.28”x2.40”x0.5”
UL 60950-1 2nd (Basic Insulation) Approval
EN 50155 Compliant with External Circuits
Shock & Vibration EN 50155 (EN 61373) Compliant
Fire & Smoke EN 45545-2 Compliant
2000m Operating Altitude
Safety Meets IEC/EN/UL 62368-1
OUTPUT CURRENT
MODEL
INPUT
OUTPUT
NUMBER
VOLTAGE
VOLTAGE
MIN.
CHB150-110S05
66-160 VDC
5 VDC
CHB150-110S12
66-160 VDC
CHB150-110S24
66-160 VDC
INPUT CURRENT
% EFF. CAPACITOR
FULL LOAD
(1)
LOAD MAX.
40 mA
1474 mA
92.5
10000μF
12.5 A
40 mA
1474 mA
92.5
5600μF
6.5 A
60 mA
1541 mA
92
2200μF
MAX.
NO LOAD
0 mA
30 A
12 VDC
0 mA
24 VDC
0 mA
NOTE:
1. Nominal Input Voltage 110 VDC.
2. An External Input Capacitor 220uF for All Models are Recommended to Reduce Input Ripple Voltage.
3. To Meet EN50155 and RIA12 refer to Application Note.
PART NUMBER
Series
CHB150-
Nominal Input
Voltage
II
Number of
Outputs
O
Nominal Output
Voltage
XX
Remote On/Off Logic
Mounting Inserts
L
-Y (Option)
None:Positive
N:Negative
None: M3x0.5 Mounting Inserts
-C: Clear Mounting Insert
(3.2mm DIA.)
05:5VDC
CHB150
110:110 VDC
S:Single
12:12VDC
24:24VDC
Part Number Example:
CHB150-110S12N-C: Half Brick, 150W, 3:1 66-160Vdc Input, Single 12Vdc Output, Negative Logic, Clear Mounting Insert
www.cincon.com
1
REVISION: V13
CHB150-110S
Series
TECHNICAL SPECIFICATIONS
(All specifications are typical at nominal input, full load at 25℃ unless otherwise noted.)
ABSOLUTE MAXIMUM RATINGS
PARAMETER
NOTES and CONDITIONS
Device
Min.
Input Voltage
Input Surge Voltage
Continuous
All
-0.3
100ms max.
All
At the center part of base plate (with derating)
All
-40
100
All
-55
105
Device
Min.
Typ.
Max.
Units
All
66
110
160
Vdc
Turn-On Voltage Threshold
All
60
62
64
Vdc
Turn-Off Voltage Threshold
All
54
56
58
Vdc
Storage Temperature
Typ.
Max.
Units
160
Vdc
180
Vdc
INPUT CHARACTERISTICS
PARAMETER
Operating Input Voltage
Input Under Voltage Lockout
Lockout Hysteresis Voltage
Maximum Input Current
Vin=66V, Full load
No-Load Input Current
Vin=110V, Io=0A
All
6
All
2.55
Vdc
A
See Model Number Table
Input Filter
Pi filter
All
Inrush Current (I2t)
As per ETS300 132-2.
All
Input Reflected Ripple Current
P-P thru 12uH inductor, 5Hz to 20MHz
All
mA
0.1
30
A2s
mA
OUTPUT CHARACTERISTICS
PARAMETER
Voltage Set Point Accuracy
Vin=110V, Full load, Tc=25℃
Device
Min.
All
-1.0
Typ.
Max.
Units
+1.0
Output Voltage Regulation
Load Regulation
Full load to no load
All
±0.2
Line Regulation
Vin=High line to low line, full load
All
±0.2
Temperature Coefficient
Tc=-40℃ to 100℃
All
±0.03
5Vo
100
12Vo
150
24Vo
240
5Vo
40
Output Voltage Ripple and Noise (5Hz to 20MHz bandwidth)
Peak-to-Peak
Full load, 10uF solid Tantalum and 1uF
ceramic capacitors
RMS.
12Vo
60
24Vo
100
mV
mV
Output Current Range
Vin= 66 to 160V
Over Current Protection
Hiccup mode, Auto recovery
All
110
150
180
Over Voltage Protection
Limited voltage, % of nominal Vo
All
115
125
140
Short Circuit Protection
All
External Load Capacitance
Full load (resistive)
Output Voltage Trim Range
Po≦max. rated power, Io ≦ Io_max.
All
Output Voltage Remote Sense
Range
% of nominal Vo
All
A
Continuous, Auto Recovery
-10
uF
+10
+10
Max.
Units
EFFICIENCY
PARAMETER
100% Load
Vin=110V
www.cincon.com
Device
Min.
Typ.
2
REVISION: V13
CHB150-110S
Series
DYNAMIC CHARACTERISTICS
PARAMETER
Device
Min.
Typ.
Max.
Units
±5
200
us
Output Voltage Current Transient
Error Band
Recovery Time
Turn-On Delay and Rise Time
Turn-On Delay Time, From
On/Off Control
Turn-On Delay Time, From Input
Output Voltage Rise Time
75% to 100% of Io_max. step load change
di/dt=0.1A/us
(within 1% Vout nominal)
Full load (constant resistive load)
All
Von/off to 10%Vo_set, Remote on
All
10
ms
Vin_min. to 10%Vo_set, Power up
All
25
ms
10%Vo_set to 90%Vo_set
All
15
ms
ISOLATION CHARACTERISTICS
PARAMETER
Isolation Voltage
(100% factory Hi-Pot tested
@2sec.)
1 Minute; input to case (base plate)
Isolation Resistance
Input to output
Isolation Capacitance
Input to case (base plate)
Device
Min.
Typ.
1 Minute; input to output
Max.
Units
2250
All
2250
1 Minute; output to case (base plate)
Vdc
1500
All
10
Input to output
MΩ
1000
All
1000
Output to case (base plate)
pF
None
FEATURE CHARACTERISTICS
PARAMETER
Switching Frequency
Pulse width modulation (PWM), fixed
Device
Min.
Typ.
Max.
Units
All
180
200
220
KHz
On/Off Control, Positive Remote On/Off Logic, Refer to –Vin Pin
Logic Low (Module Off)
Von/off at Ion/off=1.0mA
All
V
Logic High (Module On)
Von/off at Ion/off=0.0uA, Pin open=on
All
3.5
75
V
Von/off at Ion/off=0.0uA, Pin open=off
All
3.5
75
V
All
V
Ion/off at Von/off=0V
All
1
mA
Logic high, Von/off=15V
All
30
uA
Shutdown input idle current
All
10
mA
On/Off Control, Negative Remote On/Off Logic, Refer to –Vin Pin
Logic High (Module Off)
Logic Low (Module On)
On/Off Current (for both remote
on/off logic)
Leakage Current (for both remote
on/off logic)
Off Converter Input Current
Over Temperature Shutdown
Over Temperature Recovery
Temperature at the center part of base plate,
non-latching
0.3
5
105
All
80
GENERAL SPECIFICATIONS
PARAMETER
MTBF
Io=100% of Io_max.;
MIL-HDBK - 217F_Notice 1, GB, 25℃
Weight
Case Material
Plastic, DAP, UL 94V-0
Base Plate Material
Aluminum
Potting Material
UL 94V-0
Base: Copper
Plating: Nickel with Matte Tin
MIL-STD-810F/EN61373 Compliant
Pin Material
Shock/Vibration
Device
Max.
Units
Others
320
K
hours
All
90
grams
Humidity
95% RH max. Non Condensing
2000m Operating Altitude, 12000m Transport Altitude
Thermal Shock
MIL-STD-810F
Fire & Smoke
3
Typ.
240
Altitude
www.cincon.com
Min.
5Vo
REVISION: V13
CHB150-110S
Series
EMC SPECIFICATIONS (External components required, please refer to application note.)
EMI
EN50155 Compliant (with external filter)
ESD
EN 61000-4-2
Level 3: Air ±8kV, Contact ±6kV
Perf. Criteria A
Radiated Immunity
EN 61000-4-3
Level 3: 80~1000MHz, 20V/m
Perf. Criteria A
Fast Transient
EN 61000-4-4
Level 3: On power input port, ±2kV, external components required
Perf. Criteria A
Surge
EN 61000-4-5
Level 3: Line to line, ±1kV, external components required
Perf. Criteria B
Conducted Immunity
EN 61000-4-6
EN 50155
Level 3: 0.15~80MHz, 10V
Class S2: 10ms interruptions, with external hold up circuit and
capacitor required
Class C1: at 0.6Un during 100ms (without interruptions)
Perf. Criteria A
Interruptions of Voltage Supply
Supply Change Over
EN 50155
Class A
Application Note Link
Perf. Criteria B
Perf. Criteria B
CHB150-110S Series App Notes
Packaging Information Link
Immunity to Environmental Conditions
Phenomenon
EN50155: 2007
Reference Clause(s)
Reference Standard
Cooling test
12.2.3
EN 60068-2-1
Dry Heat Test
12.2.4
EN 60068-2-2
Cyclic Damp Heat Test
12.2.5
EN 60068-2-30
Temperature: 25℃~ 55℃
Humidity: 90%~100% RH
Duration: 48 hrs
Pass
EN 61373
Temperature: 25℃±10℃
Humidity: 50%±25% RH
Frequency range: 5 ~ 150 Hz
Vertical: 0.98 ⁄
Transverse: 0.44 ⁄
Longitudinal: 0.69 ⁄
Duration: 10 min / axis
Pass
EN 61373
Vertical: 5.72 ⁄
Transverse: 2.5 m⁄s
Longitudinal: 3.96 ⁄
Duration: 5 hrs / axis
Pass
EN 61373
±Vertical: 30 m⁄s
±Transverse: 30 ⁄
±Longitudinal: 50 ⁄
Duration: 30ms x18 (Each axis 3
shocks)
Pass
Random Vibration Test
Simulated Long Life Test at
Increased Random Vibration
Levels
Shock Test
www.cincon.com
12.2.11
12.2.11
12.2.11
4
Test Conditions
Column 4, Class T2
Temperature: -40℃
Duration: 2 hrs
Column 4, Class T2
Temperature: 70℃
Duration: 6 hrs
Result
Pass
Pass
REVISION: V13
CHB150-110S
Series
EN45545-2 Fire & Smoke Test Conditions
Item
Standard
Oxygen Index Test
R22
Smoke Density Test
Smoke Toxicity Test
Oxygen Index Test
R23
Smoke Density Test
Smoke Toxicity Test
R24
Oxygen Index Test
R25
Glow - Wire Test
R26
Vertical Flame Test
Hazard Level
EN 45545-2: 2013+A1:2015
EN ISO 4589-2: 2017
EN ISO 5659-2: 2017
NF X70-100-1&2: 2006
EN ISO 4589-2: 2017
EN ISO 5659-2: 2017
EN45545-2: 2013
EN ISO 4589-2
EN 45545-2:2013+A1:2016
EN 60695-2-11:2014
EN 60695-11-10: 2013
HL1, HL2, HL3
HL1, HL2, HL3
HL1, HL2, HL3
HL1, HL2, HL3
HL1, HL2, HL3
HL1, HL2, HL3
HL1, HL2, HL3
HL1, HL2, HL3
HL1, HL2, HL3
CHARACTERISTIC CURVE
Power Derating Curve
110
100
90
80
70
60
50
40
30
CHB150-110S24 Derating Curve
without Heatsink (Vin=110V)
Output Power (%)
Output Power (%)
CHB150-110S05/12 Derating Curve
Natural
100 ft./min.
200 ft./min.
300 ft./min.
400 ft./min.
40
50
60
70
80
90
110
100
90
80
70
60
50
40
30
Natural
100 ft./min.
200 ft./min.
300 ft./min.
400 ft./min.
Ambient Temperature (℃)
Natural
100 ft./min.
200 ft./min.
300 ft./min.
400 ft./min.
40
50
60
70
80
90
100
110
100
90
80
70
60
50
40
30
60
70
80
90
100
90
100
Natural
100 ft./min.
200 ft./min.
300 ft./min.
400 ft./min.
www.cincon.com
40
with Heatsink HBT127 (Vin=110V)
Output Power (%)
Output Power (%)
110
100
90
80
70
60
50
40
30
10
40
50
60
70
80
5
REVISION: V13
CHB150-110S
110
100
90
80
70
60
50
40
30
with Heatsink HBL210 (Vin=110V)
Output Power (%)
Output Power (%)
Natural
100 ft./min.
200 ft./min.
300 ft./min.
400 ft./min.
40
50
60
70
80
90
110
100
90
80
70
60
50
40
30
Natural
100 ft./min.
200 ft./min.
300 ft./min.
400 ft./min.
10
40
Output Power (%)
Output Power (%)
50
60
70
80
90
100
110
100
90
80
70
60
50
40
30
60
70
80
90
100
90
100
Natural
100 ft./min.
200 ft./min.
300 ft./min.
400 ft./min.
www.cincon.com
40
with Heatsink HBT254 (Vin=110V)
Natural
100 ft./min.
200 ft./min.
300 ft./min.
400 ft./min.
110
100
90
80
70
60
50
40
30
Series
10
40
50
60
70
80
6
REVISION: V13
CHB150-110S
Series
Performance Data
CHB150-110S05
Eff Vs Io @25 Deg. C
CHB150-110S05
Pd Vs Po @25 Deg. C
Power Dissipation (W)
Efficiency (%)
100%
90%
66V
80%
110V
160V
70%
10%
14
66V
12
110V
160V
10
8
6
4
2
20%
30%
40%
50%
60%
70%
80%
90% 100%
0%
10% 20% 30% 40% 50% 60% 70% 80% 90% 100%
Current Load (%)
Output Power (%)
CHB150-110S12
CHB150-110S12
Pd Vs Po @25 Deg. C
Efficiency (%)
100%
90%
66V
80%
110V
160V
70%
10%
66V
12
110V
10
160V
8
6
4
2
20%
30%
40%
50%
60%
70%
80%
90% 100%
0%
Current Load (%)
Output Power (%)
CHB150-110S24
CHB150-110S24
Pd Vs Po @25 Deg. C
100%
Efficiency (%)
90%
80%
70%
66V
60%
110V
160V
50%
10%
20%
30%
40%
50%
60%
70%
80%
90% 100%
66V
110V
160V
0%
Current Load (%)
www.cincon.com
16
14
12
10
8
6
4
2
Output Power (%)
7
REVISION: V13
CHB150-110S
Series
MECHANICAL SPECIFICATION
CASE HB
All Dimensions In Inches(mm)
Tolerances
Inches: X.XX= ±0.02 , X.XXX= ±0.010
Millimeters: X.X= ±0.5 , X.XX=±0.25
0.18 min
[4.6]
0.50
[12.7]
5
3
6
7
2
8
1
9
[1.02]
BOTTOM VIEW
[2.03]
4
0.600
[15.24]
1.400
[35.56]
2.00
[50.8]
2.40
[61.0]
Mounting Inserts
M3*0.5 Through 4pl.
Pin
1
2
3
4
5
6
7
8
9
Function
+V Input
On/Off
CASE
-V Input
-V Output
-Sense
Trim
+Sense
+V Output
1.90
[48.3]
2.28
[57.9]
sales@cincon.com.tw
www.cincon.com
8
REVISION: V13
