CQB150W-110S24
CQB150W-110S24
    CINCON
    模块
    隔离模块 直流转换器 1 输出 24V 6.3A 43V - 160V 输入
CQB150W-110S24 数据手册
CQB150W-110S SERIES 150 WATT 4:1 INPUT ISOLATED DC-DC CONVERTER Features ⚫ Efficiency Up to 92% ⚫ Fixed Switching Frequency ⚫ Regulated Outputs ⚫ Remote On/Off ⚫ Low No Load Power Consumption ⚫ Fully Protected (OTP/OCP/OVP/UVLO) ⚫ 3000Vdc I/O Isolation ⚫ Operating Case Temperature -40 to +105℃ ⚫ Quarter Brick Size Meet Industrial Standard 2.28”x1.45”x0.5” ⚫ CB Test Certificate IEC 60950-1 (Except 3.3&15Vout) ⚫ UL 60950-1 2nd (Basic Insulation) Approval (Except 3.3&15Vout) ⚫ EN 50155 Compliant with External Circuits ⚫ Shock & Vibration EN 50155 (EN 61373) Compliant ⚫ Fire & Smoke EN 45545-2 Compliant ⚫ 3000m Operating Altitude ⚫ Safety Meets IEC/EN/UL 62368-1 OUTPUT CURRENT MODEL INPUT OUTPUT NUMBER VOLTAGE VOLTAGE MIN. CQB150W-110S3V3 CQB150W-110S05 CQB150W-110S12 CQB150W-110S15 CQB150W-110S24 43-160 VDC 43-160 VDC 43-160 VDC 43-160 VDC 43-160 VDC 3.3 VDC 5 VDC 12 VDC 15 VDC 24 VDC 0 mA 0 mA 0 mA 0 mA 0 mA CQB150W-110S28 43-160 VDC CQB150W-110S48 43-160 VDC 28 VDC 48 VDC 0 mA 0 mA INPUT CURRENT % EFF. CAPACITOR NO LOAD FULL LOAD (1) LOAD MAX. 30 A 30 A 12.5 A 10 A 6.3 A 10 mA 10 mA 10 mA 10 mA 10 mA 1.50 A 1.50 A 1.48 A 1.50 A 1.54 A 89 91 92 91 89 30000μF 30000μF 12500μF 10000μF 6300μF 5.4 A 3.2 A 10 mA 10 mA 1.54 A 1.54 A 89 90.5 5400μF 1000μF MAX. NOTE: 1. Nominal Input Voltage 110 VDC. 2. An External Input Capacitor 220uF for All Models are Recommended to Reduce Input Ripple Voltage. 3. To Meet EN50155 and RIA12 refer to Application Note. PART NUMBER Series CQB150W- Nominal Input Voltage II Number of Outputs O Nominal Output Voltage XX Remote On/Off Logic Mounting Inserts L -Y (Option) None:Positive N:Negative None: M3x0.5 Mounting Inserts -C: Clear Mounting Insert (3.2mm DIA.) 3V3:3.3VDC 05:05VDC 12:12VDC CQB150W 110:110 VDC S:Single 15:15VDC 24:24VDC 28:28VDC 48:48VDC Part Number Example: CQB150W-110S12N-C: Quarter Brick, 100W, 4:1 43-160Vdc Input, Single 12Vdc Output, Negative Logic, Clear Mounting Insert www.cincon.com 1 REVISION: V17 CQB150W-110S Series TECHNICAL SPECIFICATIONS (All specifications are typical at nominal input, full load at 25℃ unless otherwise noted.) ABSOLUTE MAXIMUM RATINGS PARAMETER NOTES and CONDITIONS Device Min. Input Voltage Input Surge Voltage Continuous All -0.3 100ms All Typ. Max. Units 160 Vdc 200 Vdc Operating Case Temperature All -40 105 ℃ Storage Temperature All -55 125 ℃ Device Min. Typ. Max. Units All 43 110 160 Vdc Turn-On Voltage Threshold All 40.5 41.5 42.5 Vdc Turn-Off Voltage Threshold All 37 38 39 Vdc INPUT CHARACTERISTICS PARAMETER NOTES and CONDITIONS Operating Input Voltage Input Under Voltage Lockout All 3.5 Vdc Maximum Input Current Lockout Hysteresis Voltage Vin=43V, Full load All 4 A No-Load Input Current Vin=110V, Io=0A All 10 mA Input Filter Pi filter All Inrush Current (I2t) As per ETS300 132-2. All Input Reflected Ripple Current P-P thru 12uH inductor, 5Hz to 20MHz All 0.1 30 A2 s mA OUTPUT CHARACTERISTICS PARAMETER NOTES and CONDITIONS Device Min. Voltage Set Point Accuracy Vin=110V, Full load, Tc=25℃ All -1.0 Load Regulation Full load to no load Line Regulation Vin=High line to low line, full load Temperature Coefficient Tc=-40℃ to 105℃ Typ. Max. Units +1.0 % All ±0.2 % All ±0.2 % All ±0.02 %/℃ 3.3Vo 100 5Vo 100 12Vo 150 15Vo 150 24Vo 280 28Vo 280 Output Voltage Regulation Output Voltage Ripple and Noise (5Hz to 20MHz bandwidth) Peak-to-Peak Full load, 10uF tantalum and 1uF ceramic capacitors (for Vo=48V: Full load 10uF aluminum and 1uF ceramic capacitors) RMS. 48Vo 480 3.3Vo 40 5Vo 40 12Vo 60 15Vo 60 24Vo 100 28Vo 100 48Vo 200 See Model Number Table mV mV Output Current Range Vin= 43 to 160V Over Current Protection Hiccup mode. Auto recovery All 110 125 160 % Over Voltage Protection Limited voltage, % of nominal Vo All 115 125 140 % Short Circuit Protection External Load Capacitance www.cincon.com All Full load (resistive) Continuous See Model Number Table 2 A uF REVISION: V17 CQB150W-110S PARAMETER NOTES and CONDITIONS Output Voltage Trim Range Po≦max. rated power, Io ≦ Io_max. Output Voltage Remote Sense Range Po≦max. rated power, Io ≦ Io_max. % of nominal Vo Typ. Series Device Min. 3.3Vout -20 +10 15Vout -20 +10 Others -10 +10 All Max. Units % +10 % Max. Units EFFICIENCY PARAMETER NOTES and CONDITIONS 100% Load Vin=110V Device Min. Typ. See Model Number Table % DYNAMIC CHARACTERISTICS PARAMETER NOTES and CONDITIONS Device Min. Typ. Max. Units ±5 % 250 us Output Voltage Current Transient Error Band Recovery Time Turn-On Delay and Rise Time Turn-On Delay Time, From On/Off Control Turn-On Delay Time, From Input Output Voltage Rise Time 75% to 100% of Io_max. step load change di/dt=0.1A/us (within 1% Vout nominal) Full load (constant resistive load) All Von/off to 10%Vo_set All 30 ms Vin_min. to 10%Vo_set All 30 ms 10%Vo_set to 90%Vo_set All 30 ms ISOLATION CHARACTERISTICS PARAMETER NOTES and CONDITIONS Device Min. Typ. 1 Minute; input to output Isolation Voltage 1 Minute; input to case All 1 Minute; output to case Isolation Resistance Input to output All Input to output Isolation Capacitance Output to case Units 3000 Vdc 2250 Vdc 500 Vac 100 MΩ 1500 All Input to case (base plate) Max. None 3.3Vo 470 5Vo 470 12Vo 10000 15Vo 10000 24Vo 3000 28Vo 3000 48Vo 10000 pF FEATURE CHARACTERISTICS PARAMETER NOTES and CONDITIONS Switching Frequency Pulse width modulation (PWM), fixed Device Min. Typ. Max. Units All 270 300 330 KHz 0 3.5 or Open Circuit 1.2 V 160 V 160 V 1.2 V 1 mA 30 uA 10 mA On/Off Control, Positive Remote On/Off Logic, Refer to -Vin Pin Logic Low (Module Off) Von/off at Ion/off=1.0mA All Logic High (Module On) Von/off at Ion/off=0.0uA All On/Off Control, Negative Remote On/Off Logic, Refer to -Vin Pin Logic High (Module Off) Logic Low (Module On) On/Off Current (for Both Remote On/Off Logic) Leakage Current (for Both Remote On/Off Logic) Off Converter Input Current www.cincon.com Von/off at Ion/off=0.0uA All Von/off at Ion/off=1.0mA All Ion/off at Von/off=0V All Logic high, Von/off=15V All Shutdown input idle current All 3 3.5 or Open Circuit 0 0.3 5 REVISION: V17 CQB150W-110S Series GENERAL SPECIFICATIONS PARAMETER NOTES and CONDITIONS Over Temperature Shutdown Temperature at the center part of base plate, non-latching Over Temperature Recovery MTBF Device Io=100% of Io_max.; MIL-HDBK - 217F_Notice 1, GB, 25℃ Weight Min. Typ. 110 All 3.3Vo 875 5Vo 720 12Vo 720 Others 840 All 68 Plastic, DAP Base plate Material Aluminum Potting Material Shock/Vibration UL 94V-0 Base: Copper Plating: Nickel with Matte Tin MIL-STD-810F/EN 61373 Compliant Humidity 95% RH max. Non condensing Altitude 3000m Operating altitude, 12000m Transport altitude Thermal Shock MIL-STD-810F Fire & Smoke EN 45545-2 Compliant EMI Meets EN 55011, EN 55032 & EN 50155 Compliant (with external filter) ESD EN 61000-4-2 EN 61000-4-3 K hours grams Class A Magnetic Immunity EN 61000-4-8 Level 3: Air ±8kV, Contact ±6kV Level 3: 80~1000MHz, 20V/m Level 2: 80~1000MHz, 3V/m for EN 55035:2017 Level 3: On power input port, ±2kV, external input capacitor required Level 1: On power input port, ±0.5kV, external input capacitor required, for EN55035:2017 Level 4: Line to earth, ±4kV, Line to line, ±2kV (EN 50155) Level 1: Line to earth, ±0.5kV, for EN55035:2017 external components required Level 3: 0.15~80MHz, 10V Level 2: 0.15~30MHz, 3V, 30~80MHz, 1V for EN 55035:2017 Level 1: 50Hz, 1A/m for EN55035:2017 Interruptions of Voltage Supply EN 50155 Class S2: 10ms interruptions Supply Change Over EN 50155 Class C2: During a supply break of 30 ms Radiated immunity EN 61000-4-4 Fast Transient EN 61000-4-5 Surge Conducted immunity EN 61000-4-6 Application Note Link Perf. Criteria A Perf. Criteria B Perf. Criteria A Perf. Criteria A Perf. Criteria A Perf. Criteria A Perf. Criteria A Perf. Criteria B CQB150W-110S Series App Notes Packaging Information Link www.cincon.com Units ℃ 100 Case Material Pin Material Max. Packaging Information 4 REVISION: V17 CQB150W-110S Series Immunity to Environmental Conditions Phenomenon EN 50155; 2017 Reference Clause(s) Reference Standard Low Temperature Start-up test 13.4.4 EN 60068-2-1 Test Conditions Result Class OT6 Pass Temperature: -40℃ Duration: 2 hrs Class OT6 & ST2 Temperature: 85℃ Dry Heat Test 13.4.5 EN 60068-2-2 Pass Duration: 6 hrs Extended temperature: 100℃ Extended Duration: 10min Temperature: -40℃ Low Temperature Storage Test 13.4.6 EN 60068-2-1 Cyclic Damp Heat Test 13.4.7 EN 60068-2-30 Pass Duration: 16 hrs Temperature: 25℃ - 55℃ Pass Humidity: 90% RH Duration: 48 hrs Temperature: 25℃±10℃ Humidity: 50% ±25% RH Random Vibration Test 13.4.11 EN 61373 Frequency range: 5 ~ 150 Hz 2 Vertical: 1.01 𝑚 ⁄𝑠 Pass 2 Transverse: 0.450 𝑚 ⁄𝑠 2 Longitudinal: 0.700 𝑚 ⁄𝑠 Duration: 10 min / axis Temperature: 25℃±10℃ Humidity: 50% ±25% RH Simulated Long Life Test at Increased Random Vibration Levels 13.4.11 EN 61373 Frequency range: 5 ~ 150 Hz 2 Vertical: 5.72 𝑚 ⁄𝑠 Pass 2 Transverse: 2.55 𝑚 ⁄𝑠 2 Longitudinal: 3.96 𝑚 ⁄𝑠 Duration: 5 hrs / axis Temperature: 25℃±10℃ Humidity: 50% ±25% RH Shock Test 13.4.11 EN 61373 Frequency range: 5 ~ 150 Hz 2 ±Vertical: 30 𝑚 ⁄𝑠 2 ±-Transverse: 30 𝑚 ⁄𝑠 2 ±Longitudinal: 50 𝑚 ⁄𝑠 Pass Duration: 30ms x18 (Each axis 3 shocks) EN 45545-2 Fire & Smoke Test Conditions Item Standard EN 45545-2: 2013+A1:2015 EN ISO 4589-2: 2017 EN 45545-2: 2013+A1:2015 EN ISO 5659-2: 2017 EN 45545-2: 2013+A1:2015 NF X70-100-1 and -2: 2006 EN 45545-2: 2013+A1:2015 EN ISO 4589-2: 2017 EN 45545-2: 2013+A1:2015 EN ISO 5659-2: 2013 EN 45545-2: 2013+A1:2015 NF X70-100-1 and -2: 2006 EN 45545-2: 2013 EN ISO 4589-2 EN 45545-2+A1:2016 EN 60695-2-11:2014 EN 45545-2: 2013 EN 60695-11-10: 2013 Oxygen Index Test R22 Smoke Density Test Smoke Toxicity Test Oxygen Index Test R23 Smoke Density Test Smoke Toxicity Test R24 Oxygen Index Test R25 Glow - Wire Test R26 Vertical Flame Test www.cincon.com 5 Hazard Level HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 REVISION: V17 CQB150W-110S Series CHARACTERISTIC CURVE Power Derating Curve 110 100 90 80 70 60 50 40 30 20 10 0 CQB150W-110S05,12,15 Derating Curve without Heatsink (Vin=110V) Output Power (%) Output Power (%) CQB150W-110S3V3,24,28 Derating Curve without Heatsink (Vin=110V) Natural 100 ft./min. 200 ft./min. 300 ft./min. 400 ft./min. 0 10 20 30 40 50 60 70 80 Ambient Temperature (℃) 90 110 100 90 80 70 60 50 40 30 20 10 0 100 110 Natural 100 ft./min. 200 ft./min. 300 ft./min. 400 ft./min. 0 10 110 100 90 80 70 60 50 40 30 20 10 0 Natural 100 ft./min. 200 ft./min. 300 ft./min. 400 ft./min. 0 10 20 30 40 50 60 70 80 Ambient Temperature (℃) 90 110 100 90 80 70 60 50 40 30 20 10 0 100 110 0 10 20 30 40 Output Power (%) Output Power (%) 50 60 70 80 Ambient Temperature (℃) 90 10 110 100 90 80 70 60 50 40 30 20 10 0 100 110 0 10 20 Output Power (%) Output Power (%) www.cincon.com 30 40 50 60 70 80 Ambient Temperature (℃) 90 70 80 90 100 110 20 30 40 50 60 70 80 Ambient Temperature (℃) 90 100 110 10 20 30 40 50 60 70 80 Ambient Temperature (℃) 90 100 110 CQB150W-110S05,12,15 Derating Curve with Heatsink QBT210 (Vin=110V)) Natural 100 ft./min. 200 ft./min. 300 ft./min. 400 ft./min. 0 60 Natural 100 ft./min. 200 ft./min. 300 ft./min. 400 ft./min. CQB150W-110S3V3,24,28 Derating Curve with Heatsink QBT210 (Vin=110V)) 110 100 90 80 70 60 50 40 30 20 10 0 50 CQB150W-110S48 Derating Curve with Heatsink QBL127 (Vin=110V)) Natural 100 ft./min. 200 ft./min. 300 ft./min. 400 ft./min. 0 40 Natural 100 ft./min. 200 ft./min. 300 ft./min. 400 ft./min. CQB150W-110S05,12,15 Derating Curve with Heatsink QBL127 (Vin=110V)) 110 100 90 80 70 60 50 40 30 20 10 0 30 Ambient Temperature (℃) CQB150W-110S3V3,24,28 Derating Curve with Heatsink QBL127 (Vin=110V)) Output Power (%) Output Power (%) CQB150W-110S48 Derating Curve without Heatsink (Vin=110V) 20 100 110 110 100 90 80 70 60 50 40 30 20 10 0 Natural 100 ft./min. 200 ft./min. 300 ft./min. 400 ft./min. 0 6 10 20 30 40 50 60 70 80 Ambient Temperature (℃) 90 100 110 REVISION: V17 CQB150W-110S Series CQB150W-110S48 Derating Curve with Heatsink QBT210 (Vin=110V)) Output Power (%) 110 100 90 80 70 60 50 40 30 20 10 0 Natural 100 ft./min. 200 ft./min. 300 ft./min. 400 ft./min. 0 10 20 30 40 50 60 70 80 Ambient Temperature (℃) 90 100 110 Performance Data Power Dissipation (W) 100% CQB150W-110S3V3 Pd Vs Po @25 Deg. C CQB150W-110S3V3 Eff Vs Io @25 Deg. C Efficiency (%) 90% 80% 43V 72V 70% 96V 110V 60% 160V 50% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% 24 22 20 18 16 14 12 10 8 6 4 2 0 43V 72V 96V 110V 160V 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) CQB150W-110S05 Pd Vs Po @25 Deg. C CQB150W-110S05 Eff Vs Io @25 Deg. C Power Dissipation (W) 100% Output Power (%) Efficiency (%) 90% 80% 43V 72V 70% 96V 110V 60% 160V 50% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% 24 22 20 18 16 14 12 10 8 6 4 2 0 43V 72V 96V 110V 160V 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) CQB150W-110S12 Pd Vs Po @25 Deg. C CQB150W-110S12 Eff Vs Io @25 Deg. C Power Dissipation (W) 100% Output Power (%) Efficiency (%) 90% 80% 43V 72V 70% 96V 110V 60% 160V 50% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% 43V 72V 96V 110V 160V 0% Current Load (%) www.cincon.com 24 22 20 18 16 14 12 10 8 6 4 2 0 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) 7 REVISION: V17 CQB150W-110S CQB150W-110S15 Pd Vs Po @25 Deg. C CQB150W-110S15 Eff Vs Io @25 Deg. C Power Dissipation (W) 100% Efficiency (%) 90% 80% 43V 72V 70% 96V 60% 110V 160V 50% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% 24 22 20 18 16 14 12 10 8 6 4 2 0 43V 72V 96V 110V 160V 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) Output Power (%) CQB150W-110S24 Eff Vs Io @25 Deg. C CQB150W-110S24 Pd Vs Po @25 Deg. C Power Dissipation (W) 100% Efficiency (%) 90% 80% 43V 72V 70% 96V 60% 110V 160V 50% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% 24 22 20 18 16 14 12 10 8 6 4 2 0 43V 72V 96V 110V 160V 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) Current Load (%) CQB150W-110S28 Eff Vs Io @25 Deg. C CQB150W-110S28 Pd Vs Po @25 Deg. C Power Dissipation (W) 100% Efficiency (%) 90% 80% 43V 72V 70% 96V 60% 110V 160V 50% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% 24 22 20 18 16 14 12 10 8 6 4 2 0 43V 72V 96V 110V 160V 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) Current Load (%) CQB150W-110S48 Eff Vs Io @25 Deg. C CQB150W-110S48 Pd Vs Po @25 Deg. C Power Dissipation (W) 100% Efficiency (%) 90% 80% 43V 72V 70% 96V 60% 110V 160V 50% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% 24 22 20 18 16 14 12 10 8 6 4 2 0 43V 72V 96V 110V 160V 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) Current Load (%) www.cincon.com Series 8 REVISION: V17 CQB150W-110S Series MECHANICAL SPECIFICATION sales@cincon.com.tw www.cincon.com 9 REVISION: V17
CQB150W-110S24 价格&库存
很抱歉,暂时无法提供与“CQB150W-110S24”相匹配的价格&库存,您可以联系我们找货
CQB150W-110S24
  • 1+1261.631241+158.05536
  • 5+1214.623625+152.16632
  • 10+1194.8741610+149.69213
  • 25+1169.2273725+146.47914
  • 60+1145.1971760+143.46867
库存:9
