CQB75-300S12N-F
CQB75-300S12N-F
    CINCON
    半砖
    隔离模块 直流转换器 1 输出 12V 6.25A 180V - 450V 输入
CQB75-300S12N-F 数据手册
CQB75-300S SERIES 75 WATT 2:1 INPUT ISOLATED DC-DC CONVERTER Features  Efficiency Up to 90%  Fixed Switching Frequency  Regulated Outputs  Remote On/Off  Low No Load Power Consumption  Fully Protected (OTP/OCP/OVP/UVLO)  3000Vac I/O Isolation  Operating Case Temperature -40 to +105℃  Quarter Brick Size Meet Industrial Standard 2.28”x1.45”x0.5”  IEC/EN/UL 62368-1 (Reinforce Insulation) Approval  CB Test Certificate IEC62368-1  Shock & Vibration MIL-STD-810F Compliant  Fire & Smoke EN45545 Compliant  3000m Operating Altitude  -55℃ Operating Available (Suffix “-M2”) MODEL INPUT OUTPUT NUMBER VOLTAGE VOLTAGE CQB75-300S3V3 180-450 VDC OUTPUT CURRENT MIN. MAX. INPUT CURRENT NO LOAD % EFF. CAPACITOR FULL LOAD (2) LOAD MAX. 3.3 VDC 0 mA 15 A 10 mA 202 mA 81.5 15000μF CQB75-300S05 180-450 VDC 5 VDC 0 mA 15 A 10 mA 299 mA 83.5 15000μF CQB75-300S12 180-450 VDC 12 VDC 0 mA 6.25 A 10 mA 284 mA 88 6250μF CQB75-300S15 180-450 VDC 15 VDC 0 mA 5A 10 mA 278 mA 89.5 5000μF CQB75-300S24 180-450 VDC 24 VDC 0 mA 3.12 A 10 mA 279 mA 90 3300μF CQB75-300S48 180-450 VDC 48 VDC 0 mA 1.56 A 10 mA 280 mA 89 1000μF NOTE: 1. Nominal Input Voltage 300 VDC. 2. Measured at 300Vin. 3. An External Input Capacitor 33uF for All Models are Recommended to Reduce Input Ripple Voltage. 4. -55℃ Start-up Screen per MIL-STD105E S1 Sampling Procedure for “-M2” Version. PART NUMBER Series CQB75- Nominal Input Voltage II Number of Outputs O Nominal Output Voltage XX 05:5.0VDC 12:12VDC CQB75 300:300 VDC S:Single Remote On/Off Logic L None:Positive Mounting Inserts -Y (Option) None:M3x0.5 Mounting Inserts Operating Case Temp. Range -Z (Option) None:-40~105℃ 15:15 VDC 24:24VDC 28:28VDC -C:Clear Mounting Insert (3.2mm DIA.) -M2:-55~105℃ N:Negative 48:48VDC -F:Flanged Baseplate with M3 mounting insert Part Number Example: CQB75-300S12N-C-M2: Quarter Brick, 75W, 2:1 180-450Vdc Input, Single 12Vdc Output, Negative Logic, Clear Mounting Insert -55~105℃ Operating Case Temp. Range www.cincon.com 1 REVISION: V12 CQB75-300S Series TECHNICAL SPECIFICATIONS (All specifications are typical at nominal input, full load at 25℃ unless otherwise noted.) ABSOLUTE MAXIMUM RATINGS PARAMETER NOTES and CONDITIONS Device Min. Input Voltage Input Surge Voltage Continuous All -0.3 100ms max. All At the center part of case plate (with derating) Typ. Max. Units 450 Vdc 500 Vdc ℃ All -40 105 -M2 -55 105 All -55 125 ℃ Device Min. Typ. Max. Units All 180 300 450 Vdc Turn-On Voltage Threshold All 165 170 175 Vdc Turn-Off Voltage Threshold All 155 160 165 Vdc Operating Case Temperature Suffix “-M2” (with derating) Storage Temperature INPUT CHARACTERISTICS PARAMETER NOTES and CONDITIONS Operating Input Voltage Input Under Voltage Lockout Lockout Hysteresis Voltage Maximum Input Current No-Load Input Current Vin=180V, Full load All 10 3.3Vo 350 05Vo 520 Others 477 Vin=300V, Io=0A Vdc mA mA See Model Number Table Input Filter Pi filter All Inrush Current (I2t) As per ETS300 132-2 All Input Reflected Ripple Current P-P thru 12uH inductor, 5Hz to 20MHz All 0.1 A2 s mA 30 OUTPUT CHARACTERISTICS PARAMETER NOTES and CONDITIONS Device Min. Voltage Set Point Accuracy Vin=300V, Full load, Tc=25℃ All -1.0 Full load to no load Line Regulation Vin=High line to low line, full load Temperature Coefficient Tc=-40℃ to 105℃ Typ. Max. Units +1.0 % All ±0.2 % All ±0.2 % All ±0.02 %/℃ 3.3Vo 100 05Vo 100 12Vo 150 15Vo 150 24Vo 240 48Vo 240 3.3Vo 60 05Vo 60 12Vo 60 15Vo 60 24Vo 100 Output Voltage Regulation Load Regulation Output Voltage Ripple and Noise (5Hz to 20MHz bandwidth) Peak-to-Peak Output ripple and noise measured with an external MLCC 1000pF connected between -Vin to Case, and 10uF aluminum and 1uF ceramic capacitor across output for 48Vout, and with 10uF tantalum and 1uF ceramic capacitor for others RMS. 48Vo Output Current Range Vin= 180 to 450V Over Current Protection Hiccup mode. Auto recovery Short Circuit Protection External Load Capacitance www.cincon.com All Full load (resistive) 110 135 A 160 % Continuous, Auto Recovery See Model Number Table 2 mV 100 See Model Number Table All mV uF REVISION: V12 CQB75-300S PARAMETER NOTES and CONDITIONS Output Voltage Trim Range Po≦max. rated power, Io ≦ Io_max. Device 3.3Vo 05Vo Others Min. Typ. Po≦max. rated power, Io ≦ Io_max. % of nominal Vo +10 -20 +20 +10 05Vo All 3.3Vo Over Voltage Protection Limited voltage, % of nominal Vo Max. -20 3.3Vo Output Voltage Remote Sense Range Series % % +20 112 130 Others 122 130 Device Min. 05Vo Units % EFFICIENCY PARAMETER NOTES and CONDITIONS 100% Load Vin=300V, Full load Typ. Max. See Model Number Table Units % DYNAMIC CHARACTERISTICS PARAMETER NOTES and CONDITIONS Device Min. Typ. Max. Units Output Voltage Current Transient Error Band Recovery Time Turn-On Delay and Rise Time Turn-On Delay Time, From On/Off Control Turn-On Delay Time, From Input Output Voltage Rise Time 75% to 100% of Io_max. step load change di/dt=0.1A/us (within 1% Vout nominal) Full load (Constant resistive load) All ±5 % All 250 us Von/off to 10%Vo_set, Remote on All 30 ms Vin_mi.n to 10%Vo_set, Power up All 30 ms 10%Vo_set to 90%Vo_set All 30 ms ISOLATION CHARACTERISTICS PARAMETER NOTES and CONDITIONS 1 Minute; input to output Isolation Voltage (100% factory Hi-Pot tested @2sec.) Isolation Capacitance Min. Typ. All 1 Minute; input to case (base plate) 1 Minute; output to case (base plate) Isolation Resistance Device All All Input to output All Input to output All 333 Input to case (base plate) All None Output to case (base plate) All 4400 Max. Units 3000 Vac 4200 Vdc 2500 Vac 3500 Vdc 500 Vac 700 Vdc 100 MΩ pF FEATURE CHARACTERISTICS PARAMETER NOTES and CONDITIONS Switching Frequency Pulse width modulation (PWM), fixed Device Min. Typ. Max. Units All 270 300 330 KHz On/Off Control, Positive Remote On/Off Logic, Refer to -Vin Pin Logic Low (Module Off) Von/off at Ion/off=1.0mA Logic High (Module On) Von/off at Ion/off=0.0uA, Pin open=on -M2 0 1.0 Others 0 1.2 All 3.5 75 V All 3.5 75 V -M2 0 1.0 Others 0 1.2 V On/Off Control, Negative Remote On/Off Logic, Refer to -Vin Pin Logic High (Module Off) Von/off at Ion/off=0.0uA, Pin open=off Logic Low (Module On) Von/off at Ion/off=1.0mA On/Off Current (for Both Remote On/Off Logic) Leakage Current (for Both Remote On/Off Logic) www.cincon.com Ion/off at Von/off=0V All Logic high, Von/off=15V All 3 0.3 V 1 mA 30 uA REVISION: V12 CQB75-300S PARAMETER NOTES and CONDITIONS Off Converter Input Current Shutdown input idle current Temperature at the center part of base plate, non-latching Over Temperature Shutdown Device Over Temperature Recovery Min. Series Typ. Max. Units All 5 10 mA All 110 ℃ All 100 ℃ GENERAL SPECIFICATIONS PARAMETER NOTES and CONDITIONS MTBF Device 850 300S05 850 Io=100% of Io_max.; 300S12 850 MIL-HDBK - 217F_Notice 1, GB, 25℃ 300S15 850 Case Material Plastic, DAP, UL 94V-0 Base plate Material Aluminum Potting Material UL 94V-0 Base: Copper Plating: Nickel with Matte Tin MIL-STD-810F Compliant Shock/Vibration Typ. 300S3V3 300S24 850 300S48 1050 All 61 Weight Pin Material Min. Humidity 95% RH max. Non Condensing Altitude 3000m Operating Altitude, 12000m Transport Altitude Thermal Shock MIL-STD-810F Max. Units K hours grams Fire & Smoke EN45545-2 Compliant EMI Meets EN55032 & EN55022 Compliant (with external filter) ESD EN61000-4-2 Level 3: Air ±8kV, Contact ±6kV Perf. Criteria A Radiated Immunity EN61000-4-3 Level 3: 80~1000MHz, 20V/m Perf. Criteria A Fast Transient EN61000-4-4 Level 3: On power input port, ±2kV, external input capacitor required Perf. Criteria A Surge EN61000-4-5 Level 4: Line to earth, ±4kV, Line to line, ±2kV Perf. Criteria A Conducted Immunity Power Frequency Magnetic Field immunity Application Note Link EN61000-4-6 Level 3: 0.15~80MHz, 10V Perf. Criteria A EN61000-4-8 50/60Hz, 3A/m (r.m.s.) Perf. Criteria A Class A CQB75-300S Series App Notes Packaging Information Link Packaging Information Immunity to Environmental Conditions Phenomenon Reference Clause Reference Standard Vibration Test MIL-STD-810F Table 514.5C-VIII Figure 514.5C-6 MIL-STD-810F Shock Test MIL-STD-810F 516.5 Table 516.5-I MIL-STD-810F Thermal Shock Cycling Test MIL-STD-810F 503.4 Figure 503.4-1 MIL-STD-810F Thermal Humidity Cycling Test MIL-STD-810F Notice 3 Method 507.4 MIL-STD-810F www.cincon.com 4 Test Conditions Unit are Non-Operating Vibration Waveform: Random Vibration Frequency: 15 ~ 2000 Hz Vibration axis: X、Y、Z axis Duration: 1hr / axis Wave form: Sawtooth Wave Test Category: Crash Hazard Test for Ground Equipment Duration: 10 ms Peak Acceleration: 75 G Cross-Over Frequency: 80 Hz No. of Shock: Each axis 3 times Shock Direction:±X, ±Y, ±Z axis Temperature: -55℃ to 105℃ Humidity: 95%RH Duration: 8hrs/ 3 times cycling & 4hrs dwell time Temperature: 60℃ to 30℃ Humidity: 95%RH Duration: 240 hrs Result Pass Pass Pass Pass REVISION: V12 CQB75-300S Series EN45545-2 Fire & Smoke Test Conditions Item Standard Oxygen Index Test R22 Smoke Density Test Smoke Toxicity Test Oxygen Index Test R23 Smoke Density Test Smoke Toxicity Test R24 Oxygen Index Test R25 Glow - Wire Test R26 Vertical Flame Test Hazard Level EN 45545-2: 2013 EN ISO 4589-2: 2006 EN 45545-2: 2013 EN ISO 5659-2: 2013 EN 45545-2: 2013 NF X70-100: 2006 EN 45545-2: 2013 EN ISO 4589-2: 2006 EN 45545-2: 2013 EN ISO 5659-2: 2013 EN 45545-2: 2013 NF X70-100: 2006 EN45545-2: 2013 EN ISO 4589-2 EN 45545-2:2013 EN 60695-2-11:2001 EN 45545-2: 2013 EN 60695-11-10: 2013 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 CHARACTERISTIC CURVE Power Derating Curve 110 100 90 80 70 60 50 40 30 20 10 0 CQB75-300S12, 15, 24, 48 Derating Curve without Heatsink (Vin=300V) Output Power (%) Output Power (%) CQB75-300S3V3, 05 Derating Curve without Heatsink (Vin=300V) Natural 100 ft./min. 200 ft./min. 300 ft./min. 400 ft./min. 0 10 20 30 40 50 60 70 80 90 110 100 90 80 70 60 50 40 30 20 10 0 100 110 Natural 100 ft./min. 200 ft./min. 300 ft./min. 400 ft./min. 0 10 20 Ambient Temperature (℃) Natural 100 ft./min. 200 ft./min. 300 ft./min. 400 ft./min. 0 10 20 30 40 50 60 70 80 90 100 110 110 100 90 80 70 60 50 40 30 20 10 0 50 60 70 80 90 100 110 Natural 100 ft./min. 200 ft./min. 300 ft./min. 400 ft./min. 0 Ambient Temperature (℃) www.cincon.com 40 CQB75-300S12, 15, 24, 48 Derating Curve with Heatsink QBL127 (Vin=300V) Output Power (%) Output Power (%) CQB75-300S3V3, 05 Derating Curve with Heatsink QBL127 (Vin=300V) 110 100 90 80 70 60 50 40 30 20 10 0 30 Ambient Temperature (℃) 10 20 30 40 50 60 70 80 90 100 110 Ambient Temperature (℃) 5 REVISION: V12 CQB75-300S CQB75-300S12, 15, 24, 48 Derating Curve with Heatsink QBT210 (Vin=300V) Output Power (%) Output Power (%) CQB75-300S3V3, 05 Derating Curve with Heatsink QBT210 (Vin=300V) 110 100 90 80 70 60 50 40 30 20 10 0 Natural 100 ft./min. 200 ft./min. 300 ft./min. 400 ft./min. 0 10 20 30 40 50 60 70 80 90 Series 110 100 90 80 70 60 50 40 30 20 10 0 100 110 Natural 100 ft./min. 200 ft./min. 300 ft./min. 400 ft./min. 0 Ambient Temperature (℃) 10 20 30 40 50 60 70 80 90 100 110 Ambient Temperature (℃) Performance Data CQB75-300S3V3 Eff Vs Io @25 Deg. C CQB75-300S3V3 Pd Vs Po @25 Deg. C Power Dissipation (W) 95% Efficiency (%) 90% 85% 80% 75% 70% 180V 65% 60% 300V 55% 450V 50% 10% 12 9 6 180V 3 300V 450V 0 20% 30% 40% 50% 60% 70% 80% 90% 100% 0% Current Load (%) Output Power (%) CQB75-300S05 Eff Vs Io @25 Deg. C CQB75-300S05 Pd Vs Po @25 Deg. C 18 Power Dissipation (W) 95% Efficiency (%) 90% 85% 80% 75% 70% 180V 65% 60% 300V 55% 450V 50% 10% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% 15 12 9 6 180V 3 300V 450V 0 20% 30% 40% 50% 60% 70% 80% 90% 100% 0% Current Load (%) 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) CQB75-300S12 Eff Vs Io @25 Deg. C CQB75-300S12 Pd Vs Po @25 Deg. C Power Dissipation (W) 95% Efficiency (%) 90% 85% 80% 75% 70% 180V 65% 60% 300V 55% 450V 50% 10% 12 10 8 6 180V 4 300V 2 450V 0 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) www.cincon.com 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) 6 REVISION: V12 CQB75-300S CQB75-300S15 Eff Vs Io @25 Deg. C Series CQB75-300S15 Pd Vs Po @25 Deg. C Power Dissipation (W) 95% Efficiency (%) 90% 85% 80% 75% 70% 180V 65% 60% 300V 55% 450V 50% 10% 12 10 8 6 180V 4 300V 2 450V 0 20% 30% 40% 50% 60% 70% 80% 90% 100% 0% Current Load (%) 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) CQB75-300S24 Eff Vs Io @25 Deg. C CQB75-300S24 Pd Vs Po @25 Deg. C Power Dissipation (W) 95% Efficiency (%) 90% 85% 80% 75% 70% 180V 65% 60% 300V 55% 450V 50% 10% 12 10 8 6 180V 4 300V 2 450V 0 20% 30% 40% 50% 60% 70% 80% 90% 100% 0% Current Load (%) 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) CQB75-300S48 Eff Vs Io @25 Deg. C CQB75-300S48 Pd Vs Po @25 Deg. C Power Dissipation (W) 95% Efficiency (%) 90% 85% 80% 75% 70% 180V 65% 60% 300V 55% 450V 50% 10% 12 10 8 6 180V 4 300V 2 450V 0 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) www.cincon.com 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) 7 REVISION: V12 CQB75-300S Series MECHANICAL SPECIFICATION Mounting lnserts M3*0.5 Through 2pl. Φ0.040[1.02] 6pl. 0.50[12.7] 0.60 [15.2] 1.86 [47.2] Φ0.059 [1.50] 2pl. 0.600 [15.24] BOTTOM VIEW 3 4 2 5 6 1 7 8 0.150 [3.81] 0.16 [4.1] PIN CONNECTION 0.16 [4.1]min. 0.300 [7.62] 1.957 [49.70] 1.03[26.2] 1.45 [36.8] 0.525 [13.34] 0.150 [3.81] 2.28 [57.9] PIN Function 1 +V Input 2 On/Off 3 -V Input 4 -V Output 5 -Sense 6 Trim 7 +Sense 8 +V Output All Dimensions in Inches[mm] Tolerance Inches:x.xx=±0.02 ,x.xxx=±0.010 Millimeters:x.x=±0.5 , x.xx=±0.25 -F: Flanged Baseplate 2.28 [57.9] 0.150 [3.81] 0.97 [24.8] 0.525[13.34] 1.957[49.70] Mounting lnserts M3*0.5 Through 2pl. 0.16 [4.1] 0.49 [12.5] Φ0.040 [1.02] 6pl. 2-0.65 [16.5] Φ0.059 [1.50] 2pl. 2.20[55.9] 1.98 [50.3] 0.600 [15.24] 1.86 [47.2] 0.11 [2.8] 0.16 [4.1]min. 0.13 [3.2] 0.300 [7.62] 0.150 [3.81] 1 4 5 6 7 8 0.50[12.7] 1.03[26.2] 0.59 [14.9] 1.45 [36.8] BOTTOM VIEW 3 2 sales@cincon.com.tw 8 REVISION: V12
CQB75-300S12N-F 价格&库存
很抱歉,暂时无法提供与“CQB75-300S12N-F”相匹配的价格&库存,您可以联系我们找货
CQB75-300S12N-F
  • 1+911.068491+113.95380
  • 5+877.114735+109.70696
  • 20+848.8275220+106.16888
  • 40+834.9971140+104.43901
  • 60+827.0037160+103.43922
  • 100+817.03854100+102.19280
库存:30
