V12
EC4AW-H6 SERIES
5-6 WATT
DC-DC CONVERTERS
FEATURES
* 5-6W Isolated Output
* DIP-24 Package
* Regulated Outputs
* Efficiency to 85%
* Continuous Short Circuit Protection
* I/O Isolation Voltage 6000VDC
* Reinforced Insulation Rated for Working
Voltage 300VAC
* 5uA Leakage Current
* EMI Meets EN55032 Class A
* Safety Meets IEC/EN/UL 62368-1
MODEL
NUMBER
INPUT
VOLTAGE
OUTPUT
VOLTAGE
EC4AW-24S05H6
9-36 VDC
OUTPUT CURRENT
INPUT CURRENT
MIN.(4)
MAX.
5 VDC
100 mA
1000 mA
10 mA
260 mA
% EFF.
NO LOAD FULL LOAD (2) (3)
81
CAPACITOR
LOAD MAX.
80
1000uF
EC4AW-24S12H6
9-36 VDC
12 VDC
50 mA
500 mA
10 mA
295 mA
85.5 85
500uF
EC4AW-24D12H6
9-36 VDC
±12 VDC
25 mA
±250 mA
15 mA
298 mA
84.5 84
250uF
EC4AW-24D15H6
9-36 VDC
±15 VDC
20 mA
±200 mA
15 mA
298 mA
84.5 84
200uF
EC4AW-48S05H6 18-72 VDC
5 VDC
100 mA
1000 mA
5 mA
130 mA
81
80
1000uF
EC4AW-48S12H6 18-72 VDC
12 VDC
50 mA
500 mA
5 mA
149 mA
85
84
500uF
EC4AW-48D12H6 18-72 VDC
±12 VDC
25 mA
±250 mA
8 mA
150 mA
84
83
250uF
EC4AW-48D15H6 18-72 VDC
±15 VDC
20 mA
±200 mA
8 mA
149 mA
85
84
200uF
NOTE:
1. Nominal Input Voltage 24 or 48VDC
2. Measured at 12VDC for 24Vin Models, 24VDC for 48Vin Moldels
3. Measured at Nominal Input Voltage
4. Operation Under Minimum Load Will not Damage The Converter, But It May not Meet All Specifications
1
V12
SPECIFICATIONS
All Specifications Typical at Nominal Line, Full Load, and 25℃ Unless Otherwise Noted
INPUT SPECIFICATIONS:
GENERAL SPECIFICATIONS:
Input Voltage Range....……………...........……........ 24Vin .................. 9-36V
48Vin ................. 18-72V
Under Voltage Protection ……....….. 24Vin power up ….….…....….. 8.8V typ.
24Vin power down ……….……. 8V typ.
48Vin power up ………..…. 17V typ.
48Vin power down ………….. 16V typ.
Leakage Current ….…………………………………………… 5uA max .
Input Filter ………………………………………………..….……... Pi Type
Input Surge (100ms max.) ………….…...…..... 24Vin .................... 50V max.
48Vin ................... 100V max.
Efficiency ..............................................................…..……... See Table
Isolation Voltage ..........……………....……..…………….. 6000VDC min.
Isolation Resistance .........................…..................……. 109 ohm min.
Isolation Capacitance ………………..………….…………..…… 40pF typ.
Reinforced Insulation ……… Creepage Distances …….….… 8mm min.
Air Clearances ………………. 8mm min.
Switching Frequency .......................…..........………………. 100KHz min.
Operating Ambient Temperature ……………………..…... -40℃ to +71℃
De-rating, Above 71℃ ………………… Linearly to Zero Power at 100℃
Case Temperature (note4) ………………………………….. 100℃ max.
OUTPUT SPECIFICATIONS:
Storage Temperature ……………….....….......……........ -40℃ to +100℃
Voltage Accuracy .........................................…………………..…... ±1.5% max.
Voltage Balance (Dual) .………….……………………………….…. ±2.0% max.
Transient Response: 75% - 100% Step Load Change
Error Band ………………….……………….… ±6% Vout Nominal
Recovery Time ………………………………..…..……….. < 500us
Ripple & Noise, 20MHz BW (with 0.1uF MLCC) .... 5V …... 100mV pk-pk max.
EMI ……………………………... Conductive EMI Meet EN55032 Class A
Humidity ……………………………..…… 95% RH max. Non Condensing
MTBF …… MIL-HDBK-217-F, GB, 25℃, Full Load ……… 1430Khrs typ.
Dimensions ……………..… 1.25x0.80x0.40 inches (31.8x20.3x10.2 mm)
Case Material ……………………………… Non-Conductive Black Plastic
Weight ……………………….………………………………………..... 13.1g
12V/15V … 1% pk-pk max.
Temperature Coefficient .………………..……………………. ±0.05%/°C max.
Line Regulation (note1) .……………………………...................…. ±0.5% max.
Load Regulation .………….…...... Single (note2) ……….........…. ±0.5% max.
Dual (note3) …...................…. ±1.0% max.
Cross Regulation (Dual output) Load cross variation 25%/100% …. ±5% max.
Output Short Circuit Protection .............................................….…. Continuous
Start up Time …………………………………………………….……. 1.5ms typ.
NOTE:
1. Measured from high line to low line.
2. Measured from full load to 10% load.
3. Measured from full load to 25% load.
4. Maximum case temperature under any operating condition should
not be exceeded 100℃.
Typical Derating curve for Natural Convection
120%
LOAD(% )
100%
-40
71
80%
-3.45%/℃
60%
40%
Natural Convection
20%
0%
-40
0.08
[2.0]
Case A Dimensions:
100
-20
60
o
Ambient Temperature( C)
80
PIN CONNECTION
SEE NOTE
Pin
24
23
1
2
11
12
13
0.600
[15.24]
0.80
[20.3]
0.15
[3.8]
+V Input
+V Input
2
+V Input
+V Input
12
13
15
0.40
[10.2]
Dual Output
1
11
0.100
[2.54]
1.25
[31.8]
BOTTOM
VIEW
Single Output
Common
NP
-V Ouput
+V Output
NP
-V Output
15
NP
23
-V Input
-V Input
24
-V Input
-V Input
+V Output
* NC-NO CONNECTION WITH PIN
* NP-NO PIN
NOTE:Pin Size is 0.02±0.002 Inch (0.5±0.05 mm)DIA
All Dimensions In Inches (mm)
Tolerances
Inches: X.XX= ±0.02 , X.XXX= ±0.010
Millimeters: X.X= ±0.5 , X.XX=±0.25
2
100
很抱歉,暂时无法提供与“EC4AW-48S12H6”相匹配的价格&库存,您可以联系我们找货
