CFB750-300S24N-CMFD
CFB750-300S24N-CMFD
    CINCON
    封闭式 直流转换器 1 输出 24V 31.2A 425V 输入
CFB750-300S24N-CMFD 数据手册
CFB750-300S-CMFD SERIES 750 WATT 2:1 INPUT ISOLATED DC-DC CONVERTERS Features ⚫ Efficiency Up to 90% ⚫ Fixed Switching Frequency ⚫ Regulated Outputs ⚫ Remote On/Off ⚫ Low No Load Power Consumption ⚫ Fully protected (OTP/OCP/OVP/UVLO) ⚫ 3000Vac I/O Isolation ⚫ Operating Case Temperature -40 to +80℃ ⚫ EN55032/22 for EMC Characteristic ⚫ Shock & Vibration MIL-STD-810F Compliant ⚫ Fire & Smoke EN45545-2 Compliant ⚫ Safety Meets IEC/EN/UL 62368-1 Reinforced Insulation ⚫ Build-In EMI Filter ⚫ Chassis Mount, Baseplate Cooled (9.45”×4.33”×1.65”) OUTPUT CURRENT INPUT CURRENT MODEL INPUT OUTPUT % NUMBER VOLTAGE VOLTAGE MIN. MAX. NO LOAD CFB750-300S12□-CMFD 200-425 VDC 12 VDC 0 mA 62.5 A 10 mA 2.84 A 88 10000uF CFB750-300S15□-CMFD 200-425 VDC 15 VDC 0 mA 50 A 10 mA 2.84 A 88 10000uF CFB750-300S24□-CMFD 200-425 VDC 24 VDC 0 mA 31.2 A 10 mA 2.78 A 89 10000uF CFB750-300S28□-CMFD 200-425 VDC 28 VDC 0 mA 26.7 A 10 mA 2.78 A 89 10000μF CFB750-300S36□-CMFD 200-425 VDC 36 VDC 0 mA 20.8 A 10 mA 2.78 A 90 8000μF CFB750-300S48□-CMFD 200-425 VDC 48 VDC 0 mA 15.6 A 10 mA 2.78 A 90 8000μF FULL LOAD EFF. CAPACITOR LOAD MAX. NOTE: 1. Nominal Input Voltage 300 VDC 2. □ = N or none 3. VR is Used for Output Voltage Adjustment. 4. Refer to Application Note for Thermal Resistance and Derating Information. 5. TVS is Included for Input Surge Voltage Protection. 6. Recommend an External Fuse for Input Reverse Polarity Protection (shunt diode is included inside). 7. Input Connectors PIN1-PIN4: DINKLE 166-04P5 series or equivalent, suitable electric wire: 18~12AWG (IEC 0.5~4mm2). 8. Input Connectors CN1 wafer with TAIWAN KING PIN TERMINAL 8822-02 series or equivalent. 9. Output Connectors PIN5-PIN10: DINKLE DT-49-B01W-06 series or equivalent, suitable electric wire: 22~12AWG (IEC 0.5~4mm2). 10. Output Connector CN2 wafer with CHYAO SHIUNN TERMINAL JS-1001-04(K) series or equivalent. 11. Output Connector CN3 wafer with CHIA-SOON TERMINAL B3B-PH-K-S series or equivalent PART NUMBER Series CFB750- CFB750 Nominal Input Voltage II 300: 300 VDC Number of Outputs O S: Single Nominal Output Voltage XX 12: 12VDC 15: 15VDC 24: 24VDC 28: 28VDC 36: 36VDC 48: 48VDC Remote On/Off Logic L N: -YYY Negative (Remote Pin Open Module On) None: Chassis Mount Type Positive (Remote Pin Open Module Off) CMF: Chassis Mount Built in Filter Z D: With Cover Part Number Example: CFB750-300S12N-CMFD: Chassis Mount, 750W, 2:1 200-425Vdc Input, Single 12Vdc Output, Negative Logic, With Cover www.cincon.com 1 REVISION: V10 CFB750-300S CMFD Series TECHNICAL SPECIFICATIONS (All specifications are typical at nominal input, full load at 25°C unless otherwise noted.) ABSOLUTE MAXIMUM RATINGS PARAMETER NOTES and CONDITIONS Device Min. Input Voltage Input Surge Voltage Continuous All -0.3 100ms max. All Operating Case Temperature At the Center Part of Base Plate All Storage Temperature Typ. Max. Units 425 Vdc 450 Vdc -40 80 °C All -55 105 °C Device Min. Typ. Max. Units All 200 300 425 Vdc INPUT CHARACTERISTICS PARAMETER NOTES and CONDITIONS Operating Input Voltage Input Under Voltage Lockout Turn-On Voltage Threshold Full Load All 185 190 195 Vdc Turn-Off Voltage Threshold Full Load All 175 180 185 Vdc Lockout Hysteresis Voltage Full Load All 10 Vdc Module-On Voltage All 480 Vdc Module -Off Voltage All 500 Vdc Input Over Voltage Protection Maximum Input Current No-Load Input Current 300S12 300S15 Others Vin=200V, Full Load Vin=300V, Io=0A 2.84 A 2.78 mA See Model Number Table OUTPUT CHARACTERISTICS PARAMETER NOTES and CONDITIONS Device Min. Voltage Set Point Accuracy Vin=300V, Full Load, Tc=25°C All -1.0 Load Regulation Full Load to No Load Line Regulation Vin=High Line to Low Line, Full Load Temperature Coefficient Tc=-40°C to 80°C Typ. Max. Units +1.0 % All ±1.0 % All ±0.2 % All ±0.03 %/°C 12Vo 15Vo 24Vo 28Vo 36Vo 48Vo 300 300 600 600 650 750 mV 12Vo 15Vo 24Vo 28Vo 150 150 300 300 36Vo 300 Output Voltage Regulation Output Voltage Ripple and Noise (5Hz to 20MHz bandwidth) Peak-to-Peak Full load, 1uF ceramic capacitors RMS. 48Vo Output Current Range Vin= 200 to 425V Over Current Protection Continuous Current. Auto Recovery External Load Capacitance www.cincon.com 350 A See Model Number Table Short Circuit Protection All All Full load (resistive) 105 125 % Continuous, Auto Recovery See Model Number Table 2 mV uF REVISION: V10 CFB750-300S CMFD PARAMETER NOTES and CONDITIONS Device Min. Output Voltage Trim Range Po≦max rated power, Io ≦ Io_max 300S12 300S15 300S24 300S28 300S36 300S48 -40 -40 -30 -30 -20 -15 Output Voltage Remote Sense Range Po≦max rated power, Io ≦ Io_max % of nominal Vo Limited Voltage, % of Nominal Vo Over Voltage Protection Typ. Series Max. Units +10 +10 +10 +10 +10 +10 % +10 % All All 115 125 140 % Device Min. Typ. Max. Units EFFICIENCY PARAMETER NOTES and CONDITIONS 100% Load Vin=300V % See Model Number Table DYNAMIC CHARACTERISTICS PARAMETER NOTES and CONDITIONS Device Min. Typ. Max. Units Output Voltage Current Transient Error Band Recovery Time Turn-On Delay and Rise Time Turn-On Delay Time, From On/Off Control Turn-On Delay Time, From Input Output Voltage Rise Time 75% to 100% of Io_max step load change di/dt=0.1A/us (within 1% Vout nominal) Full load (Constant resistive load) All ±5 % All 500 us Von/off to 10%Vo_set, Remote On All 100 ms Vin_min to 10%Vo_set, Power Up All 600 ms 10%Vo_set to 90%Vo_set All 40 ms ISOLATION CHARACTERISTICS PARAMETER Isolation Voltage (100% factory Hi-Pot tested @2sec.) NOTES and CONDITIONS 1 minute; Input to Output, All 1 minute; Input to Case (Base Plate), All 1 minute; Output to Case (Base Plate) Isolation Resistance Isolation Capacitance Device Min. Typ. Max. Units 3000 Vac 4200 Vdc 2500 Vac 3500 Vdc 500 Vac 700 Vdc All Input to Output All Input to Output All No Bridge Capacitor MΩ Input to Case (Base Plate) All 9740 Output to Case (Base Plate) All 64000 10 pF FEATURE CHARACTERISTICS PARAMETER NOTES and CONDITIONS Switching Frequency Pulse wide modulation (PWM), Fixed Device Min. Typ. Max. Units All 180 200 220 KHz On/Off Control, Positive Remote On/Off logic, Refer to –Vin pin. Logic Low (Module Off) Von/off at Ion/off=0.0uA, Pin open=Off All 0 1.2 V Logic High (Module On) Von/off at Ion/off=1.0mA All 3.5 12 V On/Off Control, Negative Remote On/Off logic, Refer to –Vin pin Logic High (Module Off) Logic Low (Module On) On/Off Current (for both remote on/off logic) Off Converter Input Current Von/off at Ion/off=1.0mA All 3.5 12 V Von/off at Ion/off=0.0uA, Pin open=On All 0 1.2 V Ion/off at Von/off=3.5-12V All 0.5 2.5 mA Shutdown input idle current All 15 mA 13 V 20 mA Auxiliary Output Voltage All Auxiliary Output Current All Over Temperature Shutdown All 90 °C All 75 °C Over Temperature Recovery www.cincon.com Temperature at the Center Part of Base Plate, Non-Latching 3 7 10 REVISION: V10 CFB750-300S CMFD Series GENERAL SPECIFICATIONS PARAMETER MTBF NOTES and CONDITIONS Io=100% of Io_max; MIL-HDBK - 217F_Notice 1, GB, 25°C Device Min. Typ. 300S12 296 300S15 292 300S24 329 300S28 393 300S36 291 300S48 298 All 760 Weight Max. Units K hours grams Base plate Material Aluminum Potting Material UL 94V-0 (DC Module) Shock/Vibration MIL-STD-810F Compliant Humidity 95% RH max. Non Condensing Altitude 3000m Operating Altitude, 12000m Transport Altitude Thermal Shock MIL-STD-810F Fire & Smoke EN45545-2 Compliant EMI EN55032 & EN55022 Compliant ESD EN61000-4-2 Level 3: Air ±8kV, Contact ±6kV Perf. Criteria A Radiated immunity EN61000-4-3 Level 3: 80~1000MHz, 20V/m Perf. Criteria A Fast Transient EN61000-4-4 Level 3: On power input port, ±2kV Perf. Criteria A Surge EN61000-4-5 Level 4: Line to earth, ±2kV, Line to line, ±2kV Perf. Criteria A Conducted immunity Power Frequency Magnetic Field immunity Application Note Link EN61000-4-6 Level 3: 0.15~80MHz, 10V Perf. Criteria A EN61000-4-8 50/60Hz, 3A/m (r.m.s.) Perf. Criteria A Class A CFB750-300S CMFD Series App Notes Packaging Information Link Packaging Information Immunity to Environmental Conditions. Phenomenon Reference Clause(s) Reference Standard Vibration Test MIL-STD-810F Table 514.5C-VIII Figure 514.5C-6 MIL-STD-810F Shock Test MIL-STD-810F 516.5 Table 516.5-I MIL-STD-810F Thermal Shock Cycling Test MIL-STD-810F 503.4 Figure 503.4-1 MIL-STD-810F Thermal Humidity Cycling Test MIL-STD-810F Notice 3 Method 507.4 MIL-STD-810F www.cincon.com 4 Test Conditions Unit are non-operating Vibration Waveform:Random Vibration Frequency:15 ~ 2000 Hz Total Grms:4.01997 grms Vibration axis:X、Y、Z axis Duration:1hr / axis Wave form:Sawtooth wave Test Category : Crash Hazard Test for Ground Equipment Duration:10 ms Peak Acceleration:75 G Cross-over Frequency:80 Hz No. of Shock:Each axis 3 times Shock Direction:±X , ±Y , ±Z axis Temperature:-55℃to 105℃ Humidity:95%RH Duration:8hrs/ 3 times cycling& 4hrs dwell time Temperature:60℃to 30℃ Humidity:95%RH Duration:240 hrs Result Vibration Test Shock Test Thermal Shock Cycling Test Thermal Humidity Cycling Test REVISION: V10 CFB750-300S CMFD Series EN45545-2 Fire & Smoke Test Conditions. Item Standard Oxygen Index Test R22 Smoke Density Test Smoke Toxicity Test Oxygen Index Test R23 Smoke Density Test Smoke Toxicity Test R24 Oxygen Index Test R25 Glow - Wire Test R26 Vertical Flame Test Hazard Level EN 45545-2: 2013 EN ISO 4589-2: 2006 EN 45545-2: 2013 EN ISO 5659-2: 2013 EN 45545-2: 2013 NF X70-100: 2006 EN 45545-2: 2013 EN ISO 4589-2: 2006 EN 45545-2: 2013 EN ISO 5659-2: 2013 EN 45545-2: 2013 NF X70-100: 2006 EN45545-2: 2013 EN ISO 4589-2 EN 45545-2:2013 EN 60695-2-11:2001 EN 45545-2: 2013 EN 60695-11-10: 2013 HL1, HL2, HL3 HL1, HL2 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 CHARACTERISTIC CURVE Power Derating Curve Output Power (%) CFB750-300SXX-CMFC(D) Derating Curve with Heat Sink (Vin=300V) 120 110 100 90 80 70 60 50 40 30 20 10 0 Heat Sink with Iron Plate (17x17x0.04 inch) -20 -10 0 10 20 30 40 50 60 70 80 90 Ambient Temperature (℃) Performance Data CFB750-300S12(N)-CMFD Eff Vs Io @25 Deg. C CFB750-300S12(N)-CMFD Pd Vs Po @25 Deg. C 110 100 90 80 70 60 50 40 30 20 10 0 Power Dissipation (W) 100% Efficincy (%) 90% 80% 70% 200V 300V 60% 425V 50% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% 300V 425V 0% Current Load (%) www.cincon.com 200V 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) 5 REVISION: V10 CFB750-300S CMFD CFB750-300S15(N)-CMFD Eff Vs Io @25 Deg. C CFB750-300S15(N)-CMFD Pd Vs Po @25 Deg. C 110 100 90 80 70 60 50 40 30 20 10 0 Power Dissipation (W) 100% Efficincy (%) 90% 80% 70% 200V 300V 60% 425V 50% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% 200V 300V 425V 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) Output Power (%) CFB75-300S24(N)-CMFD Eff Vs Io @25 Deg. C CFB750-300S24(N)-CMFD Pd Vs Po @25 Deg. C 110 100 90 80 70 60 50 40 30 20 10 0 Power Dissipation (W) 100% Efficincy (%) 90% 80% 70% 200V 300V 60% 425V 50% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% 200V 300V 425V 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) Output Power (%) CFB750-300S28(N)-CMFD Eff Vs Io @25 Deg. C CFB750-300S28(N)-CMFD Pd Vs Po @25 Deg. C 110 100 90 80 70 60 50 40 30 20 10 0 Power Dissipation (W) 100% Efficincy (%) 90% 80% 70% 200V 60% 300V 50% 425V 40% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% 200V 300V 425V 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) Output Power (%) CFB750-300S36(N)-CMFD Eff Vs Io @25 Deg. C CFB750-300S36(N)-CMFD Pd Vs Po @25 Deg. C 110 100 90 80 70 60 50 40 30 20 10 0 Power Dissipation (W) 100% Efficincy (%) 90% 80% 70% 200V 60% 300V 50% 425V 40% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) www.cincon.com Series 200V 300V 425V 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) 6 REVISION: V10 CFB750-300S CMFD CFB750-300S48(N)-CMFD Eff Vs Io @25 Deg. C CFB75-300S48(N)-CMFD Pd Vs Po @25 Deg. C Power Dissipation (W) 100% Efficincy (%) 90% 80% 70% 200V 60% 300V 50% 425V 40% 10% 20% 30% 40% 50% 60% 70% 80% Series 90% 100% 110 100 90 80 70 60 50 40 30 20 10 0 200V 300V 425V 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) Output Power (%) MECHANICAL SPECIFICATION 9.45 [240.0] JP2 CN2 4.33 [110.0] 0.16 [4.0] 5 6 7 8 9 10 3 2 1 CN2 3 2 1 VR 0.17 [4.2] 4pl. JP1 1.97 [50.0] 5.51 [140.0] 1.65 [42.0] CN1 CN1 2 1 1 2 3 4 4.02 [102.0] 4 LED CN3 CN3 All Dimensions in Inches[mm] Tolerance Inches: x.xx=±0.02 ,x.xxx=±0.010 Millimeters: x.x=±0.5 ,x.xx=±0.25 7 PIN CONNECTION PIN Function 1 Case 2 +Rem -V Input 3 +V Input 4 5,6,7 -V Output +V Output 8,9,10 JP1 Short +S&+Vo JP2 Short -S&-Vo CN1 (On/Off JP) PIN CONNECTION PIN Function 1 +Rem 2 -V Input CN2 (Trim JP) PIN CONNECTION PIN Function 1 -Sense 2 +Sense 3 Trim 4 Rt CN3 (PC JP) PIN CONNECTION PIN Function 1 AUX 2 IOG 3 PC REVISION: V10
CFB750-300S24N-CMFD 价格&库存
很抱歉,暂时无法提供与“CFB750-300S24N-CMFD”相匹配的价格&库存,您可以联系我们找货
CFB750-300S24N-CMFD
  • 1+3165.604251+408.10746
  • 5+3047.456735+392.87596
  • 10+2997.8313510+386.47829
  • 25+2933.3712025+378.16814
库存:12
