CFM2002S
CFM2002S
    CINCON
    开放框架 AC DC 转换器 1 输出 12V 85 ~ 264 VAC 输入
CFM2002S 数据手册
V17 CFM20 SERIES ︳ 20 WATT OPEN FRAME AC-DC MODULES Features * Universal Input Range 85~264Vac * Efficiency to 81% * Industry Standard Pin Out * Meets EN55032 Class B * Continuous Short Circuit Protection * PCB Mountable Type is Available MODEL OUTPUT MAX. MIN. VOLTAGE LOAD LOAD RIPPLE & VOLTAGE LINE LOAD % EFF. NOISE ACCURACY REGULATION REGULATION (Typ.) NOTE 1 NOTE 2 NOTE 3 NOET 4 NOET 5 CFM2001S 5V 4400 mA 0A 1% ±1% ±0.5% ±1% 72% CFM2002S 12 V 1800 mA 0A 1% ±1% ±0.5% ±1% 79% CFM2003S 15 V 1400 mA 0A 1% ±1% ±0.5% ±1% 80% CFM2005S 24 V 920 mA 0A 1% ±1% ±0.5% ±1% 81% CFM2007S 3.3 V 4400 mA 0A 50mV ±1% ±0.5% ±1% 66% CFM2009S 9V 2450 mA 0A 1% ±1% ±0.5% ±1% 76%. Specifications are subject to change without notice. 1 V17 Specifications CFM20S Series Derating Curve INPUT SPECIFICATIONS: 120~370Vdc Frequency ………………………………………….……………..... 47 to 63Hz Inrush Current ………………….…………................... 40A max. @230Vac Conducted EMI …………………………….…………... CISPR/FCC Class B Leakage Current ………………………………………………….. 3.5mA max. Rated Load(%) 100% Voltage …....………........…........................................... 85~264Vac 75% 20LFM(Natural Convection) 50% 25% 0% OUTPUT SPECIFICATIONS: 0 10 Holdup Time ……………………..……………………… 16ms typ. @115Vac 20 30 40 50 o Ambient Temperature( C) 60 70 Short Circuit Protection ……………….…… Hiccup Mode (Auto Recovery) Over Voltage Protection ……………................ TVS Component to Clamp Temperature Coefficient ………………….......................... ±0.05%/℃ max. GENERAL SPECIFICATIONS: NOTE: Isolation ……………………………………..…… Input to output = 4,242VDC 1. Add a 0.1uF ceramic capacitor and a 10uF E.L. capacitor to output for Operating Temperature ................................ 0 ~ 70℃ (See Derating Curve) Ripple & Noise measuring @20MHz BW. Storage Temperature …………………………....….......……........ -20~85℃ 2. Voltage accuracy is set at 100% rated load and 25℃ Ta. Humidity …………………...….......….......... 93% RH max. Non Condensing 3. Line regulation is measured from high line to low line with full load. Cooling …………………………………………………….. Natural Convection 4. Load regulation is measured from full to 10% load. Switching Frequency ………………………………………….. 67KHz Typical 5. Typical efficiency at 230VAC and full load at 25℃. MTBF ………………..… MIL-HDBK-217F, GB, 25℃/115VAC 300Khrs min. 6. Standard input and output connectors wafer with LONG CHU P3060 Altitude ………………………….……………………………………… 2000m Dimensions ….….….. 3.501x2.000x0.906Inches (88.92x50.80x23.00mm) series and mate with MOLEX housing 5195 series or equivalent. 7. Model “CFM200XS-P”: Connectors with pcb mountable type. (CFM200XS-P) 3.501x2.000x 1.000Inches (88.92x50.80x25.40mm) Weight …………………………….………………….…… 100g (0.22 Pounds) SAFETY AND EMC: Emission and lmmunity …………………………….…….… EN55032 Class B EN61000-6-3, EN61000-3-2, EN61000-3-3 E N 5 5 0 24 , E N 6 12 0 4 - 3, E N 61 0 0 0 - 6 - 1 Safety ……………….…… EN/IEC/UL 60950-1, EN/IEC/UL 62368-1 Mechanical Specification 0.243 [6.17] 1.701 [43.20] 2.000 [50.80] -Vout 0.173 [4.40] PE VR 0.071 [1.80] 0.040 [1.00] 3.019 [76.67] Typical at 25˚C, nominal line and 75% load, unless otherwise Specified 2 PE 1.000 [25.40]max VR PE 0.150 [3.80] 18] Φ3. 25[ 0.1 Φ 4 3. 18 ] All Dimensions are in inches(mm) Tolerance:Inches:X.XXX±0.02 Millimeters:X.XX±0.5 +Vout ACN 0.906 [23.00]max 0. 12 5[ Φ 0.063 [1.60] 0.079 [2.00]max PE 4Φ 0.243 [6.17] 0.156 [3.96] -Vout 0.150 [3.80] 0.063 [1.60] 0.079 [2.00]max +Vout ACN 3.501 [88.92] 3.202 [81.32] 0.240 [6.08] ACL 2.000 [50.80] ACL 1.701 [43.20] 0.150 [3.80] 0.311 [7.90] 0.486 [12.34] 3.501 [88.92] 3.202 [81.32] 0.240 [6.08] 0.150 [3.80] 0.625 [15.88] CFM20XXS-P Series 0.150 [3.80] CFM20XXS Series
CFM2002S 价格&库存
很抱歉,暂时无法提供与“CFM2002S”相匹配的价格&库存,您可以联系我们找货
