https://www.cincon.com
V13
CFM300S SERIES
300 WATT AC-DC POWER
SUPPLY WITH PFC
Features
* Universal Input Range 90 ~ 264Vac
* Active PFC Meets EN61000-3-2 Class C&D
* High Efficiency up to 94%
* High Power Density up to 14.1W/Inch3
* Over Temperature Protection
* Continuous Short Circuit Protection
* Remote Voltage Sense
* PS On/Off Remote Control
* Power Good & Power Fail Signal
* +5V Stand-by Output Power
* 12V Fan Output
* No Load Power ConsumptionPG>50ms
The TTL goes high with 50ms to 250ms after power set up
The TTL goes low at least 5ms before Vo below 90% rated value
Humidity …………………………….…….… 93% RH max. Non-Condensing
Altitude ………..……………………………………………..………..... 5000m
Cooling ……..… Natural Convection for 200W~250W (See Derating Curve)
Forced Air Flow Convection(10CFM) for 300W
Switching Frequency ………………………....... 60~80KHz typ. @ Full Load
MTBF ……… MIL-HDBK-217F, GB, 25℃/115VAC ……….… 160Khrs. typ.
Dimensions
Open Frame Versions …………….. 5.000x3.000x1.421 Inches (127.00x76.20x36.1mm)
-C Covered Versions .…….. 5.355x3.425x1.591 Inches (136.00x87.00x40.40mm)
Weight
Open Frame Versions ………………….….………….. 420g (0.925 Pounds)
-C Covered Versions .…………………..…………….. 550g (1.21 Pounds)
SAFETY AND EMC:
Emission and Immunity ……………………………..... EN55032/35 Class B
EN61000-3-2, EN61000-3-3, FCC CFR 47 Part 15 Subpart B
IEC61000-4-2, IEC61000-4-3, IEC61000-4-4, IEC61000-4-5
IEC61000-4-6, IEC61000-4-8, IEC61000-4-11
Safety ……………………………………..…..…. Class I, IEC/EN/UL 62368-1
NOTE:
1. Add a 0.1uF ceramic capacitor and a 10uF E.L. capacitor to output for
ripple&noise measuring @20MHz BW.
2. Voltage accuracy is set at 100% rated load and 25℃.Ta.
3. Line regulation is measured from High Line to Low Line with rated load.
4. Load regulation is measured from Full to 10% load.
5. Typical efficiency at 230 VAC and full load at 25°C.
6. No load power consumption
很抱歉,暂时无法提供与“CFM300S360”相匹配的价格&库存,您可以联系我们找货
