CHB300-300S SERIES
300 WATT 2:1 INPUT
ISOLATED DC-DC CONVERTER
Features
Efficiency Up to 90%
Fixed Switching Frequency
Regulated Outputs
Remote On/Off
Fully protected (OTP/OCP/OVP/UVLO)
3000Vac I/O Isolation
Operating Case Temperature -40 to +100℃
Half Brick Size Meet Industrial Standard
2.282.40x0.50
CB Test Certificate IEC60950-1
UL60950-1(Reinforce Insulation) Approval
Safety Meets IEC/EN/UL 62368-1
Shock & Vibration MIL-STD-810F(EN61373) Compliant
Fire & Smoke EN45545-2 Compliant
2000m Operating Altitude
-55℃ Operating Available (Suffix “-M2”)
MODEL
INPUT
OUTPUT
NUMBER
VOLTAGE
VOLTAGE
CHB300-300S05
180-425 VDC
CHB300-300S12
OUTPUT CURRENT
INPUT CURRENT
% EFF.
CAPACITOR
NO LOAD
FULL LOAD
(1)
LOAD MAX.
60 A
10 mA
1125 mA
89
10000uF
25 A
10 mA
1135 mA
88
10000uF
0 mA
12.5 A
10 mA
1110 mA
90
6000uF
0 mA
10.7 A
10 mA
1110 mA
90
6000uF
6.25 A
10 mA
1110 mA
90
3000uF
MIN.
MAX.
5 VDC
0 mA
180-425 VDC
12 VDC
0 mA
CHB300-300S24
180-425 VDC
24 VDC
CHB300-300S28
180-425 VDC
28 VDC
CHB300-300S48
180-425 VDC
48 VDC
0 mA
NOTE:
1. Nominal Input Voltage 300 VDC.
2. Measured at Nominal Input Voltage.
3. An External Input Capacitor 150uF for All Models are Recommended to Reduce Input Ripple Voltage.
4. -55℃ Start-up Screen per MIL-STD105E S1 Sampling Procedure for “-M2” Version.
PART NUMBER
Series
CHB300-
Nominal Input
Voltage
II
Number of
Outputs
O
Nominal
Output Voltage
XX
Remote On/Off
Logic
L
05:05VDC
12:12VDC
CHB300
300:300 VDC
S:Single
None:Positive
-Y (Option)
Operating Case
Temp. Range
-Z (Option)
None:M3x0.5 Mounting
Inserts
None:-40~100℃
-C:Clear Mounting
Insert (3.2mm DIA.)
-M2:-55~100℃
Mounting Inserts
24:24VDC
28:28VDC
N:Negative
48:48VDC
Part Number Example:
CHB300-300S12N-C-M2: Half Brick, 300W, 2:1 180-425Vdc Input, Single 12Vdc Output, Negative Logic, Clear Mounting Insert,
-55~100℃ Operating Case Temp. Range
www.cincon.com
1
REVISION: V16
CHB300-300S
Series
TECHNICAL SPECIFICATIONS
(All specifications are typical at nominal input, full load at 25℃ unless otherwise noted.)
ABSOLUTE MAXIMUM RATINGS
PARAMETER
NOTES and CONDITIONS
Device
Min.
-0.3
Input Voltage
Continuous
All
Input Surge Voltage
100ms max.
All
At the center part of case plate (with Derating)
Suffix “-M2” (with Derating)
Storage Temperature
Typ.
Max.
Units
425
Vdc
500
Vdc
All
-40
100
-M2
-55
100
All
-55
125
Device
Min.
Typ.
Max.
Units
All
180
300
425
Vdc
INPUT CHARACTERISTICS
PARAMETER
Operating Input Voltage
Input Under Voltage Lockout
Turn-On Voltage Threshold
Full load
All
165
170
175
Vdc
Turn-Off Voltage Threshold
Full load
All
155
160
165
Vdc
Full load
All
10
Maximum Input Current
Lockout Hysteresis Voltage
Vin=180V, Full load
All
1.91
No-Load Input Current
Vin=300V, Io=0A
Input Filter
Pi filter
All
Inrush Current (I2t)
As per ETS300 132-2
All
Input Reflected Ripple Current
P-P thru 12uH inductor, 5Hz to 20MHz
All
Vdc
A
mA
See Model Number Table
0.1
A2 s
mA
50
OUTPUT CHARACTERISTICS
PARAMETER
Device
Min.
Voltage Set Point Accuracy
Vin=300V, Full load, Tc=25℃
All
-1.0
Load Regulation
Full load to no load
Line Regulation
Vin=High line to low line, full load
Temperature Coefficient
Tc=-40°C to 100°C
Typ.
Max.
Units
+1.0
All
±0.2
All
±0.2
±0.02
Output Voltage Regulation
All
Output Voltage Ripple and Noise (5Hz to 20MHz bandwidth)
Peak-to-Peak
RMS.
Full load,
5V: 47uF T521 KO CAP.
很抱歉,暂时无法提供与“CHB300-300S12”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1780.339151+230.43956
- 5+1713.981925+221.85056
- 10+1686.0966410+218.24121
- 25+1649.8786525+213.55331
