CFM12S120-E
CFM12S120-E
    CINCON
    模块
    封闭式 AC DC 转换器 1 输出 12V 1A 90 ~ 264 VAC 输入
CFM12S120-E 数据手册
CFM12S SERIES 12 WATT OPEN FRAME AC-DC MODULES Features  Universal Input Range 90~264Vac  High Efficiency up to 87%  1.5”x 1” Open Frame Compact Size  Class II  No Load Input Power < 75mW  Approval IEC/EN/UL 62368-1 Ed 3.0  Approval IEC/EN 60335-1  Approval EN 55032 Class B and CISPR/FCC Class B  Operating Altitude 5000m  Continuous Short Circuit Protection  Over Voltage Protection  Over Voltage Category OVC II & OVC III VOLTAGE RIPPLE& ACCURACY NOISE NOTE1 NOTE2 NOTE3 NOTE4 NOTE5 2A ±2% 100mV ±1% ±1% 80% 9V 1.34 A ±2% 100mV ±1% ±1% 85% CFM12S120 12 V 1.0 A ±2% 120mV ±1% ±1% 85% CFM12S150 15 V 0.8 A ±2% 150mV ±1% ±1% 85% CFM12S240 24 V 0.5 A ±2% 240mV ±1% ±1% 87% MODEL OUTPUT OUTPUT NUMBER VOLTAGE CURRENT CFM12S050 5V CFM12S090 LINE LOAD REGULATION REGULATION %EFF. (Typ.) Note: 1. Voltage accuracy is set at 100% full load. 2. Add a 0.1uF ceramic capacitor and a 10uF E.L. capacitor to output for ripple & noise measurement @20MHz BW. 3. Line regulation is measured from 90Vac to 264Vac with 100% full load. 4. Load regulation is measured from 10% to 100% full load. 5. Typical efficiency at 230 Vac and 100% full load at 25℃. 6. T Version wafer with JST B3B-XH/B4B-XH and mate with JST housing XH series or equivalent. PART NUMBER Series CFM12 Number of Outputs X CFM12 S:Single Nominal Output Voltage XXX 050:5V 090:9V 120:12V 150:15V 240:24V Type -XX Blank:PCB Mount E:Encapsulated T:Wafer Part Number Example: CFM12S120-T: Open Frame, 12W, Single 12Vdc Output, Wafer www.cincon.com 1 REVISION: V20 CFM12S Series TECHNICAL SPECIFICATIONS (All specifications are typical at nominal input, 100% full load at 25℃ unless otherwise noted.) ABSOLUTE MAXIMUM RATINGS PARAMETER NOTES and CONDITIONS Input Voltage Safety approvals only to the AC input All Operating Temperature See Derating Curve Storage Temperature Device Min. Typ. Units 90 264 Vac 120 370 Vdc All -40 75 ℃ All -40 85 ℃ IEC/EN/UL 62368-1 OVC II Operating Altitude Max. 5000 All IEC 62368-1 OVC III 2000 IEC/EN 60335-1 OVC II m 5000 INPUT CHARACTERISTICS PARAMETER NOTES and CONDITIONS Operating Voltage Range Input Frequency Range Maximum Input Current 100% Full load, Vin=100Vac Leakage Current Inrush Current Vin=240Vac, Cold start at 25℃ Device Min. All 100 All 50 Typ. Max. Units 240 Vac 60 Hz All 0.4 A All 0.25 mA All 50 A Max. Units OUTPUT CHARACTERISTICS PARAMETER Output Voltage Set Point Operating Output Current Range NOTES and CONDITIONS Vin=Nominal Vin, Io=Io max., Tc=25℃ Vin=90Vac~264Vac, See Derating Curve Device Min. Typ. CFM12S050 4.90 5 5.10 CFM12S090 8.82 9 9.18 CFM12S120 11.76 12 12.24 CFM12S150 14.70 15 15.30 CFM12S240 23.52 24 24.48 CFM12S050 2.0 CFM12S090 1.34 CFM12S120 1.0 CFM12S150 0.8 CFM12S240 Holdup Time Vin=115Vac All Vdc A 0.5 10 ms Output Voltage Regulation Load Regulation 10% to 100% full load All ±1.0 % Line Regulation Vin=High line to low line All ±1.0 % Over Voltage Protection Output Ripple and Noise Load Capacitance www.cincon.com Hiccup mode (Auto recovery) 1. Add a 0.1uF ceramic capacitor and a 10uF aluminum electrolytic capacitor to output 2. Oscilloscope is 20MHz band width 3. Ambient temperature=25℃ 1. Vin=115Vac and 230Vac 2. Output is 100% full load 3. Ambient temperature=25℃ 2 CFM12S050 6.3 CFM12S090 12.6 CFM12S120 15.8 CFM12S150 18.9 CFM12S240 31.5 CFM12S050 100 CFM12S090 100 CFM12S120 120 CFM12S150 150 CFM12S240 240 CFM12S050 2000 CFM12S090 1340 CFM12S120 1000 CFM12S150 800 CFM12S240 500 Vdc mV uF REVISION: V20 CFM12S PARAMETER NOTES and CONDITIONS Device Min. Typ. CFM12S050 80 CFM12S090 85 Efficiency 1. Input voltage is 230Vac 2. Output is 100% full load 3. Ambient temperature=25℃ CFM12S120 85 CFM12S150 85 CFM12S240 87 Series Max. Units % ISOLATION CHARACTERISTICS PARAMETER NOTES and CONDITIONS Device Min. Input to Output 1 minute All 3000 Isolation Resistance Input to output All 100 Device Min. Typ. Max. Units 4300 Vac MΩ FEATURE CHARACTERISTICS PARAMETER NOTES and CONDITIONS Switching Frequency Pout=max. rated power All Typ. Max. Units 65 kHz GENERAL SPECIFICATIONS PARAMETER NOTES and CONDITIONS MTBF Humidity Shock Vibration Weight Device Min. Io=100%; Ta=25℃ per MIL-HDBK-217F All 580 Non-condensing Meet MIL-STD-810F Table 516.5,Table 516.5-I 10ms, each axis 3 times(±X、 ±Y、±Z axis) Meet MIL-STD-810F Table 514.5CVIII,15~2000Hz, X、Y、Z axis, 1 hour (each axis),. Total 3 hrs. Blank (PCB mount) All Safety EMC Emission Conducted Disturbance Radiated Disturbance Harmonic Current Emissions 93 k hours % RH g All 4 g CFM12S 16 CFM12S-E 40 T (Wafer) CFM12S-T All T (Wafer) Units 75 E (Encapsulated) E (Encapsulated) Max. All Blank (PCB mount) Dimensions Typ. grams 17 1.500x1.000x0.756 Inches (38.10x25.40x19.20 mm) 1.600x1.100x0.772 Inches (40.64x27.94x19.60mm) 2.150x1.000x0.689 Inches (54.61x25.40x17.50mm) Class II, IEC/EN/UL 62368-1 (Ed 3.0), IEC/EN 60335-1 EN 55032:2015+A1:2020, 47 CFR FCC Part 15 Subpart B, EN 55032:2015+A11:2020, EN 61000-6-3:2021, EN 61000-6-4:2019, EN 61000-3-2:2019+A1:2021, EN 61000-3-3:2013+A2:2021 EN 55032:2015+A1:2020, 47 CFR FCC Part 15 Subpart B, EN 55032:2015+A11:2020, EN 61000-6-3:2021, EN 61000-6-4:2019 EN 55032:2015+A1:2020, 47 CFR FCC Part 15 Subpart B, EN 55032:2015+A11:2020, EN 61000-6-3:2021, EN 61000-6-4:2019 EN 61000-3-2:2019+A1:2021 Class B Class B Class B Voltage Fluctuations & Flicker EN 61000-3-3:2013+A2:2021 EMC Immunity EN 55035:2017+A11:2020, EN 61000-6-1:2019, EN 61000-6-2:2019, IEC 61000-4-2,3,4,5,6,11 Electrostatic Discharge (ESD) Radio-Frequency, Continuous Radiated Disturbance Electrical Fast Transient (EFT) IEC 61000-4-2:2008, Air Discharge: ±8kV, Contact Discharge: ±4kV Criterion A IEC 61000-4-3:2020 Criterion A IEC 61000-4-4:2012, ±1kV, ±2kV Criterion A Surge Conducted Disturbances, Induced by RF Fields Voltage Dips IEC 61000-4-5:2014+A1:2017, L-N: ±1kV Criterion A IEC 61000-4-6:2013+COR1:2015 Criterion A IEC 61000-4-11:2020, Dip: 30% Reduction, Dip >95% Reduction Criterion A Voltage Interruptions IEC 61000-4-11:2020, >95% Reduction Application Note Link www.cincon.com Criterion B CFM12S Series App Notes 3 REVISION: V20 CFM12S Series CHARACTERISTIC CURVE Power Derating Curve Derating Curve Rated Load (%) 100% 75% 50% 25% 20LFM(Natural Convection) 0% -40 -30 -20 -10 0 10 20 30 40 50 60 70 80 Ambient Temperature (℃) Performance Data CFM12S050 (Eff Vs Io) CFM12S090 (Eff Vs Io) 90% Efficiency (%) Efficiency (%) 85% 80% 75% 115V 85% 80% 115V 230V 70% 10% 20% 30% 40% 50% 60% 70% 80% 230V 75% 10% 90% 100% 20% 30% Current Load (%) 50% 60% 70% 80% CFM12S120 (Eff Vs Io) CFM12S150 (Eff Vs Io) Efficiency (%) 90% 85% 80% 115V 85% 80% 115V 230V 75% 10% 90% 100% Current Load (%) 90% Efficiency (%) 40% 20% 30% 40% 50% 60% 70% 80% 230V 90% 100% Current Load (%) 75% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) CFM12S240 (Eff Vs Io) Efficiency (%) 90% 85% 80% 115V 230V 75% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) www.cincon.com 4 REVISION: V20 CFM12S Series MECHANICAL SPECIFICATION 0.776 [19.70] max BOTTOM VIEW 2 1.100 [27.94] 0.098 [2.50]max 0.571 [14.50]max 0.173 [4.40] 0.150 [3.80] Φ0.039[Φ1.00] 0.150 [3.81] 3 2 0.800 [20.32] 0.800 [20.32] 1.000 [25.40] 4 1 0.772 [19.60] 0.100 [2.54] 0.213 [5.40] 0.100 [2.54] 3 4 1 0.150 [3.81] Φ0.039[Φ1.00] Φ0.071[Φ1.80] 1.300 [33.02] 1.600 [40.64] 0.150 [3.81] 0.150 [3.81] 1.300 [33.02] 0.400 [10.16] 1.500 [38.10] CFM12SXXX-E 0.100 [2.54] 0.400 [10.16] 0.100 [2.54] CFM12SXXX PIN CONNECTION Pin Function 1 ACN 2 ACL 3 -Vout 4 +Vout All Dimensions In Inches[mm] Tolerance Inches:x.xxx= ± 0.02 Millimeters: x.xx = ± 0.5 0.125[3.18] CFM12SXXX-T 2.150 [54.61] 1.900 [48.26] 0.123 [3.13] 0.127 [3.22] 1 3 4 All Dimensions In Inches[mm] Tolerance Inches:x.xxx= ± 0.02 Millimeters: x.xx = ± 0.5 Pin 1 2 3 0.709 [18.00]max 0.571 [14.50]max AC Input Connector(CN1):JST B3B-XH-A(LF)(SN)(2N) or equivalent 0.098 [2.50]max 8[Φ 3.5 0] 0.125 [3.18] 4-Φ 0.1 3 1.000 [25.40] 1 0.750 [19.05] CN2 CN1 Function Mating Housing Terminal ACN JST JST XHP-3 or equivalent SXH-001T-P0.6N or equivalent ACL DC Output Connector(CN2):JST B4B-XH-A(LF)(SN) or equivalent Pin 1 2 3 4 Function Mating Housing +Vout +Vout JST XHP-4 or equivalent -Vout -Vout Terminal JST SXH-001T-P0.6N or equivalent sales@cincon.com.tw www.cincon.com 5 REVISION: V20
CFM12S120-E 价格&库存
很抱歉,暂时无法提供与“CFM12S120-E”相匹配的价格&库存,您可以联系我们找货
CFM12S120-E
  • 1+80.271921+10.38440
  • 5+76.470525+9.89263
  • 17+73.6824217+9.53195
  • 34+72.1534234+9.33415
  • 51+71.2729551+9.22025
  • 102+69.79175102+9.02863
  • 255+67.88105255+8.78145
  • 510+66.47072510+8.59901
库存:248
